Everything posted by subaru360
95 Lego headlights swap onto 98 Lego?
subaru360 replied to brighton98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey fit, you do have to splice in the different plug.
saving a Forester
subaru360 replied to bheinen74's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood buy. I would just fix it and flip it for about $3-4k myself.
Gasket or Sealant
subaru360 replied to Dannomanno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo gasket! Just a thin layer of silicone and the o-ring. My favorite stuff is permatex ultra copper. But any quality brand is fine too.
oil filter other than subaru
subaru360 replied to brus brother's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never seen an oil filter related problem on a subaru. I work on these cars every day. So I just buy whatever store brand filter is the cheapest.
VIDEO: Has your EJ22 smoked this much?
subaru360 replied to renob123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2 cents is rings. That's too much smoke for valve seals. Pop another EJ22 in there. They are cheap.
1996 legacy gt motor swap question??
subaru360 replied to 99gtott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut the trans in first and then the engine. You can remove/install them together, but it is 10x's harder.
1996 Legacy, bad year, valve problem ???
subaru360 replied to akm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf there was a problem, it would be known on here. There is no better source for info on older subarus.
Best New Gen Subaru for the $$?
subaru360 replied to losingalltouch's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnything with an ej22 phase 1 is a tank and pretty much runs until it rusts away. Even if it breaks, used parts for these (90-98) are dirt cheap.
98 Forester parts into 95 Legacy
subaru360 replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAll the 98 foresters I have seen had 205 70 15 tires. They do fit on a standard legacy, but it is VERY close to both the upper rear spring perch and the front of the wheel well. The seats fit. The struts fit. If you swap struts into the legacy, use the trailing arm brackets off the forester, they center the rear wheel in the wheelwell. But putting the legacy engine in the forester is a good idea as well.
What the heck is this thing?
subaru360 replied to John P's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat is the horn for the alarm system. Probably not your noise.
CAT efficiency code- suggestions for replacement?
subaru360 replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou won't be stranded by an O2 sensor, but the car can be a handful to drive, hesitating with no power. I've almost been run over trying to pull out in a car that had a bad O2. They do run with it unplugged. When it sets an O2 sensor code the computer ignores the sensor input and goes to backup fueling or what some people refer to as "limp mode".
subaru360 replied to gijoe985's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot true, I've have bad front O2 sensors cause major driveability problems. Even on obd1 cars which is what I consider old stuff. Surging at cruising speeds is common. Hesitaion from a stop happens a lot too. But anyway for the 420, aftermarket cats will NOT fix it. They don't work well enough. Factory cats will but are mega expensive, sometimes more than the car is worth. I just do the antifoulers, it works 9 times out of 10 for me.
Need some help identifying knocking sound in ej22
subaru360 replied to scrap487's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIAC is totally different. It won't work. Options- Get a phase 2 2.2 engine Use just the older shortblock if your heads are good. Get a 95+ intake manifold and 99 2.5 bulkhead harness.
Will these wheels and tires fit my 95 impreza
subaru360 replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the backspace on the wheels as well. I think the tires are too tall.
headgasket choices...
subaru360 replied to babyfacefitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'd go with a EJ22 swap and be done with it.
Impreza springs on a Legacy???
subaru360 replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't know of anyone that makes legacy wagon lowering springs, but they may be out there. I know impreza wagon springs would work better than sedan springs. Adjustable coilovers would do what you want but they are around $1000.
Any suggested on-line retailers?
subaru360 replied to AlanS's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.rockauto.com For dealer only parts I don't even bother online anymore. I just go to the local dealer. By the time you pay shipping and handling the price is about the same.
subaru360 replied to SubieDaddy80's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, but the rear of the wagon will sag badly from the additional weight over what the impreza springs were designed for.
rear main seal install
subaru360 replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should be flush.
Importing a JDM vehicle
You can't legally import jdm cars that are less than 25 years old. They do not comply with us emissions and crash test requirements. Those companies with the websites will take your money and put the car on a boat, sure. As soon as it gets it here it will be seized by customs and you get a choice, pay to send it back or have it crushed. With all that said, there are ways to get the cars here that are semi legal. These are called gray market cars. You can pay to have the car disassembled in Japan and have the body and drivetrain shipped in seperate containers. Then put it back together when it gets here. Or have it imported into Canada where they only have a 15 year rule. Some of the Canadian importers have been know to drive the car across the border for you. What you do with it after that is your business. Some states let you title and register jdm cars. Most don't. If you want a mail car just buy a rhd legacy mail wagon. They made them 90-99. There are still plenty of them around. I've bought/sold 2 of them myself.
any 2002 wrx wagon owners?
subaru360 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe wrx lines should bolt on, while the older legacy/impreza ones clip on.
subaru360 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will work if you want to use it. The only difference is the little tab for the brake hoses and abs wires.
EJ-2.2... new to such a modern motor..
subaru360 replied to Indrid cold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe EJ22T has 2 vents on top of the crankcase and the EJ22 only has one. The second one on the turbo block is a 90 degree fitting. I've owned a few of the turbo blocks and all of them had 2 crank vents and the crosshatch pattern ribbing on the block.
90 ej22 swap in 98 Outback
subaru360 replied to sparky11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have it all figured out. Your combination of parts will work.
subaru360 replied to Indrid cold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom the outside an EJ22T block will have crosshatching in the casting all over the block where an EJ22 doesn't. There is also an extra crankcase vent on the top of the block that an EJ22 doesn't have. Once the heads are off, you will see the closed deck and the difference is obvious.
