Everything posted by MilesFox
5 Spd Transmission - which years will fit
MilesFox replied to sam888's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthat gear ratio should be 3.900
EA82T intake onto the EA82 SPFI ??
the heads and intkes are different 1 port vs 2. whay you can do is swap the entire turbo engine and harness into the gl, along with the engine crossmember and all the pipes. what can be better, is you swap the turbo heads and intake onto the gl short block. this gives you mpfi, and you can ditch the turbo, because you will have a block with more compression. you still have to swap the ecu and harness, but you do not need the engine crossmember. the easiest thing to do is take the gl shortblock, put the mpfi heads onto it, and fix up the gl-10 and makit NA mpfi.
bigger side rear mirror
MilesFox replied to eastwestboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow about a spot mirror or a wide angle stick-on? if you stand alongside the car, you should see the driver's face in the mirror when adjusted properly. The spot mirror will help you see the white fog line and the road immediately next to the vehicle, while the rest of the mirror is looking straight behind you.
failed emissions test in GA - 1994 Loyale
have you looked at the coolant temp sensor?
need a lil help
This body of text is an adaptation of an existing article for compilation. I did not write this, but it is sure handy info.
need a lil help
The GL-10 was the luxo trim package, and the seats were more plush with velour and the buttons, where the regular gl had more of a tweedish type fabric. the gl-10 seat has a height adjust lever on the side. pulls up or down, extends for leveage. Check the vin plates from the dash and the door sill. what is the build date? can the dude produce a title, or is this a parts car? Subaru Vehicle Identification Decoder Look up your vin number online First 3 Digits JF1 Passenger Vehicle JF2 Multi-Purpose Passenger Vehicle (MPV) Fourth Digit Model Line A Subaru XT and Loyale K Subaru J Line Fifth Digit Body Type A Justy B 4-dr 81-84 C 4-dr 85-89 F HatchBack 81-89 G 3-dr Coupe 86-89 K Touring Wagon 89 M Wagon 81-84 N Wagon 85-89 R Brat 81 T Brat 82-85 U Brat 86-87 W Hardtop 81-84 X XT 85-89, XT6 88-89 Sixth Digit Engine Type 1 1300 2 1600 3 1600 4wd 4 1800 5 1800 w/o air suspension 7 1800 4wd with air suspension 8 2700 9 2700 4wd with air suspension Seventh Digit Model Designation 1 STD Hatchback 2 DL 3 GL 81-90, RS, Justy 4 GLF 81-82, GL-10 85-89, Xt6 88-89 5 86 Turbo, GL-10 Turbo 87-89, GL full-time 4wd 3-door 87 6 Turbo RX 7 GL Turbo 87-89 Eighth Digit Weight Class and Restraint Type A Less then 3000 lbs GVWR B 3001-4000 lbs GVWR with Passive Restraint 1 Less then 3000 lbs GVWR 2 3001-4000 lbs GVWR with Passive Restrain Ninth Digit Check Digit Tenth Digit Vehicle Model Year A 4spd MT B 5spd MT C 3AT D 4spd 4wd MT 81-84 D 5spd 4wd MT 85-89 E 4spd 4wd Dual Range MT 81-84, 85-89 Hatchback, 85-89 Brat E 5spd 4wd Dual Range MT 85-89 F 3AT 4wd G Full Time 4wd MT H 4EAT Full Time 4wd 4 4spd 4wd 87 Hatchback Last Digits 002001 & after Touring Wagon 100001 & after Hatchback 200001 & after 4 Door Sedan 300001 & after Hardtop 81,84, XT, XT6 400001 & after Wagon 500001 & after Brat 700001 & after Justy 800001 & after 3-Door Subaru VIN code Position Sample Description 1 4 World Manufacturer Identifier 2 S 3 4 4 B Line type 5 T Body style 6 6 Engine type 7 1 Model identifier 8 C Restraint type 9 X Check digit 10 3 Model year 11 7 Plant of manufacturer & transmission type 12 1 Sequential number 13 0 14 8 15 3 16 8 17 5 Line types The line type is specified in character four of the Subaru VIN for passenger cars. VIN Code Description A Alcyone/XT/XT6 B Legacy/Baja C Alcyone SVX G Impreza S Forester Body styles The body style is specified in character five of the Subaru VIN for passenger cars. VIN Code Description C Impreza Sedan D Legacy Sedan E Legacy Sedan F Impreza & Forester Wagon G Legacy Wagon (Outback models) K Legacy Wagon M Impreza Coupe P Outback Wagon T Baja X XT/SVX Coupe Engine types The engine type is specified in character six of the Subaru VIN for passenger cars. VIN Code Description 2 