10
Everything posted by ivans imports
even for free no one wants it somone must need a 2.7 L
EA71 Pistons
ivans imports replied to Twitch de la Brat's topic in Historic Subaru Forum: 50's thru 70's
dont use them weak between the ring lands use loyale ea82 pistons have a thin ring on top lands the ea71 has thick uper ring that makes piston crack between the ring lands -
brat for sale #2
ivans imports replied to ivans imports's topic in Historic Subaru Forum: 50's thru 70's
will get matt to help me put some on here will take me a bitt -
Thinking about giving up on restoration needs body work 77 brat 100% complete red has very low kms runs good is project car but worth restoring has been sitting here for 5 years i start it every spring and fall anyway just have to many cars 3 brats is to many might also sell my 81 brat not shure yet anyway the 77 brat will go for 2000$ with all parts for restoration the 81 go for 3500$ is 98 % compleate and has high low and efi ea81 and rear disks and loyale rear strut convertion 185000kms no rear seats and well used but very good runner and 100% reliabble Just to many cars
take the sprayers from a 01 -05 cars have a wide spray pattern and move way more fliud
is older race engine ran well had a damaged piston witch i fixed has been sitting for 3 years dry had a front mount turbo setup and cut down wire harness mising ecu but rest is there anyway free come get it a'm tierd of it taken up space and will not run a 2.7 agian
biult the strut blocks and geting the brakes sorted the master had failed from being blocked so put on a outback master cly on it fixed has crazy brakes now holds at the stall no problem think this will make a hudge difference in my start times.
Im so glad that all the ea82 t engine are long dead round here wost subaru engine ever ! cracked heads blown gaskets droped guides stuck lifters broken pistons knocking rods water in the oil split hoses over preshured rads oil leaks ect. I can only think of one of those engines thats still on the road round here in a 88 rx. Put a 2.2 in it and you will be way hapyer
make shure you chage the inline fillter is hiden in the ds fender well and gets overlooked on this car was a remote fillter this will cause more problems than a oil cooler will. Why they did this I dont konw But I never see them changed. The six had problems eating up planetarys I dont think a cooler will help with that but it may.
used up 20 cut off wheels last year cut of every extra bracket ear ect we cut of all the extra ears of engine lightened the uper bodywork. As mutch weight as we added with front end parts i removed off the front body. As for my trashed rack anybody have a 85 gl non power rack ? I'm ordering the replacment pistons today I can buy them as indavidules so orderd up 2 one to fix broken one and one for spare. The engine runs so good still even with only 110 psi on #3 pulls 115 psi oil preshure when started cold no smoke out the pipe. Anyway time is runing down fist race is coming so time to sort out all the bugs
front wheel knocking and grinding
ivans imports replied to czaray's topic in Old Gen.: 80's GL/DL/XT/Loyales...
use shim keeps the berrings spaced properly -
Radiator in the rear, booster pump?
ivans imports replied to Phizinza's topic in Subaru Retrofitting
I added a 6 L expantion tank inline with uper rad hose gives me a 14 L coolant system and helps to keep it cool the more coolant the les chance of heat soak. I race in the middle of the day on hotest days of the year still takes 35 min to warm up in 35 degre heat -
at the kammloops race in 2010 i lost the turbo shaft and impeler out the exhaust at 7000rpms and at 100mile in 2011 we gernaded a 2.2 turbo twin cam sent lots of peices into the air and out the pipe we dont want it pointed at anybody. And keeping the guy at the start line safe is priority. Seems to like a longer exhaust runs better than strait out also my o2 works better. One more thing should have been more clear about dont want to add any weight to front rear is ok as car is front heavy have been trying to get a good balance piont so no nosie dives when jumping. Anyway i just have to rebiuld the toyota calipiers and rear brake are done then back to engine. Scott no thats a ea rear end setup tortion bar and coil shock the rear end is original from the 81 2dr 4x4 that buggy was made from we moved it from under the back to under the floor
