Everything posted by THAWA
what did you have to do to get the wrx muffler to fit? was it bolt on? did you need to get it welded? Was it long enough to meet the midpipe? Just how short are the tips when looking at the car compared to stock? I did some measurements and t looked like the wrx muffler is about an inch shorter or so. Do all the hangers line up, or id you have to change them?
200,000 Miles!
THAWA replied to MailManX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
congrats! -
I wasnt aware morette made a kit for the 00-04 legacy's/outback's also as I understand it, the morette kits are the 90mm hella modules. Assuming they use the ECE code lights that's more than 100 bucks each light or 400 for the whole set. Not to mention it's already moulded to the design of the grill/bumper/hood/cornerlights. 450 sounds like a steal to me
you don't need to worry about a clutch that disconnects the transmission from the engine no, but there is a clutch pack you need to worry about. Your best bet with the tranny is to first and foremost install an auxiliary ATF cooler. 4eats main enemy is heat. Secondly, change the EXTERNAL filter only, the internal filter is never meant to be replaced. And finally Keep up on the transmission services, this is as important if not more than installing an aux ATf cooler.
seriously be glad you bought the subaru and not some other thing like a honda or toyota or something that couldnt handle these kinds of conditions. If you really want the car to last long enough, make sure you do all the manufacturer recommendations on time, and do every single one of them. You should start saving now for headgasket replacement, and honestly you should do it now before they blow on ya.
