Everything posted by Mike104
Buy wheel bearing from dealer expecting Koyo, get NTN
Mike104 replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep learned that one the hard way too!
Solenoid? Intermittent starting problem.
Mike104 replied to washwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the voltage at the small wire on the starter when cranked.
96 legacy manual swap
Mike104 replied to Jaysus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGetting another car is likely the easiest option. Best to buy a whole car to swap parts from. Try www.car-part.com to see what years/models are compatible.
Forester rear end noise
Mike104 replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it get more noticeable above a certain speed? Usually wheel bearings start making noise about 30-40mph (at least mine did). Apparently the Right Rear is the worse culprit on that model era. (I've changed 3 of 4 on my '03 Forester)
Inspection Hurdle
Mike104 replied to stackman1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may already know this (readiness monitors not set) https://dmv.ny.gov/brochure/what-do-you-mean-my-cars-not-ready
Inspection Hurdle
Mike104 replied to stackman1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrom another post Subaru recommends the following conditions and drive cycle to get the monitors on its vehicles completed in the shortest amount of time: 1. Make sure the fuel tank is between one-quarter and three-quarters full; half a tank is ideal. 2. Start the engine and immediately drive the vehicle for at least 15 minutes at a speed greater than 50 mph. During the warmup, try to avoid sudden acceleration, hard braking and/or lane changes. 3. Drive the vehicle at a steady 55 mph for three more minutes. During this stage of the drive cycle, it's crucial that you keep throttle angle changes to a minimum. 4. Bring the vehicle hack to the shop, hook up the scan tool and look at the status of the readiness monitors. Repeat the drive cycle, if necessary.
Replace Joint or Axel?
Mike104 replied to potter2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad I don't still live in SLC
Replace 2.5 HG prophylactically ie before failure
Mike104 replied to hugho's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Later 2000+ EJ25's are better as they usually don't randomly overheat but leak extenerally so they're easy to plan ahead for a repair and not get stranded. so they're a better option for reliable, long term, high mileage commuting." Especially if you routinely check the oil and radiator for coolant level!
Broken a/c belt tensioner
Mike104 replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe it is still plastic. Many don't loosen the nut that holds the pulley before trying to adjust the long bolt and snap the plastic bits. My dealer stocks them. Dorman kit is a good option. I take that back, since they say parts are powder coated the adjuster may be metal
96 legacy L . Brake fluid leaking
Mike104 replied to Jaysus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasy fix
PLEASE HELP NOT TRYING TO SPEND $1200
Mike104 replied to 2011sublegacy2.5's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo the takeaway is to buy two extra keys when you get one of these types of cars with the immoblizers? What year did this become standard?
Mike104 replied to Jaysus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour turn signals could be the fuse (but I think the same fuse is for the turn signals/parking lights?) or the flasher.
Cruise Control Not Working
Mike104 replied to btrentel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for using it!
Idle Question on 1993 Impreza
Mike104 replied to Subasaurus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a reverse switch and a Neutral switch. Both are on the side of the MT. I seem to recall that the switches have different colored connectors but can't recall which one is which color. It's the rear one https://parts.subaru.com/a/Subaru__/49242870__6027485/MT--REAR-CASE/B11-120-01.html
Mike104 replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah that made me buy new stuff to have on hand and I needed it all. I don't have a lift or air compressor so I definitely was glad to have seen how bad it could be. Hand tools were not going to get mine apart.
dash lights flashing gauges bouncing car hesitating surging - Alternator?
Mike104 replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAuto parts store alternators are not that good. A used Subaru one is often better.
oil changes
Mike104 replied to garspeelin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUsed to do that on airplane spark plug changes on small piston powered aircraft. Now we just toss the $1,000 +igniter with the gasket in the trash for jet engines. http://www.skygeek.com/champion-ch34630-igniter.html?utm_source=googlebase&utm_medium=shoppingengine&utm_content=champion-ch34630-igniter&utm_campaign=froogle&gclid=EAIaIQobChMIpMmG-rCF2QIVj4zICh2tewouEAkYCSABEgLD6fD_BwE
Opening a 2013 Outback Gas Door in an Ice Storm
Mike104 replied to bdavis811's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could always spray some silicone spray on the edge of the door or even car wax would help. The ice remover spray works great too.
Mike104 replied to LeolaPA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust make sure you push the bearing out in the correct direction. An electric or pneumatic impact makes this job much easier!
Oil Consumption 14 Forester
Mike104 replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe short and sweet version above by GD. Here is the long version https://subaru.oemdtc.com/80/engine-oil-consumption-2013-2015-subaru/4
Outback
Mike104 replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAccording to this guy it was pre 2010 for the Outback https://allwheeldriveauto.com/subaru-head-gasket-repair/ Main problem with these is that some get overheated multiple times and eventually have rod knock, usually after spending a bunch of $$$ or time replacing head gaskets. If it was an SOHC engine it may be an external leak (oil or coolant). The EJ25D (DOHC) engines were prone to exhaust leaks into the cooling system. Best gasket to use is the Turbo one 11044AA770 from Subaru, its a Multi-Layer Steel gasket.
04 Outback Cranks, fires, sputters, dies, bad communication with ECM
Mike104 replied to mikeamondo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's misfiring I would suspect plugs/wires/coil rather than an ECU but that's just my uneducated opinion
Loud Power Steering Pump
Mike104 replied to Naked Buell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe O-Ring PN for the Elbow fitting is 34439FG000 https://parts.subaru.com/a/Subaru_2007_Impreza-Sedan-25L-AT-4WD/_54100_6027967/OIL-PUMP-PUMP-04MY-/G11-348-05.html You may be able to remove the O-ring and take it to a parts store to match it rather than buying the $2 part from Subaru
No spark on 2005 Forester sometimes
Mike104 replied to Chaid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubies prefer OEM coils and NGK wires (not Durac*ap parts). If its having trouble starting in cold weather it could be your coolant temp sensor since that adds fuel when its a cold start Could also be a slipped timing belt (was your timing belt service done at 105k miles?) That's just my uneducated opinion.
Records Keeping
Mike104 replied to sadarahu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPretty much a state by state thing. You can deduct those taxes on your IRS tax return. According to the IRS (IIRC) they can go back 7 years to audit your return. I believe if they can prove intentional tax avoidance they can go back forever.
