Everything posted by AWD TURBO!
[attach]7281[/attach] this help:)
35" what is the biggest lift that has Ben dun?
Overheating and no heat issues... please help!
AWD TURBO! replied to emarsh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
.... http://www.ultimatesubaru.org/forum/showthread.php?t=66707 -
you still got my jump box
you would think so but he does not think its the leaking radiator lol -
did you try? yes the actual bleeder is the cap you start your car & run it with out the cap on add coolant don't put the cap on tell you stick your finger in the coolant & it is HOT & looks like it is flowing... -
do you have pictures of your GM 100a alternator in your ea82 Subaru?
well i know ware not to grind now good picks
OK so its in the teens do you have something in front of the rater to keep the car worm so the thrums stat stays open at temp? if its too cold out the water in the radiator is getting too cold making the stat closed! moter is hot! water is ice cold make since? -
[ATTACH]7264[/ATTACH] this looks cool
really like your hi\lo lever think I'm going to do the same.
I'm out 2 gear went out unless i can find a full time 4wd hi lo with the diff lock in time
TDO4 or TDO5 on my EA 82 T ?
AWD TURBO! replied to Steve W.'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
TDO4 just fished mine & love it -
with me having the boost gauge connected I'm doing 14 psi max & 12 on the dot no fluctuating. going to put it back on the intake i will have vac
yes its the boost gauge i just wanted to know what psi was off the turbo was