1800cc FWD 3 3300cc AWD 4 2200cc AWD 6 2500cc AWD 8 3000cc FWD Models The model is identified in character seven of the Subaru VIN for passenger cars. VIN Code Description 1 Base 2 Brighton 3 L 5 LS/S 6 LSi 7 GT/RS 8 Outback/Sus 9 Postal Vehicle Restraint types The restraint type is specified as character eight of the Subaru VIN for passenger cars. VIN Code Description 2 Automatic Seat Belt without Air Bag 5 Manual Seat Belt w/ Driver/Passenger Air Bags 6 Manual Seat Belt w/ Driver/Passenger Air Bags and Side Air Bags C Manual Seat Belt w/ Driver/Passenger, Curtain and Side Air Bags Plants and transmission types The plant and transmission type is specified in character eleven of the Subaru VIN for passenger cars. VIN Code Plant Transmission 6 SIA AWD MT5 5/R 7 SIA AWD 4EAT 8 SIA AWD 4EAT (Postal) C FHI FWD 4EAT G FHI AWD MT5 5/R H FHI AWD 4EAT SIA=Subaru-Isuzu of America FHI=Fuji Heavy Industries Subaru WMIs WMI Country Description Vehicle Types JF1 Japan Fuji Heavy Industries Passenger Vehicle 4S3 USA Subaru-Isuzu of America Passenger Vehicle 4S4
New/used Alt
If you are looking for alternators, they work from 83-84 subarus. sometimes there can be a fitment issue with certain AC setups, where there is a rounder alternator for (usually turbo/xt) for the square compressor with an inboard alternator. the more common setups are a round compressor with the alternator outside. This alternator has a flat frontal are a with a little bit of a lip around the circumfrence. this alternator in the other styles place can butt against the bracket before taking all of the slack out of the belt, resulting in loose engagement as the belt seats over time. you can overcome this by grinding on the side of the alternator to remove the lip where it touches the bracket. a nissan maxima alternator fits, too, and is 60 amps, instead of 30 amps.
need a lil help
This car is a 1987 with gl-10 seats. the steering wheel is 1987 specific. 85-86 was more squarish, and 88 thru the loyale had the long horizontal middle, the dildoey steering wheel. 1987 is somewhat specific to its year, as this was a tansition year. The wiring harness is schematically similar to a 1988, but has connectors similar to a 1986. The sensors and distributor are compatible with 86. by 88, the design remained considtent through the 1994 loyale. The instruments have a green illumination. if you replace your engine, the harness form the intake will swap over to an 88+ manifold, and the manifold itself swaps. The connector for the engine harness is similar to 1986. If you use a motor from 88 or later, you need your original intake, or at least swap your87 harness to the 88+ intake.
88 gl power problems
one thing to suggest, a bad engine temp sensor or corroded plug. 2, ignition timing, it should be at 20 deg btdc 3, timing belt alignment, could have skipped a tooth, or is installed a tooth off by the previous mechanic. search "timing belt check and adjustment" on this forum, and "the art of subaru maintenance" eisodes 7 and 8 on youtube. This will give you the basis on understanding the oddity of the ea82 engine. your 'tbi' setup is called 'spfi' in subaru terms (single port fuel injection) after reading the timing belt article and watching the videos, you can easily check your timing marks by removing the outer covers and rotating the crank
Subaru shop in Milwaukee
MilesFox replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might be able to remedy the lifter tick by rebuilding the il pump. there is a plate internally that the screws can get loose on, and it's common to remove the oil pump and re-torque these screws. this work can easily be don in an afternoon, along with other routine service such as cam seals and timing belts at the same time. we have shop space, and would be happy to help you with working on your car, just to shoot the breeze and have a few beers, all in a saturday afternoon! I like working on subarus, and i am in it more for the enthusiasm than for any money i can make. It's the kind of thing we do just for the fact that someone would appreciate it. I hope to see you at one of out weekend meets, we need to grow our local subaru crowd!
