Everything posted by EVOthis
i think the best bang of the buck are Kumho's I have them wrapped around 17's on my legacy.....however kumho's are horriable for traction in wet weather( my experience). So i have bridgestone blizzaks for the winter on my steelies....i find it really helpful to read like consumer reports and such.....got to Tirerack.com they have an excellant selection and not bad prices......
IAC Valve?
EVOthis replied to EVOthis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
ah thanks......ill try it again tomarrow after work..... -
IAC Valve?
ok....so i got some seafoam today along with some TB cleaner....i go under the hood, just undo the air box (didnt remove it) and undid the hose to the IAC....almost immediately the car stalled.....i tried it like 4 or 5 more times again almost immediately stalled.......what is this telling me about my IAC......tomarrow i will get my buddy just to hold some gas on while i spray the cleaners through it.....just wondering if this means anything?..... -
IAC Valve?
thanks for the tip....i was told to test the MAF....you run the engine and just tap on the MAF with like a screwdriver and if you car stumbles or stalls than your MAF is bad and if it doesnt do that than the MAF is fine..... -
IAC Valve?
thanks a bunch porc....before i go digging around in the junkyard ill try and give her a good cleaning tomarrow...(not trying to spend any more money than i have too)....appreciate the help as always...... -
IAC Valve?
so just pull the hose off the intake that goes to the IAC, spray some seafoam in there while the car is running, let it idle a few minutes, than spray some throttle body cleaner in there? you mean i dont have to take the whole IAC off? -
IAC Valve?
thanks porc. its a very complex like low idle intermitent...unexplainable you have to see it kind of deal...i made a post on it a while back but i dont even think i got one reply.......nonetheless......i believe it is sticking open or closed a little bit.........if i do remove the valve to clean it how important is it that i get a new gasket? ( i really dont want to make a trip if i dont have to)....also how exactly do you clean it?.....thanks for the help -
Ok ive got a 96' legacy ej22 with a 5 spd....i know ( or at least i think) that the IAC Valve on the 1.8 and the 2.5 engines are part of the throttle body....my question is....are there any differences on the 2.2 liter engines.....ex : could i swap an IAC from any other year 2.2 liter and put it on my 2.2?.....im making a junkyard run tomarrow and just trying to get some advice..... ( dont feel like paying $350 for a new IAC from the dealer......thanks in advance.....
be careful man....thats what my subarus previous owner did with my subaru and it messed them up bad....started bottoming out the struts and every time I turned the steering wheel or went over a bump the spring would pop off the perch and rub against the tire..... I ended up drilling through the strut perch and putting about 7 or 8 industrial stregth zip ties on there....I eventually replaced the springs and struts.....the springs i bought were not specifically made for my model year and they worked great for me... .....if its your beater car great...but i would not recommened cutting your spings.....good luck though with whatever you decide to do.....
