10
Everything posted by ivans imports
Clasic get this weekly it threw a rod right after the heads were done Two reasons one poor cleaning job or orbital grinders used for cleaning. Also if was running with bad HG the coolant was finding its way into oil witch the pcv can remove the moisture but addatives and sugars are left in the oil ruining bottom end bearings. A oil presshure test should have been done prior to removing engine { MIN 10 PSI HOT AT IDLE ] if not bearing time. people assume that because they are going to get the heads done soon they do not have to change oil BIG MISTAKE antifreeze in oil will ruin engine and you will never see it coming. And will never have milky oil or any warning signs just wipeout bearings.
how do i mimic a VSS?
ivans imports replied to lilpusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Can you use a axle tone ring on your drive shaft to give you the signal a tone ring could be pressed on and you could cut out teeth till you get the right # -
pitch rod bushings...where to find
ivans imports replied to odie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
read that wrong thought you were talking about strut rod on control arm The pich stopper can just use any neoprene flat bushing -
Got to much time on my hands lol Nice car sweet job !!
dealer item I got them new for my 80 brat so still avalibble -
EA82 head crack between valves
ivans imports replied to spayordie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welding cracks is bad idea DOSENT WORK bad news have had to cleanup so many bad head cars because of poorly done weldup jobs the problem is the casting is poorus and holds carbon bits the make the welds not bond properly and after heatup and cooldown cycles the welds give out guide falls down piston gos smack and you look for new engine. Subaru had some very good tooling to build those heads and I think was some very tech temp related work to put those seats in head. -
My turbo 2 dr justy has best 0- 60 of all my cars 1rst 3rd 5th
83 BRAT... No Spark In The Morning
ivans imports replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Diss module on its way out ? -
Check the ohms of plugwires / coil wire if to high will arc at coil and no spark to cap the old 78 wagon I just bought had this problem was just snaping from coil wire back to coil +post -
Automatic Transmision HELP
ivans imports replied to taz ride's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I still have piles of oldschool parts
