Subruise
Everything posted by Subruise
  1. depends on how you do it, you need to keep the pinion shaft with the ring gear and outer seals. youd know this if you could read.
  2. if you dont wanna look you have no business wanting to know anything, just pay someone to do it for you. dont waste peoples time due to your own complacency, its rude.
  3. use the search function next time please, http://www.ultimatesubaru.org/forum/topic/63821-pics-of-lsd-conversion/...or look in the USRM....
  4. good question Ivan, ive got parts off a gen 2 79 wagon with a ea71...fenders, bumper. somehow i feel this one is a gen 1, even though i have no reason to.
  5. if it smells like fuel or exhaust (ie not sweet, like antifreeze) you may have an issue. did you use a dealer tstat? are you sure your tb seal is working?
  6. smell your coolant....you may have bad hgs
  7. next weekend, if not 3 weeks from now. sorry for fallin through.
  8. get some steelies off a 91 mitsubishi montero, trapezoid holes. mine are perfect for a 2". stock offset, too narrow now that the 4" is on there though
  9. raped apes run differently depending on whats chasing them
  10. hit the "local" spot a couple times since the 4" and lsd went on. looking forward to more
  11. the bottom line is, has been, and always will be flow. those heads do not and cannot put up with the cfm needed to produce power. Tallonx: this is only the hundredth or so time this EXACT topic has been covered, and by linking something, you are suggesting it. unless you say otherwise whilst posting it. By the time Subaru/FHI got around to fixing the head flow issue among all the other performance inhibiting factors of ea series engines.....guess what? they had ejs. no one is being a douche, theyre right. cool your jets and go brush up on math and hydrodynamics
  12. on paper, a 91 festiva is the same as an original mini cooper. but they arent the same car
  13. i believe another member and i may be able to pull it this weekend
  14. not unless you make 400 a day. call a limo to shuttle you around all day, itll still be cheaper
  15. get some belts and fix it yourself. youll save hundreds. with a little maintenance its a cheap car to own.
  16. Im near Tacoma if that helps. Ive got lotsa parts
  17. search for loyale blower fan resistor pack
  18. you can use an outback xmember on an l series?
  19. go 2". research first
  20. On our 86 wagon the screws holding the rods from the latch to the handles were stripped, allowing the whole thing to "bend" instead of --- it would v ....someone else had been in there and made the screws unremovable. solution: big fat ziptie on the joint so theres no flex. this was the third time (and last hopefully) Ive tried to solve that problem. hth
  21. Im about 8 minutes from PLU. ill be home pretty much all day. Give me a call, I can get that thing to quit bleeding. 253 678 6137, Rob.
  22. valve covers(and grommets), cam towers, OIL PUMP is a usual deal. where at in the pnw are ya? ifn you can get here i can help (in person)
