Everything posted by ()__1337_CRAYOLA__()>
so what would it take?
()__1337_CRAYOLA__()> replied to rpholz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
better off doing a ej swap for reliability -
hmmmm why is one fender different from the other
man white... im gonna get it greasy... haha
put me down for a 2xl are they gonna be white though?
Pics of my Turbowagon!
()__1337_CRAYOLA__()> replied to 4x4_Welder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
could be under the hood on drivers side by firewall i believe -
79 brat dead, need help quickly.
()__1337_CRAYOLA__()> replied to mandelbrotx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
alright... id hate to see a car get towed ive been in that same type of situation befor and have been lucky a few of my friends own big chevys with trailers -
did you get it to move? i could bring my brat down to seattle and tow you around if your not to far into seattle... -
and when you were rolling down the hill it seemed like it was running but i doubt it was -
what did you do comming up to the hill... check your plug wires check the rotor and make sure it's on alot of things could have happened -
loyale lacks power
()__1337_CRAYOLA__()> replied to saetern's topic in Old Gen.: 80's GL/DL/XT/Loyales...
what type of spark plugs are you using... ive had problems with the higher end plugs out of the box giving me this problem now i use e3 diamond fires or standard ngk's -
High temp low pressure. WTF?
()__1337_CRAYOLA__()> replied to wentz912's topic in Old Gen.: 80's GL/DL/XT/Loyales...
when the car overheats you oil will thin out giving you low oil pressure its a cause and effect thing -
How The Heck....
()__1337_CRAYOLA__()> replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
bumpo anyone... i hooked it up and all i could get it to do is run for a second then backfire and die.... -
has anyone installed a MSD 6A box on there ea81... if so how was it done do these soobs have mag pickup?
how much would it cost to have a new seal installed using old glass.... the person that replaced the windsheild on my brat used silicone and it is wicking into the glass xD
wouldnt the sti engine eat that auto alive?
EA81 Cylinder Wall
()__1337_CRAYOLA__()> replied to XT6 Magic's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you had to deck it? was the block warped.... because it never got over running temp while i owned it. it didnt burn to much oil it mostly leaked it. (it marked it's teritory) that engine ran like a champ every day untill i swapped it though... and it is amazing at 218,000 miles it still has the factory cross hatching -
EA81 Cylinder Wall
that the one you got from me? i didnt think it was that bad it had blown head gasket symptoms for only maybe under 2 weeks befor i swapped it... it never got hot or anything just steamed:eek: -
just sign the title over to me and ill come get it tommorow :-p
On the light trail :)
()__1337_CRAYOLA__()> replied to Caramanos2000's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that thing must be a oven when it gets hot out with that bed liner on the roof! -
can i do lights?
()__1337_CRAYOLA__()> replied to bicycle_ben's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your good.... but if it just so happens they do take your alternator out spring for the lifetime warrenty one -
I Got My Rims Back Today
()__1337_CRAYOLA__()> replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ahhhhhhhhhhhhhhhhhhhhhhhhhhh there WHITE!!! but they'll look awsome with some trim rings and center caps and maybe tires :-p -
No Spark! Help please! *Pics*
()__1337_CRAYOLA__()> replied to kellyray's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that thing grounds to the body and the neg (-) side of the coil but i doubt thats your problem as i run my ea81 brat without it:-\
