el_freddo
    150
  1. An alternative is to shave the bolts 3-4mm shorter. Cheers Bennie
  2. It seems there’s an issue with the thread at the bottom of the hole, or some debris down there stopping you from getting the bolt all the way in. You might need a thread chaser with a straight edge on the leading face to get to the bottom of the threads in each hole. A tapered end won’t do the job. Have you sat the intake manifold on with the gasket in place and checked to see if the bolts can be torqued with contact on the intake manifold? When you fit the manifold, don’t forget that pesky little coolant hose from the top of the block. It’s a PITA to get to with the manifold on, but not impossible. Cheers Bennie
  3. Have a read of this thread. You should get some ideas in here Cheers Bennie
  4. You just need a hand file or a dremel. As for the adaptor plate various ppl sell them around the traps. The bolt holes of the EA82 flywheel needs to be elongated to fit to the EJ crank... Cheers Bennie
  5. Been done many times. Engine mount holes need to be extended outwards. I can’t remember how far - it’s the same for any EJ conversion. Cheers Bennie
  6. I hope you get that pump/battery issue sorted now. I bet you were driving around like before you got stuck in the car park! Cheers Bennie
  7. If there’s no fuel at the hose work backwards from there. Firstly, got fuel in the tank? Any fuel at the pump? Did you place all fuel lines back in their correct order? Cheers Bennie
  8. *orders four sets of lock nuts* Tailgate trim is being kept safe as it’s in good condition. The trim pieces that hold it on we’re failing so I took it off before it fell off or someone did it for me. Someone got a good deal on that wagon! Cheers Bennie
  9. That double roll pin arrangement on the selector shaft - ALWAYS remove the inner pin before attempting the outer pin! Ive seen this setup on just about all Subaru gearboxes, except the real old EA81 4spd boxes. They’ve usually dropped out or been replaced with a bolt Cheers Bennie
  10. Very nice! There’s one really close too: Cheers Bennie
  11. Whoa! That interior should come with a warning!! Best of luck on the sale. Cheers Bennie
  12. Those km could be genuine. I’ve seen these owned by old grandpas that typically garage them and only drive them to church/into town once a week. Would be a steal at that price. Innes motors here in Bendigo had one traded, 288,000km from memory, late model in white - looks like it came off the show room floor and it’s a survivor vehicle. Dunno how they kept the interior look g like pics from a catalogue! It’s on display in their showroom Cheers Bennie
  13. What order do you have the firing order in - and do you have no1 starting at the correct position on the dizzy? Cheers Bennie
  14. Welcome Cart. Interesting parking choice there! Cheers Bennie
  15. @darkstealth16 - wiring is always a hard one to diagnose over the forum, even over the phone at times! Glad to hear you go it sorted, it’s the best feeling short of firing up the engine with your cut down loom! SMJ? Super module junction or what ever that big joint with the bolt is called? If so, you don’t need that! Have you labelled all your wires so you know what’s what the next time you test or go for the install? Cheers Bennie
  16. Ok, now I’m super jealous about paint! I’d love to do a full resorts of both my L wagon and my brumby. Ultimately a rotisserie would be used to do the underside and inner guards as well... probably won’t ever happen though. So I’ll have to live vicariously though your efforts Nico! Cheers Bennie
  17. If imported from the US I highly doubt it’ll be a dual range. Cheers Bennie
  18. Hey Doc, thanks for he update. And wow, you guys took it to the extreme! Over here businesses were still open but with the regulated social distancing requirements in place. I’m glad that didn’t happen to us (still could!) as having access to parts was a bit of a life line for me - I got a few things done so it wasn’t wasted time. Cheers Bennie
  19. I love how you go all in on a few levels up! Keep up the good work. Cheers Bennie
  20. Ah yeah I didn’t think about the Gen3 NA EJ251 - and I’ve got two in the family! With my comment above, I was thinking of the 2 litre EJs. But like I said, not 100% on it and that is certainly the case for the 2.5 litre EJs. Cheers Bennie
  21. @D Giles Baeton - we need an update on this!!! Hope you’re well mate! Cheers Bennie
  22. I think with the phase two that an odd number is turbo and even number is NA, but I’m not 100% sure on that. Cheers Bennie
  23. I don’t think a knock sensor can do that! Maybe there’s also an issue with the idle air control valve and in conjunction with a dodgy knock sensor the engine was able to stall out. Cheers Bennie
  24. I should’ve asked what year each of the L series are. Over here mid ‘87 is the crossover from series 1 to series 2. Some cosmetic differences occurred on the exterior, wiring wise the switches for the headlights changed and the cluster switch on the steering column was introduced in the series 2. Some of the dash buttons changed too (flat grey to a black framed with grey insert). If swapping from a series 1 to a series 2 you’ll have to take these changes with the loom, unless you do some fancy wiring mods. All that said, I don’t know if the SPFI came in the series 1. All the best with it! Cheers Bennie
