Everything posted by EVOthis
Sorry to hear your luck...We had a similar problem kind of a while back...someone brought I believe an 05 Legacy GT in and complained of the turbo glowing red...This specific customer had a turbo-back exhaust...we tried and tried to duplicate the problem and checked over the vehicle thoroughly AF ratio's and everything...however we could not duplicate the problem...sent the customer on there way and a few weeks later comes back with a rod knock...I have no idea if the two instances where related but we ended up installing a new short block and havent seen the customer since (knock on wood)...Doesnt really sound like the same problem/luck your having but I thought I would be good to know that others have problems with there newer vehicles also....(Ive also seen 09 foresters and tribecas have internal engine failure)
All I can say about this tire question is...If your looking for good wet/snowy weather traction DONT BUY KUMHOS..I have them on my Legacy and even in like a couple inches of snow I still slip all over the place....I will however recommend some bridgestone blizzaks for decent snowy weather traction...
http://cgi.ebay.com/ebaymotors/1996-Subaru-Legacy-4X4-EXCELLENT-CONDITION-NO-RESERVE_W0QQitemZ320367625986QQcmdZViewItemQQptZUS_Cars_Trucks?hash=item4a97660702&_trksid=p4506.c0.m245&_trkparms=72%3A317|65%3A12|39%3A1|240%3A1318 Quickest way i know how to find a pic. of the air intake... You should prob be ok using some T adapters however the one huge air line for the IAC I would prob. route straight to the intake tube...
I have seen a couple...I have actually had customer complaints about a shimmy more than a noise....and It turned out they needed a wheel bearing...sometimes withe the car in the air even when you dont hear anything...grab the tire at 12 and 6 and than again at 9 and 3...if you notice excessive play in both directions chances are the wheel bearings gave out....you could also tighten the axle nut....if the play dissapears chances are youve got a bad wheel bearing... my 96 Legacy had this problem...I didnt hear anything and was just prodding around one day and I had what I described...excessive play and no noise...Its obviously more common though to hear them going bad..
could be another heat shield...with age/mileage those things tend to loosen up...quick fix if you dont want to remove them is get some self tapping screws and screw them into the loose heat shield at random points just about 3 or 4 turnsafter the screw makes contact with the exhaust pipe=tension...should keep it from rattling... If this noise sounds the same as the other heat shield did and it went away after removal of the heat shield than 9/10 its another heat shield...
Wow...this is news to me...every single tech (including our senior master tech) where I work puts the conventional white bottle of ATF in every 4EAT we do flushes on (thousands of them) and have NEVER had a problem...Quite Obviously you can put the ATF HP in the 4EAT's however I dont see a problem using the the reg. ATF plus its much cheaper...I know they changed the coolant to the super blue long life coolant in the 08 STI and all 09 models...
Ej20t
EVOthis replied to fuentearriba's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
come on man...02-03 WRX had the EJ20's Turboed of course... -
has anyone replaced the air filter or had the air box off recently?...We have these complaints every week or so...people dont install the air box lid properly so it never latches down...and on acceleration you get like a deep growling noise...I would make sure that your airbox is tight first....before we go digging...lol
Its pretty common for these systems to leak a little around the line fittings where the o-rings are...sometimes you can take some soapy water and spray a little there and you will get a little bit of bubbling...Personally Im not one for the little can with the low psi. side gauge....How do you monitor the high side when using one of these?...you cant...unless or course you have a set of manifold AC gauges...
