Everything posted by subiemech85
My son's re-creation of the MW2 Subaru Meet
then it brings back memories
EA-71 3 door coupe?
check your body: you have a wagon wagons have the handle in the headliner there are two different types of handles you may want to check a sedan
EA-71 3 door coupe?
GRAB HANDLES: xt, xt6, omega, rx, 3dr all use the same handles they also should have the nuts welded in , equipped for installation of optional features all you have to do is pull down the plastic trim, turn it over, and there should be the marks for where to drill new holes done it to my rx, grabbed the handle from the xt6
"ECS" light ? what does it mean?
E missions C ontrol S ystem engine check stupid :-p
Fuse keeps blowing
yes, chech your grounds
EA-71 3 door coupe?
equipped with shape shifting decals and headlight squirters :drool:
Sti ATV!!! the name says it all!!!
I was thinking of actually "using" it maybe a gun rack to hold all the recovery gear :-p I shoot bow
EA-71 3 door coupe?
your room must be the one with the robin in the window, just behind the hood how about detalis, pics of engine
needs a hitch, winch, and tires
Factory Fuel Pump Flow Rates
61-71 psi 25.1 g/hr @ 43.4 psi
ea-81 subaru sucks, take a look!
Quote: Originally Posted by hatchsub These cars are designed to run on a certain amount of backpressure. Not true. But you're right, it's not a good idea to run it without any exhaust bolted up. Won't harm anything it you're just firing it for a few seconds, though. BALONEY! they should idle just fine, but there is a "dead spot" just off idle, with a corresponding loss of torque, after that, the sky's the limit as far as high rpm low speed driving, 5k @35, or whatever, circle track corn field racing against a crappy buick century that eventually burnt up quite well
coil wires mix up
don't worry, the'll still run when wired backwards and the noise choke, one end goes to coil +, the other to engine ground
did you change the other fuel filter, by the fuel pump?? the idle adjust screw is long, in about the middle of the air box, underneath it
info request: headlight squirters :clap:
I would like some info on the strange little novelty, since I know of only the xt6 having them in the US, I want! do they have a separate reservoir or pump for the fluid? how are they plumbed?? and most important: how well do they work to blast off mud and ice??? got pics?
twin core radiator tweak
"fan wouldn't come off without damaging the radiator in some way" why is that so? all you would of had to do was remove the 4 nuts on the waterpump pulley, remove the 4 bolts on the fan shroud, if equipped, and pull up
Loose things under the hood?!
when in doubt, yank it out the white thing is a fuel filter, it would be good to add it to the supply line to the carb under the air box the blue thing looks like some kind of vac. controlled vent device all a carb engine needs to run is a line for the choke, and then add a line for the vac. brakes, climate control, timing advance I have made write-ups of emissions removal and they seem to run better afterwards. headlight squiters!!
Lifted Justy
"speed hump" for larger hampster wheel
Transmission Q? clarification
it's full time 4wd, with center diff lock, or part time 4wd and let's try to keep our numbers straight, 1.196 -- (20/22 x 25/19) 1.592 -- (23/14 x 25/19) can the 20/22 gear set be swapped for the 23/14 gear set to give the better low?
FIXED!!! Gremlins running amok or low volts problem, help needed.
run wire from bat+ term on alt to battery + run wire from alt case screw to battery - run wire from battery + to terminal of fuse link box check fusible links, IIRC a green one haldles the charge check 15a fuse, should have low voltage when NOT running
Newbie pinging problem (EA82) FIXED
here's what you can do: replace sparkplugs with NGK BPR6EY-11 OR BPR6ES-11 v-power or regular replace plug wires with NGK or BOSCH remove EGR valve, remove ASV, and block off run vac. line from vac. advance unit to intake manifold port near head remove emissions canister, one line is left open, one line is blocked, and I forgot the rest you should be able to run 89 octane
Turbo help - boost is almost gone :(
there may be foreign material blocking the flow of exhaust gasses in the turbo housing
OR remove the fan
Check ALL J/Y Soobs!
found: set of 3 brake pads, NIB change tools subaru tool kits 2 metal saucer sleds coat -- wore it out underware,
To fix or not to fix
that ain't good
ECS light - trouble codes
the way to diagnose subarus is KISS start removing, disconnecting, blocking off, reverse engineering, etc. until it runs like you want it to I am guessing the c/w is the problem, either put on a weber -- holley, or a ea82 hitachi with matching intake manifold -- my personal favorite, and do away with the ecm
