86subaru
Everything posted by 86subaru
Filters?
86subaru replied to derekho55's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
fram is made very cheap and are junk also stp -
Filters?
wix, bosh, mobile 1 , oem, -
cross country trip, need emergency contact info.
86subaru replied to operose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i sent you a private message with my phone # , i am in western ,ohio , right along I-75 , 100 miles south of toledo ,ohio, [ ANNA,OHIO] give me a call if you are going this way and stop on by , july 30th and aug 1st i will be gone -
cleaned IAC ,WILL NOT STAY RUNNING
86subaru replied to 86subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no coolant leak etc.. , seems the other iac was bad , but still back to the same problem as before i started -
AC belt on an EA 82 question ...
86subaru replied to FlyB0y's topic in Old Gen.: 80's GL/DL/XT/Loyales...
make sure the parts store is looking up for the right size motor , there should be adjustment left after you put the new belt on -
this i what i did , the problem may have been is i used another one ,that looked good and cleaned it good , put it on and no go , sooooo i cleaned the old one and put it back on , still idles like before , but aleast i can drive it :-\the other iac was from a same year car ? either it is bad or something else -
bump:banghead: -
cleaned the IAC and now car will not stay running ? it is a 88 spfi 5sp d/r wagon,all vacuum lines hooked up ,all wires pluged in , it runs good as long as you hold the gas pedal down
idle problem w/88 spfi wagon
got it ,thanks skip and everyone else -
thanks skip ,did a search did not find cleaning , -
anyone heard of acetone in the fuel
if you remember it will take either 1-3 ozs , i tried 3oz then 1 oz no major improvement ,but i think it is pretty good enjector cleaner -
looked at it very quickly tonight, heard a ticking around the acell coil, all wires good ,ngk plugs, new cap, rotor, ?? -
a question here, i removered the big fat cat on my 88 turbo wagon , but i still have the o-2 sensor in place ,really no difference in power , should i unplug the 0-2 sensor ? or leave it pluged in ?
that could be , -
after the cars sits over night it starts right up and idles fine, drive it 5-6 miles shut it off for 2-3 minutes ,start it back up it will idle way down and some time even stall , but does not do this all the time , recent tune up, cap,rotor, wires,plugs, fuel filter , acell coil still good, no codes flashing , car has 189,000mi , mpg is 25-26 with ac on, any suggestions ? thanks
New record fuel mileage for me!
86subaru replied to heartless's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my 88 5sp might get that if i do not run the ac ,w/189,000mi on it , yours is doing really good i think , -
help me identify my radiator
86subaru replied to Frank B's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i also have 88 turbo awd a/t turbo wagon, it will start to over heat if your running 80-85 mph with the ac on. but 65 -68 runs normal ,and i have a 2 row , but i live where it is very flat , my problem is the fins on the outside may not let enough air into the radiator -
timming question/ top dead center
the weber was not hooked up at all, and the vacuum lines were crossed , oil was going into the weber, , but it was running fine , i decided to change coils and go with a acell coil and this is how it all started -
no big deal, when ever you take your grandson back ,stop on by -
set top dead center, set timming to .8 , major back firing , surging , so i bumped up timming to .12 , alittle less backing firing , if i really get on the gas is when it back fires , what should i look at next ? -
that is what i was thinking , my books say something about 3 marks , thanks -
when setting timming marks, which marks do you set the pointer at ? , i cranked the motor by hand , and turned it to A and left it there , i do not mean when turning the dist that is .8 , what mark is top dead center ?this is on a 84 brat with a weber ,thanks
