Everything posted by subaru360
I just scored a 93 Impreza for $200!!!
subaru360 replied to A DOG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe have a purple 93 too. GF loves it and won't part with it. I just got a green 95 and did a jdm wrx swap on it. Try RS25.com Nasioc is mostly 02+ WRX stuff anymore.
teh East Coast meet: Carlisle 2010 thread! Its on!
I'm out for this year. I just scored Red Sox tickets for the 22nd.
Can I really prevent rust by....
subaru360 replied to pearlm30's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI always toss them. They trap dirt and water.
Head gasket blown after three months since replacement?! - 97 Outback 2.5
subaru360 replied to sean56a's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll let the myth perpetuate itself. I make a lot of money buying and repairing the blown head gasket cars.
Need front rotors and pads replaced on 02 WRX
Rotors are cast iron, not steel. I'm square in the middle of the rust belt. OEM rotors rust just like anything else here. Large chunks of the braking surface flake off often. Cheap rotors are $20-30. Expensive and OEM ones are $150. Places around here charge $20 to cut rotors. I just put on a fresh set of cheapie rotors with almost every pad change I do. It makes sense for me.
http://www.rockauto.com is about the cheapest I've found for brake parts. Rotors are rotors. No point in buying them from a dealer, just get what's cheap. If it's just an everyday driving car, any name brand semimetallic pad is fine like wagner, raybestos, bendix etc . Some of the real cheapo no-name pads can be noisy and not last too long. If you can turn a wrench, take the wheel off and it's 4 bolts per side to change pads and rotors. Just use a c clamp to push the piston back in. You can do it in about 1/2 hour. If not most places will charge about 1-1.5 hours labor.
Good bye
If you thought the Outback had problems, you're going to hate the VW.
IDENTIFY brakes...
subaru360 replied to monstaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot in the US. We got 2 pot front 1 pot rear brakes on the wrx 02-05. Those could fit a lot of different models. Legacy, WRX, RS etc. The calipers are all the same mostly, just different brackets for different rotor sizes.
That is the way to go then. It's a pain having to park, get out, wait in line then, get back in the car and park again. They should have done this a long time ago.
No AWD option in new Subaru Sports Coupe
subaru360 replied to bobs97c5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo idea. This car has been talked about for years.
What's so 'Limited' about this Outback Limited?
subaru360 replied to dave833's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot a limited. Insane asking price. It's worth about $2000 with that mileage, I don't care if it has a new engine. $4900
02 wrx turbo question
subaru360 replied to pamike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou probably had a leaking turbo inlet and they fixed it for you.
subaru360 replied to bobs97c5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's only going to be rwd. Kind of old news.
Need to replace doors on 97 Legacy Outback
subaru360 replied to johnny9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think they are from a 97. You'd just swap the door wiring harnesses over. Original paint. They will probably still be here in April, unless I get sick of looking at them and scrap them.
subaru360 replied to johnny9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpop the grommets out and the wiring plug is inside the body pillar. There is usually enough slack to pull it out. If not pop off the trim panels inside the car.
WRX Fob
subaru360 replied to Durania's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCompare the numbers on the back of the fob. If they are the same it will work.
subaru360 replied to johnny9k's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have 4 green outback doors in PA, no rust out $25 each picked up. I really just want them gone.
what year engines will fit my 95 Legacy
subaru360 replied to dgarlepp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes the pulley will fit.
subaru360 replied to sean56a's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy advice, don't put anymore time or money into a questionable engine. Get a 2.2 and put it in. Don't spend more than $500 if you get it pulled out or $100 if you go to a U-pull it. Try to find one under 200,000.
subaru360 replied to dgarlepp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet underneath it with a chisel and pop it out. Tap the new one in with a hammer.
subaru360 replied to dgarlepp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo, 96 and up is dual port heads.
subaru360 replied to dgarlepp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your 95 a 5 speed or automatic? If it's a 5 speed the 90 engine will work as long as you transfer the intake manifold and all the sensors over from your old engine. If it's an automatic, you need a 95 2.2 automatic engine for a direct fit. Or a 96-98 2.2 automatic engine if you can get the matching single port exhaust y pipe. You can replace the crank key, but usually the end of the crank gets damaged when they come loose.
Maybe I'll bring my new one. 95 Impreza coupe with 95 jdm wrx EJ20G.
Torque for castlenut
subaru360 replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow exactly can over torquing the axle nut warp the rotor? 140 ft lbs is a lot, unless you have a 4 foot bar on it, you don't really have to worry much about getting it too tight.
ej20 non turbo to turbo ?????
subaru360 replied to dunnahog69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll of the turbo parts will just bolt on. The wiring and ECU is different. The non turbo engine will have higher compression. Assuming you put all the turbo parts on the non turbo engine, you'd need a way to retune it to run correctly with higher compression.
