kevinsUBARU
Everything posted by kevinsUBARU
From mysubaru.com: All-Wheel Drive (AWD) vehicles, it is extremely important that the rolling or outer circumferences of the tires be within 1/4 inch of each other. This means that you must physically measure the size of the tire. This is best done with the weight of the vehicle off the tire and at the tread centerline. Also be certain that the tires are properly inflated since this can affect your readings. If you need to replace just one tire, the same holds true. The measured difference in circumference between the replacement tire and the other tires on the vehicle cannot exceed 1/4 inch. Depending on the vehicle mileage, it might be better to replace all four tires. If the vehicle mileage is low and the tires have been rotated and driven at the proper inflation pressures, then you may be within the allowable 1/4-inch difference in circumference. If the difference between the new/replacement tire and the current tires is within this 1/4-nch maximum, then the tire should be compatible. If it is not, then other tires will need to be replaced to conform to the 1/4-inch rule. Exceeding this 1/4-inch difference in tire circumference can place unnecessary wear on drivetrain components, possibly causing them to wear out prematurely. If your vehicle is AWD (All-Wheel Drive) with an automatic transmission and the temporary spare tire has been installed, put a spare fuse (15 amp) inside the FWD (Front-Wheel Drive) fuse holder (refer to your owner's manual for location). Confirm that the Front-Wheel Drive (FWD) warning light comes on before you drive the car. Installation of this fuse deactivates AWD to prevent possible damage to the drivetrain components that can result due to the use of the smaller temporary spare tire. After re-installing the conventional tire, remove the fuse from the FWD fuse holder to restore AWD operation. For more information on tires and temporary spare tire usage, always consult your Subaru owner's manual. I know it doesn't say you have to put the donut on the back, but I didnt pull that out of my rump roast I think it says so in my Impreza manual... Anywhow, take care! Kevin
If you wan't to base your next purchase by what you read on this board, I think thats a little crazy. For every one complaint here, there are a million other happily satisfied customers. Fact is, there will be defect in a certain % of any product. Here is the rust warranty: Rust Perforation Limited Warranty Coverage: 5 Years / Unlimited Mileage The rust perforation warranty covers your Subaru for five years, regardless of how many miles you drive during that time. Defective original body sheet metal panels that are rusted completely through from the inside out (perforated by corrosion) will be repaired or, at the option of SOA or your authorized Subaru dealer, replaced without charge to you for labor and materials. The complete list of parts covered under these warranties is included in your Subaru Warranty and Maintenance Booklet. That booklet also contains other important information about your Rust Perforation Limited Warranty including additional coverages, limitations, and your responsibilities under this warranty. Please read your booklet carefully. If you’re not sure about whether a specific failure on your Subaru is covered, your Subaru dealer will be able to inspect your vehicle and answer any questions you have. Get a different dealer and get this taken care of Good Luck, Kevin
80's Japanese Domestic Subaru's... PICS!
kevinsUBARU replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think SubieGals rally wagon is also in that issue of the magazine along with a few other people from NASIOC.com Kevin -
Are you 100% Hard Core SUBARU?
kevinsUBARU replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
old man tim:-p -
Kinda fell in my lap...
kevinsUBARU replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
163,003.062 miles -
I dont know how it is where you are, but the snow earlier today was kind of slushy, then it froze. Its pretty icy outside with about 6 inches of snow on the road since they plowed last. Even with 4 snow tires (on their 4th season so that might have something to do with it) its not the easiest driving. Ice just sucks!
smores?
The only kind of boat you can put in the Ashokan Reservoir is a row boat/John boat. NYCDEP regulates that so that the use of the water doesn't become 100% recreational...just fishing As far as independent mechanics and body stuff, I really have no idea. I've tried a couple of small shops with limited success, and everytime I need bodywork done I've been out of the area. Kevin
