Everything posted by subaru360
Prices/rareness? 91 turbo leg 5 speed in the junkyard
subaru360 replied to hatchsub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can get $500-600 for the block. The rest of the engine isn't worth much. The trans isn't worth a whole lot, it's pull clutch like a wrx, but has the older style narrow gears old synchros. The rear lsd might be worth a few hundred if it's not the one with the old style axles, that one doesn't work in much but old legacys. Not all T legs have LSD.
Remove cams to do HG?
subaru360 replied to larrykjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPhase 1 2.2 and 1.8 you don't have to remove cams or valve covers. Phase 1 2.5 you do. It's not hard. Just keep all the lifters in order.
2.2 L swap on a 98 Forester AT?
subaru360 replied to larrykjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEGR recirculates exhaust gas for emissions.
subaru360 replied to larrykjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo way around it. You have to remove the cams.
subaru360 replied to larrykjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot an issue. 98 forester still has the 4 bolts engine to trans. 95 2.2 goes right into a 98 forester.
JDM EJ25 has coil behind intake, mines up top will it work??
subaru360 replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe engine in the Ebay link is an oddball. I'd pass on it. It's got a turbo exhaust manifold and hydraulic lifter 96 and older heads on it. And that odd intake manifold. I'm not sure exactly what it is.
comment by sub tech re: P0420
subaru360 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplacing O2 sensors has never fixed a 420 code for me. Antifoulers have fixed it 9 times out of 10. It's almost always bad cats. Aftermarket cats will not fix a 420 code. New dealer cats will, but who spends $1000 on cats for a $2000 car?
EJ22E rebuild, and secret O-rings
subaru360 replied to bosango's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think it is insanity to bother to rebuild an EJ22 phase 1. I can buy a complete running engine for $65 at the U pull it. I can get as many as I can haul away at that price. Maybe 1 out of 100 of them fail. I'll take those odds and price any day. I can swap one out in 2 hours, so even that isn't a valid argument. Oh and these are really tough little engines. I have a stock 100,000+ mile phase 1 EJ22 shortblock in my wrx. It makes over 300 whp, sees 22 psi almost daily and has survived a few oops at 30 psi.
Old subarus in arizona junkyard
The FF1 looked like it could have been saved.
One LONG drive
Wow, old thread. I do PA to ME pretty often also. 4 or 5 times a year, sometimes more. It's about 1100 miles for me. I can get just about 30 MPG in the WRX if I stay out of boost. I won't even mention how fast I can do the trip if I don't care about MPG. Out of state speeding tickets don't transfer to a PA license. When I lived in NJ we did NJ to Orlando FL a few times straight through. I have 3 driving trips I'd like to try someday. PA to Key west FL, PA to Alaska and PA to California. Maybe someday. I also want to try to drive the 360 to Maine.
97 OBW 5spd 2.5l to a 2.2l what years fit???
subaru360 replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll 2.5's 96-99 have EGR, 5 speed or auto doesn't matter it has one. Any 2.2 95-98 with EGR will plug in and work
95 legacy tranny no traction after flood waters
subaru360 replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's not too late I have an Outback parts car with a 5 speed and everything to convert yours.
subaru360 replied to themoneypit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 2.2 needs to be from an automatic car with an EGR valve. 95-98 will work. 95 uses the same dual port y pipe. 96-98 you need to get the matching single port y pipe.
svx in outback
subaru360 replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I'm sure. The radiator support was cut out and the radiator moved forward. There are pics on here I just don't remember where.
Legacy - rear door bolt
subaru360 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've seen those before. We just unbolted the hinge on the door side too.
svx in outback
subaru360 replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not a turbo and yes it can be done and has been. All we'll drive in NJ did one. I forget his username on here.
impreza/legacy condensors interchangeable?
subaru360 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe lines are different. If you get the matching lines it will work. The mounting holes and pins don't quite line up, but if you are creative it will work, I've done it.
WRX brake swap
subaru360 replied to allwheeldad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 99 legacy uses the same calipers as the 02 wrx. It's just different brackets and bigger rotors.
Replace 2.5 with 2.2 ? ROLL CALL
subaru360 replied to backwoodsboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've done almost 50 of them. Get one with an EGR valve. Swap the dual port y pipe with a single to match your 96 engine. Everything else is plug and play.
'99 2.5 issue question
subaru360 replied to Allpar Mod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave him replace the gaskets before sale? Parts aren't that expensive and it's not a hard job.
The tally thus far..... '96 Legacy FROM HELL
I only buy used parts for cars I plan to sell. I have a huge stash of spares and always have a few cars around to swap parts from. Most of the cars I sell are 100,000+ mile cars and the parts are from 100,000+ mile plus cars so I don't see the big deal about it. I would never put bad parts on a car, but I want to make a profit, so yeah, I would put in a good used clutch and flywheel and used axles. Used transmission is 60 bucks no core.
Where are you getting parts? Don't you have any of the U pull it junkyards? Around here I could have fixed all of that for about $300 with used parts.
which lights will light the road better
subaru360 replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe factory foglights will light the road to the sides and directly in front of the car. The hella 500 driving lights will light the road way down the road. But, you will have to turn them off if there is oncoming traffic, it will blind other drivers like highbeams. I have the hella 500 fogs, not driving, in place of the factory fogs on my wrx. This is a nice compromise, more light than stock fogs and you can leave them on all the time without blinding others. I rewired the foglight switch so I can drive with highbeams and fogs at the same time and it's perfect for back roads, but illegal in some states.
Confused on which t-belt kit I need for this '96 Legacy
96 has the old style tensioner.
Turbo Legacy Question
subaru360 replied to xoomer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorque them to 22, then 51. Back off 1/2 turn. Then 25 on the inners and 11 on the outers. Then 1/4 turn, then 1/4 turn more.
