Everything posted by P K
WRX Manx..check it out
P K replied to Trader4Less's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXXLNT ! ... and the street-legal muffler goes where? It must be hella loud, but if you go fast enough, it's behind you, lol
JARED - you talkin bout the ORV in El Centro? Southwest Pics*
Glamis , baby, Glamis ! Air down and speed up.
2.2 with noisy valve train ???
P K replied to Esteban32696's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXStill could be oil pump. The HLAs might still have some air, but they should quiet after I think 2-3 hours (is that what the manual says?). Anyway, Subes like THIN oil , not 20-50 stuff. After Seafoam, Rislone, trans fluid, etc cleaning -then maybe 10-30? my $0.02 r/PK
PK can't contain himself anymore
Thanks All for the feedback. I promise I won't blaspheme it. But daaaaamn! its fun. Its raining big time here and the car schticks like glue. ("...but officer, I wasn't driving faster than was safe - the car makes it safe."
lift is done... now I can't shift!
Usually, the only shift difficulties come with the 4/3 kit. I haven't had feedback about the EA82s and that problem, but none the less, often with the kits the shift boot hampers movement and sometimes the boot hole requires some hammering just a wee bit to allow the shift rod full movement. Other have like Hatchmonster, heated and bent the shift rod a bit to do the same. I can call you and discuss. r/ PK
I agree, lift and rally dont go together. I want to run fast on the dunes and dirt roads, and the minimal ground clearance scares me. I figure 2 inches is enough to get some more wheel travel (one inch body and one inch strut lift). BYB Brett's in OZ has a 3-inch lift with 28" tires: A little more than I want, but I want more than stock. I am always open for suggestions and opinions. Besides, I am in the business thanks, PK
I wont beat her up, just want to get her airborne without too much worry. Legacy Lift kit - The Legacy lift is not what I wanted as it sits: that is - it is a body lift of 3-4 inches, HOWEVER, in doing it the usual way, there is no room to add larger tires because of the strut coil in the way, above the tire. The solution is to buy Outback front struts ($300 pair) and Legacy 2WD rear struts ($130 pair), which both have the lower coil perch about 2 inches higher, thus allowing 4 inch taller tires. (stock are 24.? inches, so then 28" tires are possible). Unfortunately, the lift kit portion will still cost $400+ , so the total lift package = $830+, plus more costly shipping. Secondly, the kits are different between the years- 1990 vs 1992 etc. It's really turning into a logistics problem. For me, I figure I can just lift her 2 inches and go just one size bigger on tires. For those who want lift and big tires - right now I dunno .
Allright, I can't keep it secret till WCSS7. 93 AWD Turbo Touring Sedan 5 speed 'Tis the shiznit Planned: IC, Man boost controller, 2-inch lift, beefy rally tires.
Which Cars came with the "good" EJ22 motor
P K replied to mtsfabman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPre 1996 I believe - you want the two-port SOHC 2.2 EJ-22E motor. The later 2.2 SOHC is a single port, which Subaru later bored to 2.5 as the newer motors. Of course the EJ22T - ahhhhh....
crank t bars up
Remove rubber plug under rear seat. Will be one adjustable bolt. Use socket with extension. Best to first wd-40 the threads from the underside if rusty, then jack vehicle up to help lessen tension and adjust. r/PK (I just used 'wd-40' as a verb)
Halfway
Ah, the Liberators - XLNT!
Halfway
Nice tires on 14" Pugs - what size?
Knocking Legacy Turbo
P K replied to dave.marchment's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds maybe like an Air Cond compressor problem... it's usually on for AC and defrost on most cars. AC compressor will knock with too much freon in it too. Others opinions?
Aluminum BYB / PK lift
Good pic - thanks. Yeah, box and parts weigh 55-60 lbs. That cardboard and paper packing must be pushing 2 lbs. Actually the solid aluminum kit is on average 7-10 lbs heavier than the plated box steel kit... then there's the aluminum's cost - ouch. Future kits will most likely be a blend of plated steel (white zinc to match) and aluminum blocks to lose some weight and expense. r/ PK
Rarity of D/R AWD
P K replied to WoodsWagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is my understanding, and I have seen spec sheets, that the dual range is 1.19:1 ratio much like the old RX, versus the 1.52:1 ratio in the EA82. Might be great if one puts on larger tires, then wanted to get back to original gearing driving in the lower range, but I think its a costly mod for that. Can one run 24/7 in low range? Just my $0.02. r/PK.
i found the 4 inch lift kits
Hi Cody, I just replied with details. Timeframe is definitely shortened, LOL. thanks, PK.
John Mudrat - Adapter or others with answers
Still contimplating the EJ to EA adapter. As you know, I was going the reverse, that is, putting the EA82 5 speed dual-range behind the EJ22 in my Legacy. 1. In trying this, I need to know if I have to buy and use EA axles, meaning 4-lug wheels in front? Or will the EA axles work with my Legacy front discs? Certainly my EJ axles wont mesh in the EA82 trans will they? 2. Legacy 5 speed (current) and EA82 5 speed D/R (proposed) might be different lengths, so now I need to modify my driveshaft? Hopefully not having to lengthen it - argh? Anyone with answers appreciated, thank you. r/PK.
Early legacy AWD 5-speed???
P K replied to Frank B's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRatty2Austin - how much for the AWD 5 speed, and is it shippable? Is the main shaft bearing fine? thanks, PK ... or, has anyone replaced the main bearing - I understand you have to split the trans open.
PKmobile won't start!!!! Fuel Pump fuse/relay?
On my Brat the fuse blew in the engine bay - fusable link?. Replaced and it kept blowing everytime I tried to start it. Turned out to be the alternator was shorted (or regulator inside ). Dunno?
I think it's a total. Maybe you should sell it back to me. Sorry to hear, Dave. So it 's no electrical to the pump? Somewhere I read that Sube's fuel pump get their voltage form the voltage regulator - check those connectors and/or relay. Good luck. r/PK
Hey PK............
Hey Tim, I will get to my emails tonight... all my emails, everyone r/PK
Who hoo! Partys on!
Thanks for info guys, the 1/8" has been corrected. As far as the corners on the front blocks, it's hit or miss (pun) on EA81 or EA82. Sorry for inconvenience - thankfully, aluminum is easily filed/cut/modified. Nonetheless - I have now moved to round blocks for those - no worries. r/PK.
Wanna know why I named my new hatch "Ozy"?
Hey Brian, actually you missed the earlier post. Now there's two of us with too much mental investment in Subes that STATE GOVERNMENTS know about, LOL. That's the 2nd neatest plate I 've ever seen, here's the first: Actually, I like the Washington plate better with its graphic background Get one in Oregon, and we'll have a threesome at WCSS7 p.s. Brian, get your t-shirts? r/ PK
lift is done
Hi Ratelo, I'm sorry, but that name is not familiar. Where did you get this BYB kit?... different name? The steering should be a T-bar unless you have power steering, then it is a double u-joint. 4-inch front and 3-inch rear is correct, with the rear torsion as Rooinator says adjusts to desired stance. r/ PK
Don't hate me cuz I'm beautiful (new better photos added)
What a beauty! Where do you keep finding these? I reckon you got the parts all okay, except the one in due 5-6 weeks, eh? ... very, very nice - I'm sure it'll get dirty, but don't bend it . r/PK
