153
You will need a custom intake manifold if you want the coolant passage to be seperate to the air intake tract, the the manifold as such. On the EJ the coolant is separate to the intake manifold so keeping heat away from the intake is a whole lot easier. Keen to see where you go with this as a matter of interest more than anything. Cheers Bennie
Can you get these rims without the bolt pattern drilled before purchase? Then have a shop drill to 4x140. Interesting you have ATVs that are heavier than the Brat! Cheers Bennie
If you have all the parts and the two vehicles are the same generation, you can swap the AC in. I’ve done it with one of our Brumbys over here. Pulled all the AC gear, including wiring from the touring wagon and dropped it into the Brumby. Took the PS as well Cheers Bennie
Just no. 3mm is a lot when it comes to bolt patterns. This idea is all kinds of wrong. Cheers Bennie
That’s a crazy amount of gunk on that throttle body! Have you tried running a can of upper engine cleaner through the engine? Follow the instructions to a T and keep the revs up as you spray the remainder of the bottle in. I’d say you have some very dirty intake valves - the back side of them. This could be causing issues with the air fuel mixture entering the cylinder. What sort of compression are you getting on each cylinder? Cheers Bennie
Interesting @Numbchux. Over here the SJM is cut out and left in the scrap pile. I presumed it would be the same in other markets too. Apologies for the bum steer @glife Cheers Bennie
Fan clutch for EA81 turbo.
el_freddo replied to oczuk32's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How does that work?? @oczuk32 - what’s wrong with your mechanical fan? Are they a viscous unit? If so you might be able to replace the fluid inside it for some fresh stuff that should make a difference. I know the guys over here replace the fluid in their Monteros (I think that’s what they’re called over there. They’re known as a Pajero over here and also a Shogun elsewhere). Cheers Bennie -
This is a common mod over here. A fella I know that still runs the EA82t has this setup using a small motorbike radiator. I can’t remember if he has this mounted in front of or behind the main radiator, I think in front. @Step-a-toe might be able to shed more light on it as he *should* be running this mod with his EA82t to help keep it cool! Cheers Bennie
Second thing to check (if the belt is good) is that the rotor button’s retainer screw is installed. Cheers Bennie
EA82 Clutch cable assembly... need some help.
el_freddo replied to DrieStone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah that is the hill holder valve. Good when adjusted properly, not good when you’re trying to inch your way back down a climb you didn’t complete the first time. You don’t need it and it’s not detrimental to leave it out. I don’t have the cable connected for it on my L series, zero issues so long as the return spring remains in place. Cheers Bennie -
I’m 99% sure many vehicles until late into the naughties were batch fired injectors - that’s why the sequential injection became a catch cry of many car company’s advertising campaigns. EA are definitely batch fired. Which ones I don’t know. Cheers Bennie
Well one thing is for sure @davepak - if you like puzzle boxes this is sure to be right up your alley! All the best with it. With that wiring diagram cross reference the wire positions at the ECU to make sure someone previous to you hasn’t repinned the ECU plug wires and misplaced a few. Cheers Bennie
Try that first if you can siphon the fuel out - or pump it out with a Fawcett pump if going straight from the tank to bucket. Other way to try would be fill with good fuel, throw a new fuel filter in there and use the EFI pump that’s already there to do the work if it’s up to it - collect the fuel from the return line. Use as much clean fuel as you like, I’d initially double what’s in there, flush, once low, throw another jerry can of clean fuel in there, flush another litre or two then try for a fire up. Good idea to do fresh spark plugs and a well charged battery with a vehicle also jumping the starter battery (with correct voltage spike protection). Cheers Bennie
If that injector is squirting that amount of fuel, you might have a cylinder full of fuel that can cause a hydro lock situation. Hopefully not. Your oil will probably smell like fuel now. Have you swapped injector 4 for a known good unit? I’d start there. Also, these injectors are batch fired, what are the paired units? I don’t fully understand how that system works and what’s involved but understand the principal of batch firing. I would’ve thought you’d find two wires from the injectors to the ECU connected. Just putting it out there, hopefully not a red herring as I don’t play much with EA82 EFI these days, just EJ22 looms and conversions. Cheers Bennie
You’ll need the matching engine management loom and ECU. Then splice this into the vehicle’s main loom so it works. If you have security that’s an added challenge. Or run an aftermarket loom and engine management. Other supporting mods that could be done are larger brakes. You’ll need an upgraded fuel pump. Best to buy a turbo vehicle from the get go and star with that base. Cheers Bennie
Fuel pump replacement options
el_freddo replied to KevinP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just about any external efi pump will do the job. Look for one from a V6 or something of the like and use that. They shouldn’t be much bigger if at all. I’m using an external efi pump from a ‘91 V6 Holden VN Commodore. That’s a 3.8 litre from memory so it’s got loads to deal with the 2.2L in my L series Cheers Bennie -
Do not do this! The efi pump replies on fuel to cool itself - yes, there is fuel flowing through the internals of the pump’s electric motor. All EFI pumps are like this. If it’s possible to reverse the polarity and run the pump I wouldn’t do it. Pull a fuel line and blow compressed air back into the tank if you really need to - make sure the fuel cap is removed. Cheers Bennie
Check the cam timing. Both cams could be aligned exactly the same which means one is 180 degrees out of synch. The other thing to consider is open valves. Rust/grud build up could be holding several valves open enough not to let them create the required seal for the bang to make any kinetic energy in the form of engine power. Or rings are clogged up, not producing compression. Cheers Bennie
