Everything posted by ivans imports
Legacy -- Reverse near gone -- other gears fine
Takes me two hrs to teardown and redo reverse clutch pack don't even have to pull the pan can remove whole internals in one large piece and get to the good stuff the nice thing is no fancy tools needed just flat screwdriver and 14 mm do have to back the band add off
EA71 Backfiring
looks fine show us a pic of pistons on the problem holes little bit of oil burning is all I see
Intake gaskets... I know I know...
Subaru only !
Reverse clutch pack is gone is very last part in bottom of trans when you take it apart
Lifters will not come out of ea82 head!
I tap them sideways gently all way round this will slightly expand brass lifter bore and should let them release
How the hell did this happen?
Happens to me all the time so I got rid of wife and kept Subarus
Cruise Control Problems
ivans imports replied to KZCool's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 clockspring
Stranded in Pittsburgh w/blown turbo. Please help!
Had a lengthy Talk with a friend tech about this and were thinking about drilling the banjo bolts bigger to increase flow to turbo he is on his 2nd turbo in his outback keeps blowing up
- 1988 Subaru GL Transmission Knock
EA71 Backfiring
My 81 brat has that one 81 year only. Anyway sounds lean and might have a broken piston ring land. Do a fuel volume check
Anything I need to look for when I go to look at this? 2003 Outback
ivans imports replied to Sandrion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe headgasket leaks off the seam were head joins the block and runs down xmember look for oil leaks there
ivans imports replied to Sandrion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOil pressure check min 10 psi hot at idle and HG check for leaks rear DS head seam
Roller rockers and roller cam in big valve hydro ea81?
I see flat springs in there to cool !
- Transmission stub shaft swap - Who has done it?
Sick love it !
Try a flat oil pan from 89-92 ej2.2 will give you more room Also if you use 07 and up water pump hose comes off the front instead of bottom gives you more room to
Transmission swap
ivans imports replied to Georgep's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95-98 99-04
There's a 1996 ignition coil on my 1997 Legacy Outback
ivans imports replied to revtim's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe ej2.5 early ones say twin cam on valve cover late ones do not diferent plug wires is one year that is late model engine early coil pack is 97-98 has female coil after 98 is male coil ends
NEED HELP WITH VALUES
I prefer the gold two headlight one is a nicer look to it
maf help
I have one to if needed the two do not interchange
Frankenmotor Failure
Rust on the cly walls good luck sealing
Broken ring land race car dose that when piston is broken between the comp rings needs piston! I have boxes of them
- 1996 Legacy 2.2L
Remove oil feed line screens they plug and stop oil flow to turbo
