Everything posted by erik litchy
i got a new CAR!!!!!!
reminds me of when i got tyres on my jeep. they had to wash the mud out of the rim to get them to balance
Justy Fuel Pump
erik litchy replied to storrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif i remember right dwell meter is bascially an ohm meter? because points are basically open or closed. (forgive me this is so obsolete it hurts) so that wont help. you could use a voltage meter in a multimeter and back-probe the injector wires, i stated it the way i did becasue i didnt know if you had one. id still check the computer for errors, something simple can cause it to not to open the injectors. if theres a loose ground to it or somewhere that wont help any either.
RX turns 300,000
makes me wish i could drive mine.
Hi-Flow aftermarket cat?
id get a 2.25" 2 way cat to replace the stock 2. 2.25" exhaust from the cat to the tailpipe with the muffler of your choice (but most muffles dont fit unless they are very short in the oem spot). that would be a lot more efficient that the stock exhast that necks down to 1.5" in some areas.
sad day for alleyboy
wow just like that vw vid i posted
How to troubleshoot A/C probs?
sounds logical but the compressor is turning off. (easy to tell by the engine performance) the air comes out the same temp as the outside air, so its not going through the heater.
Anyone have experience with short-throw shifter?
erik litchy replied to swc7916's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXworth doing in just any car. its kinda simple i cant see how one brand can be better than another.
coolant problems
is guess bad radaitor cap
thats what mine does. but only on the highway. around town its fine. its got a good charge too
Justy Fuel Pump
erik litchy replied to storrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcan you pull them out and leave them connected to the fuel lines?
Justy Fuel Pump
erik litchy replied to storrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX40 is good. check the injector to see if its spraying, have you checked the computer to make sure it shows no errors? im sure a problem like crank angle sensor or something will cause no start
Tire recommendations?
ive got kumhos on my jeep and I like them better than the goodyears i bought for my subaru.
It's alive! Pics of 80 DL hatch. 56k warning!
holy crap those are some narrow wheels and tyres what size are you running. you should get in the group wheel buy!
Motor driven fan broken, how to get it off completely?
unbolt it after that the rest will be obvious.
Paint Colors
i vote for montreal blue
cruise control
erik litchy replied to gmorgan1387's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive heard others with this same problem.
Loyale touring wagon
whats special about a raised roof? is there something special inside that makes it more luxurious? overhead storage? whats the benefit?
Need cheaper price options for 92' Loyale 4wd rear struts.
paid $40 each for the kyb's on mine they are great
I bought a 2005 Impreza!!
erik litchy replied to Lesbaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnice get the sti short shift
motor. . . maybe?
sounds perhaps like a head gasket, not a big deal.
Air conditioning
erik litchy replied to floater's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXusually a decent vacuum pump can boil off any moisture in the system.
Manual Tranny Swap Problem...
perhaps you can take some slack out of the linkage by adjusting the cable?
Engine Mods
erik litchy replied to Neil '01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi dunno ive driven both in high altitudes and can say that the turbochargers were definatly working harder, but the engines was about normal, and the non turbo engines are wheezing. Semis dont seem to have too mutch trouble at high alt...I know they pass me up hills when im towing
Whine at 50 mph+
interesting, but grease doesnt really have a strong scent, and you should be able to smell the grease in the broken CV joint following the same logic
Whine at 50 mph+
smell it? no
