Everything posted by Mike104
Best head gaskets
Mike104 replied to iriejedi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX11044AA642 is the Multi Layer Steel gasket for the Non Turbo EJ25 motor 11044AA770 is the Multi Layer Steel gasket for the Turbo EJ25 motor Installed properly these will be best option.
Power Steering Clamp "Things"
Mike104 replied to potter2010's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat year Forester? Do you mean this O-ring This Clamp? Just use a pair of slip-joint pliers
trim ring bezel around ac controls/vent 1996 impreza outback wagon
Mike104 replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.parts.subaru.com says 93-96 Impreza's used that panel. You could check www.car-part.com or ebay for a replacement 66220FA020EM 66220FA020MJ
O2 sensor questions 03 forester
Mike104 replied to nicksubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPage 6 and 7 give troubleshooting procedure for P0032 Diagnostic Procedure with Diagnostic Trouble Code (DTC).pdf
Head Gasket leaking coolant & Oil
Mike104 replied to Colec533's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf I recall the specified head gasket for that MY is a 11044AA633 that is a Non-MLS gasket (bad choice) Normally aspirated MLS gasket for that MY is 11044AA642 Turbo charged engine MLS Gasket is 11044AA770 Many use the turbo gasket (770) instead of the 642 for normally aspirated (non turbo charged) engines.
Mike104 replied to Colec533's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you change the head gaskets, do a complete timing belt service while you are there
Will 99 2.2 impreza L swap into a 2003 Forester?
Mike104 replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may also have to swap the Crankshaft gear and Drivers side Cam Gear from the Forester, if they have different timing triggers
Manual Transmission Replacement Compatibility
Mike104 replied to VancouverMike's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo to www.car-part.com and they will tell you what transmissions will work
1996 impreza outback wagon luggage rack
Mike104 replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTorx is standard and once loose the cross bars just lift or pull out
EJ20 Head trouble
Mike104 replied to Bdamit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBest timing belts are Mitsuboshi
Mike104 replied to nicksubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFront sensor is an Air/Fuel sensor. Rear one monitors the efficiency of the catalytic converter
Identify my drive shaft
Mike104 replied to Smo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes the blue wrench is what is needed
Mike104 replied to nicksubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPost the two codes here for better assistance.
Engine Oil Consumption
Mike104 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLots of Subaru's on my Craigslist with bad engines, usually spun bearings/rod knock/hole in case probably from low oil. Most are post 2005 so easy engine swaps aren't an option. A short block from Subaru is a good option but when you consider the asking price + repairs, not a viable option for a flip to make a few dollars. May be an option if you could do it yourself and keep the car as a daily driver.
I'm sure it's the wheel bearing
Mike104 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you live on salted roads it can be a bear. Some use this tool to help separate the bearing assembly out of the knuckle
Engine replacement Question (Forester 2007)
Mike104 replied to iandra's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com is the best option to find compatible engines. Your local pull and pay can tell you what vehicles they have that may work. Do your homework first and then go to the pull and pay yard or a contact a local wrecker to see what they can provide.
- 2 replies
- forester
- subaru
- engine
- replacement
Tagged with:
Outback Transmission Swap
Mike104 replied to fatboy_dan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have a lift the transmission removal is usually done without removing the engine. No lift usually means removing the engine as said above I don't know for certain if the 6 speed is a suitable replacement option.
95 EJ22 to EJ251 swap
Mike104 replied to punx2400's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEJ25D is the DOHC engine
2001 Outback Legacy engine lower dam
Mike104 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI took mine off my 03 Forester (fire hazard due to oil soaked pad) when I got it three or four years ago. No issues noted
Rod-knock on 2013 WRX... HELP!
Mike104 replied to Dustin06's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad it's not still under warranty. The local dealer here seems to get overrun with blown BRZ/WRX engines to replace under warranty. Sadly many of them are tuned and had after market equipment on them (both which void the warranty). They remove all of the items before going to the dealer (hard to believe a car with 30k+ miles only has 9 key starts). Since you have already been to a dealer I expect you won't be able to try a warranty claim anywhere else (3yr/36,000 miles?). Definitely get GD to install a rebuilt block (or an upgraded one). He will be less expensive and give you quality work. I guess the issue is getting funding but I don't have any suggestions (creditcard/bank/parents?)
Determining ignition coil of swapped engine
Mike104 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know one difference is that some have a three wire plug and some have a four wire plug (that bit me a couple of times before).
1998 Legacy rear outer joint spins but axle shaft does not
Mike104 replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLateral link bolt needs to come out to get the axle out (or at least it did on my 99 OBW). On my 03 Forester I changed the rear diff and the axles will come out by dropping the rear diff if the lateral link bolt is seized in place
Head gasket potential issue
Mike104 replied to coryl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX11044AA642 is the MLS non-turbo Head Gasket 11044AA770 is the MLS turbo Head Gasket. Those are Subaru part numbers. I believe the original non-MLS gasket was 11044AA633 that was prone to failure.
Mike104 replied to coryl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think is a potential problem by retorquing them.
What’s happening?!?!
Mike104 replied to TJBlanton's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a 2018 take it to the dealer for warranty fix
