10
Everything posted by ivans imports
I built a tool to compress the spring in position so can slip follower out and change lifter without teardown sitting in my tool box unused for 6 years now
Idleing high 1980 brat
ivans imports replied to disom93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Take off top of carb and unscrew them doubt is you problem check intake gaskets are they factory subaru only ? also check that choke is pulling off and idle curcit in carb have had luck putting my hand over the top at high rpms thiss will stall it but pulls the crap outa the bottom of carb may have to do it more than one time but seems to work on old hitachis -
Newbee to subaru's
ivans imports replied to pappa_wolf's topic in Old Gen.: 80's GL/DL/XT/Loyales...
one more the feul pump wont turn on unless ecu gets crank signal to tell realy to cycle -
Newbee to subaru's
check timing belt and posibble crank senser failure dose the engine sound right when cranking ? spark ? are the main power feeds in under hood fuse box ok black fuse wire is main fuse 80 amp s -
Go big or go home is way cool to have control over system wonder what the max we could throw at it whould be? Anyway runs totaly different than before and seems to get feul properly now
77 wagon voltage regulator ?'s
ivans imports replied to stanced77's topic in Historic Subaru Forum: 50's thru 70's
I put a 100 amp mitsubishi alt on my 81 brat used the choke wire as eciter wire came off 86 caravan with 2.6 mitsubishi engine works very good think reg is unpluged -
#1 cylinder not firing
ivans imports replied to Frank T's topic in Old Gen.: 80's GL/DL/XT/Loyales...
stuck injector try a differnt one have seen them stick faily often -
EA82 How do we feel about it?
ivans imports replied to BestCar/OnlyCar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ej 2.5 turbo turned into stroker 2.7 wreaked two this season already -
ea82 lifters good for 300000kms no porblems oil pump seals change every 100000kms or when it starts ticking
5-Speed DR Rebuild Kits
ivans imports replied to alaskaloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Duke pull drain plug look for teeth or meatal bitts on magnet also have seen the pin shear on shift fork and fork slip out of shifter slots inside trans all other gears work ? -
I have got super good at filing the syicros just right can be made to shift very good but must set the angles and debur it just right then shifts great. Have rebiult at least 50 of them now also have been hording DR cores have 15 now also install a 1/4 inch reverse shim behind the reverse idler this will make reverse 70 % stronger I use a brass washer 1/4 thick prevents reverse kickout -
EJ22T after swap problems. Fuel cut at 3 to 5 lbs of boost.
ivans imports replied to Steve W.'s topic in Subaru Retrofitting
ok is it posibble that the vacume lines to the map are pluged restricted or one way valve backwards do you get clean vacume to map ? darn is to bad so far away oh well keep pluging away the problem will show its self -
92 Loyale Bad ECU?
ivans imports replied to koticimage's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use the soiliniods from newer outback/legacy do the same job but way tougher use 2.5d egr soiliniod -
I like short subarus !! nice can you make a outback one ?
change brown seal in oil pump and orings
The last race engine had 3 bent rods and two smashed pistons did 2 passes like that bent rods dont seem to slow them down mutch -
most likly bent valves they like to get them comp test when retimed
- 39 replies
- Engine swap
- EJ25
(and 1 more)
Tagged with:
well its down on power now but we can keep adding more nos and more nos and more nos
O2 senser shorted ? ritch why ? leaking injector ?
