Everything posted by thatswhatshesaid
I'm in! thats_what_shesaid @ hotmail . com SWEET!
Sounds awesome! I might be taking part of this! Can't wait!
Weight transfer from left-to-right (or vice versa) will ALWAYS be the same. The gravity and lateral force will be present no matter what suspension set-up you have. The weight of the car and common laws of physics are NOT CHANGING. The point you brought up regarding SUVs is a completely different - the reason SUVs roll over is because they are waaaaay taller and higher off the ground. They also have more weight up high (high center of gravity). Now we're talking about up-and-down center of gravity. Not side-to-side weight transfer. Newton's laws act on SUVs and Subarus exactly the same. No exceptions. The SUVs roll over because (A) the suspension on one side compresses much more than it would on a Subaru and ( because the monstrous amount of lateral (centrifugal) force applied to a vehicle with a much higher center of gravity. The side-to-side weight transfer is no different on a 4,000-lb. Jeep than a 4000-lb. Outback (assuming the front-back weight distribution is the same for the sake of argument). It's the top-to-bottom C.O.G. that meks the Jeep flip. The laws of physics that we've known for centuries are always present. They cannot be ignored with swaybars and struts. In short, Sir Isaac Newton isn't a liar. STILL.
Oooh, yes. That wouls be one short (and capable) EA. I wonder how much you could hack away at the front of the car... ...Upon inspection of the Loyale (jeez - it's like 5* F outside), it seems as though you might be able to whack as much as 10" (or so - give or take a few inches) away from the front of the car if no radiator is present. The safety features up front will need to be replaced, though. Perhaps a big, meaty bumper would do the trick. What are you thinking, Scott? I want to see the photoshop results now! Yahoo!
So...my EJ25 is running like poo poo. - 2000 Outback (EJ25) with auto tranny - 135k miles - I've owned the car for the last 8k miles - maintenence before that is not well documented, so...? It all began about 1k miles ago (at the beginning of a 900-mile road trip), with a slight hesitation on hills, and a backfire every now and then. I had to finish out the trip. so now I'm back, I've driven it two more days and the symptoms are much worse. Backfiring happens in every gear below 3k RPMs. Above that, it smooths out, but still lacks the power it used to have. I have looked for vacuum leaks, but to no avail (I haven't done the propane test). Apparently there is no EGR valve, so that's out. When it starts to run roughly, the CEL flashes. It idles normally, but any more load than that and it runs badly. So here's what I'm thinking (let me know if I'm wrong): - PCV? I'll grab one tomorrow - it's 5 bucks and it probably needs it anyway. - Bad plugs/wires? If the plugs have carbon build-up, are the wires toast too? And how the flip can I get to the plug on cyl. #4? Any other ideas? Thanks, - Tyler
The '04 is beautiful. It's got awesome amenities. However... The '05 is MORE stylish inside, is faster, safer, handles better (the body style change brought suspension changes that make it handle wonderfully). If anything, the '04 will handle like an SUV when compared to the '05. I'd say go for the '05 (but dang, I like that monotone black so darn much, and the two-tone gray/silver is so plain...)
I think everyone that buys one should get a "Donor" badge under their name...they ARE donating (in a roundabout way).
I'm tentatively in for one, as long as I like the pictures of the final product.