BRAT brown light syndrome
The lights ground thru the headlight switch.
MilesFox replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am available after 5 pm tue-thurs, and the rest of the week is for working on cars. Depending on cost comparison, we can do the head gaskets for within the price of another motor to swap. HG's are not the end of the world, and once fixed, are beter than new.
MilesFox replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi AM HAVING THIS SHOP DO THE WHEEL BEARING IN THE FORESTER, since i do not have the right tools. We have a Subaru Alliance here in milwaukee, and a shop space. i have an engine crane, and have a shop full of old school soobs. Once i finish this ea82 head gasket, we could do the swap in an afternoon. 414-793-7728
Hey guys need help with my subaru
If your car is SPFI fuel injected, this is your code. is your car a 3-door? http://www.economysuperstar.com/milesfox/subaru/service/ecu.htm
old subaru market has collapsed
tell everyone to quit parting off repairable cars. this makes ebay sellers hungry, selling parts to people that dont have cars left to put them on! i have been seeing a lot of original rnning ea82t's being chucked out for ej22's what ever happened to the days when you had gl wagon, that you had to invent your lifts, bellhousings, and swaps. nowadays you can go but grandma's car and order sjr's online. pretty soon we will have this problem with 1st and 2nd gen legacy and impreza. As the new market is buying up new soobs as a sales trend, there will be a few people scouring the earth for the last non-interference motors and cars.
fwd cv axles
non turbo auto and manual are the same. 23 splines
Scoring an XT6 next weekend!
There are guys in coumbus, oh, and one guy in hillsdale michigan. I am from fort wayne area, and i was down to columbus to hit up the junkyards for ea82's, since they were scarce in indiana.
86 Turbo XT blown head gasket?
try replacing the engine temp sensor. typical symptoms are starting up fine, but once warm, runs crappy and hard to start. Typically the connector corrodes.
eating more drivers side timing belts
the title of the thread says it all: Re: eating more drivers side timing belts
Never saw this sube before
MilesFox replied to naru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX4eat?
where do you buy?? XT6
I think it may be possible to use an impreza or legacy(libery) axle and change out the inner bearing seal on the knuckle to the impreza seal. I think this is a Numbchux discovery. correct me if i'm wrong.
SE WI, Milwaukee Regional/Subaru Alliance
other than loose cords and items layng around, there is room tp put the car in there
Wanted subaru legacy parts (colgate) Date: 2011-03-07, 9:38PM CST Reply to: sale-mzgsp-2253271889@craigslist.org [Errors when replying to ads?] I am looking for the front clip from a 2001 subaru legacy. The items i need are listed below Front bumber head lights fog lights both front fenders hood radiator front frame support drivers door and pretty much anything else to do with the front end If you have any of these parts and are looking to get rid of them please give me a call or text 414 550 9088 thanks justin also i have cash in hand
Timing belt tensioner ?
MilesFox replied to Fairtax4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtake a 6" c-clamp in your car. I had the same car throw the same timing belt at the same place on the same day doing the same thing 1 year later. donuts behind the truck stop in the snow. the same tensioner. you should be ok as long as you are not doing donuts behind the truck stop
maybe there is slack in the oil pump shaft, and the belt is walking around on the pulley. Have you replaced any pulleys? the belt residues on the tensioner could be clue to seizure once it warms up, or drag on the belt causing it to break, and residue from the resulting heat. i would start by suspecting the tensioners or the idler pulley. spin them. if they rattle like skateboard wheels, get new ones.
