Everything posted by subyrally
TD04 headcount
one of these days, ill get my old engine rebuilt with new parts and then ill get some head work done and then hopefully get my turbo back from my friend. i hope he gets done with it soon.
Lifted Justy
almost makes me want to get a justy. granted, id lower it and drop in a turboed engine and awd drivetrain.i go rally with it.
B9 TRIBECA... and other things... discuss...
subyrally replied to Zefy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthink as the 92x as theluxury wrx, its a rather nice car to be honest. i was just looking at some tonight when i went to the dealer with my friend (he drives a chevy s-10). to be honest, i cant wait till the b9 roadster comes out,even if it is a hybrid. just imagine a awd roadster with the sti engine and drivetrain.its gunna be hot.
Whats next?
us financially challenged folks should get together and figure out every inexpensive power adder and performance mod for these cars and start a list or write a book, then we could make some moneys. hmmm, the grand book of elcheapo suby improvements.
Subaru Operetta
if you ever find the book "impreza", there is a picture and some info on the car about halfway through the book. id scan it if i could find the cables for my scanner. it was a decent looking impreza, but i think it could have been done a bit better.
EA82T Transplant?
all you really need is the ditsy plug, find one with the same plug as your harness, then there are two screws on the bottom, un screw em and pull the plug out the bottom of the ditsy, do the same on your ditsy andswap the plugs. i had to do that like 4 times in three months. hope that helps/
WHOA! Susquehanna urethane mudflaps are STRONG!
sooo, anyone want to hook me up with two sets? one for the impreza and one for the rx.
GL pulls to left...??
the axle can be dead even if there isnt a bad boot, the boot coulda been replaced when the axle should have been tossed alltogether.
window banners
i beleave they would be exterior style. i never noticed that link you have there, shows how much attention i pay to the little things.but either way, ill be getting one from the guy i know, he will make em to fit the windows, front and rear.
window banners
i might be able to get some window banners made to fit the old school subies, mainly the sedans. the guy that makes the stuff is a friend of my friend's parents. i think he does it as a home business or something like that. if there is any interest in this he might be willing to make em. i thik he said something like $30 for the front and rear banners, im guessing solid with "subaru" across em. and possibly the old school logo on each side.
Volvo intercooler
one could posibly do it like subarubrat did his radiator, attach it to the hood some how. then cut out above it and mount vents or louvers to direct air flow down into the hood or pull air out the hood. just a thought though, i might snag one if i go to the yard today.
How much power can EA82T stand?
the heads might crack even without the turbo, but the majority of the cracks are in #3, which is where the turbo sits, thus is the hottsest exterior part other than the exhaust ports. if the turbo was on the driver side, we be talking about issues with #4 having cracks. oil coolers and intercoolers will help to make a difference, but only to a certain point. but every little bit helps.
ok, i had to chime in, the subaru factory rx rally car in the 80's was in the ballpark of 250 hp and reliable, but obviosly not stock. this i learned from a guy thats been doing racing and work on subarus since the 70's. the guy also has one of the nicest svx's ive seen in a while. the crack in the heads on #3 is from the added heat of the turbo almost sitting ontop of it. wrx's have been having the same issue since they were release in the us. if the turbo was moved about two inches toward the back of the engine bay, and then insulated from the engine, i think that there would be a lot less trouble with the #3 cylinder.
Unknown source of coolant leak.
i have a simular isse, but my leak is on top of the block. i thinki9 mine be the manifold gaskets or a loose hose. and the waterpump.
Interesting things i found tonight
that will be sweet. cant wait to see the pics.
No Photoshop This time... now the grill.
dude, sweet. i was thinking about s=doing that, but i dont have the brackets to mount the grill on my rx. im prett sure that hte core support wherre the brackets are meant to be isnt the original one from this car.
Subaru VS. ELk
thatll buff out. glad your ok, looks almost like the damage when i hit a deer in my impreza.
87+ Fuel Cut Solution
shell is 86, wiring is 87+
i just bypassed the boost sensor on my rx, never got boost but when it was running right. granted that only lasted a couple weeks.
2 issues...
hey will, do you have the boost controller still hooked up to the compressor side of the turbo? on mie, i have it still wired up but not connected to the turbo, just a hose going from the compressor to the waist gate. no boost cut and it still works properly.
I usually dont do "sighted" threads but...
ive driven a few rhd cars, including a legacy and bmw. parking is easier as is shifting. i want a rhd car.
Oil in the air filter?
sounds like my rx. i just put in a new engine cause i cant get ahold of new rings for the first engine i had.
Anyone have a busted motor for me?
i have an engine located in frederick maryland, but i want to keep it for a project as well. i am thinking of having it built up to something special. if i can find some way to pay for it.
Direct Fit coilovers inside...
ooowowwwwwwyy, my wallet hurts. just looking at those
2.1l Ea82t
thts drinking, not thinkig
