Everything posted by stealth
My New 1979 DL Wagon Front Wheel Drive Automatic (lots of pics)
Super Tidy!
- Betty - 1978 4wd wagon
Hi from New Zealand
Hi Sqaure eyes, there is a local forum and depending what city you live in (close to) someone will be able to help you, http://clubsub.org.nz/forum/forum.php
I have seen an early suby wagon showcar, i believe it was yellow, anyone know whos it is or got any links? TIA
- 1978 Subaru Brat
- Trip Report: Walhalla, Victoria, Australia April 2014 *Loads of pics!*
My New Wheeler Project.....Butters.......... **updated pics**
Do you have any pics of how the front got tied together?
Metal heater pipe worn thru on 88 leone
legend! also is it cold there?
Ea82 dash clock ipod upgrade! Now with pics!!!!
yeah do a write up, id be keen to have a crack at this myself.
ok so today i started removing the intake manifold, after thinking twice, (before seeing your post) but am struggling to get the AC unit out of the road, there must be some secret bolt, can anyone please advise? Im also thinking of getting rid of the AC unit, is it just a simple case of removing the unit, leaving the bracket for the alternator, and sourcing a shorter belt, or more involved? thanks
fireback.
Could be the distributer not in the right place or leads?
help, I want to install on my subaru brat ej20t
Use the search, will prolly get lots of info.
Cheers Loyale 2.7 Turbo, your pics made it very easy for me to see whats happening under all the carby and pipework, but basically the metal water pipe that comes from the intake manifold (to the heater pipe) has completely rusted away, and most of the pipe where it joins the heater is also rusted away, altho i think i can get a hose on to the heater end. The main reason i want to bypass the waterjacket in the manifold is because im lazy, I have talked to others about this and it may cause problems with the auto choke? Can you think of any other issues i may have? thanks
Alrighty so i stripped it back a bit and the rubber hose comes from the carby, as the rusted hose going from the heater pipe still has a wee bit left on it i thouhgt if i take the hose off and replace it with a little bit longer one i will be ok, so i took it off the carby end and what do you know it is completely rusted thro with nothing able to be attached! Damn it! So a few questions i have: Can I bypass the carby? And what kind of affect will it have?
thanks MilesFox Is it connected via another rubber hose...ill be pulling it apart tonight...
My new score :) and a couple issues....
vac lines is where id start, get a can of brake clean and spray it around the engine and see if idle note changes... (should idle down)
Does anyone have a pic of a semi stripped down motor so i could see where heater piping goes under the carby, thanks
do and document it well so i can cheat, looks pretty tidy too, at least compared to my hack
The pipe on mine has a wee 90 deg bend with another pipe coming out, and the corner of this pipe has rusted away. its connected to a hose at the end i can see, im wondering if its attached by hose or if its pressed into the block, sorta the reason why i posted up here, hoping someone will know..(of couse they will!!!)
Howdy guys I have just noticed my leone is leaking water, quick pop of the bonnet reveals there is water spraying out from a metal Y join on the heater pipe (just behind carby). As it is dark outside, im wondering if this part is easily removable for repairs, i have tried searching for pics and info online as i expeted this to be a common problem, has this happened to you before and how did you fix it? thanks in advance
Lifted Legacy gets taller!
rocker cover gaskets or the wee seals around the bolts for the rocker cover?
- moved
- Subaru "Harvester"
Question for our kiwi contributers
if i remember i will check with southland business' i deal with on Monday (thats if the snow stop to allow me to go to work - Woot!) someone could also run the plates...
Red Sedan Build , solid rear axle
I cant believe i havent seen this b4, but WOW!!! just blew my mind (in regards to sideways motor and box!!!)
