subaru360
Everything posted by subaru360
  1. You can buy brand new axles from rock auto for $60 plus shipping. http://www.rockauto.com
  2. In my part of the country they run until they rust in half. Literally sometimes. Almost every one in the junkyards here is over 200,000 miles. We see 300,000 often.
  3. The front one for a 93-01 Impreza will fit 95-99 legacy and outback. I've done it. Not sure about the rear.
  4. It's typical. The factory flash might help some. The final solution is aftermarket tuning with a tactrix cable and rom raider and ecu flash software, if you're willing to go that far.
  5. That looks like every other subaru here in PA. Put a socket over the exhaust nuts and bang it with a hammer a few times to break the rust before you try to loosen the nuts. You'll have to pry the engine and trans apart. Start with a gasket scraper, hammmer it in between, then go to a screwdriver, then a prybar. The bodies here all rust out where the rear bumper meets the quarter panel. I deal with this stuff all day, it's not so bad. For my personal cars, I buy them from southern states and get them shipped to avoid rust. My 95 Impreza I just bought came from florida, my last wrx was from southern MD.
  6. 99 Impreza 2.5 RS is phase 2 as well. In 05 or 06 they added variable valve timing. You can still use those engines in older cars. It just won't work, the ecu won't control it and defaults to full lift, runs fine. Keep the intake manifold with the car. Swap it onto the new engine.
  7. Shouldn't it still be under emissions warranty? 5 years and either 60,000 or 100,000 miles. If so take it to the dealer.
  8. You can get a set of aftermarket ones for less than 1 factory one. It's not hard to install. Drill 2 holes and splice 4 wires.
  9. You could still bring a Z car to Carlisle. If everyone else is going to give it another shot, maybe I will go again. I sold my wrx wagon and am building a new car for myself. 95 Impreza coupe with 95 jdm wrx swap. The WRX was fun, but it was just too nice for me, I was constantly worrying about something happening to it. I like sorta beater cars more. I'll be able to screw around with this without being paranoid. I still have the 360 don't worry.
  10. I've personally driven a FWD legacy in Maine in the snow in winter. My GF's parents had one. She hated driving it in the snow. I hated driving it in the snow. Her Mom hated driving it in the snow. It also sucked in dirt and gravel. They push (understeer) really bad. I got them an Outback to replace it. It's much, much better. With an awd subaru if it pushes in the snow, you just get on the gas, the back end comes around and you power through the turn. Not to mention you can take off without massive wheelspin.
  11. FWD subarus suck in the snow. Sorry you found that out after you bought it. Convert to AWD, it all bolts in. Or sell it and buy an AWD one.
  12. 1. A better turnout. 2. Security not kicking people out before I even got there. Plus honestly besides our Subarus, a few older Hondas and the random old english car, there really wasn't much else to see or do that interested me. Hundreds of Volvos, Saabs, Bmw's, Audis Mercedes etc was boring and the owners of said vehicles were generally speaking snobbish a-holes.
  13. Thanks. I'd like to see the top of it, where it goes up to the steering column. If it looks like it will work, I'm looking to buy one as well if anyone has one for sale.
  14. Has anyone ever laid eyes on a Loyale or any EA82 car with manual steering? Or own one and can get a pic? Rumor on nasioc has it that these manual racks will bolt into an Impreza. I want one for my Impreza. I've been looking for one in the pick a part and haven't found one yet. All the loyales I found were PS. I did compare an EA81 manual rack to an Impreza and it was not the same. The spacing on the mounting bushings is different. The loyale and the Impreza PS racks have a wider spacing on the mounts. Supposedly the loyale manual rack does not have the bolt on extension up to the u joint like the EA81 does and the mounting bushing spacing is the same as Impreza. I saw a few loyale manual racks on Ebay, but I wanted to verify before buying what it looks like.
  15. The wheels will fit fine. The tires you woud have to test fit for clearance. They may be too tall or wide and rub the struts.
  16. 99 is a one year only MAF for forester and impreza. But you can find one on car-part.com for $30-$50 easy enough. I got one for a 99 RS last year for $45 shipped.
  17. The squared off bottom oil pan takes more oil than the rounded bottom oil pan. It's got nothing to do with reliability. You can use any EJ oil pan on any EJ engine.
  18. New at this huh? You need to go a little further north in PA to get to the good yards. Harry's in either Pennsburg or Hazleton has engines for $90 EZ pull in New Ringgold has them for $65 Buy them from a wrecked car so you know it runs. At harry's if there is an R on the windshield, it's an insurance auction car that ran.
  19. It's part of the oil pump. There's a lever coming off the side of the pump with a cable attached to it. The cable can get stuck wide open if it's not adjusted right. If you are working on a 360 that's been sitting around for a long time, it is going to smoke bad, not much you can do about it. It will keep smoking until you get it out on the road and drive it hard, as in wot, for a few days to burn all the old oil out of the engine and exhaust system.
  20. The oil pump has a variable rate, it's controlled by a cable that runs to the carb. It pumps less oil at idle and more at wot.
  21. It's not worth rebuilding 2.2's being that you can buy them so cheap used. Go buy a used known good running 2.2 for $200 or so. Reseal it for under $100.
  22. Rota makes cheap, decent looking wheels in the right size and offset for subarus. I've had 2 sets of them and they have been fine. http://www.wheeldude.com
  23. The canister is the only real difference. I also think it was 98 when it went to the back of the car. But there are always oddball cars. The only other thing I can think of is look at the vacuum lines that lead to the inner fender, some years have one and some have 2. You don't have to change the intake for that, just hook them up in the right spot on the new engine.
