Everything posted by monstaru
Smiley..........
All mounted up . She is sitting on her own Two feet again in the back cheers
Adjustable trailing arms??
ebay cheapies... I have some that have stayed quiet through alot of abuse. cheers
Smiley..........
I looked just slightly earlier than you posted.It is literally from 2.5 5 speeds. from like 97 to whenever that generation ends. Got athe proper Slave, and mounted it up the trans to make sure it fit. Then checked the fitting to the Toyota master cylinder.. Cheers:drunk:
Smiley..........
WElp replced the picture up front, and here are some more. Just put the tires in front of her to see Finally got my wheels welded up Test fitting the bellhousing.I need to get anotherr Subaru hydro clutch.The one I have is from some other model i guess.Because it does nto match this bolt pattern. Wheels all painted up, I thought I would like the whiite background.But don't.Ima change it to drab.... whipped up a twin stick setup... Still working on the fluid barrier, I sat around the other night with sandpaper(300 grit-ish, and 1000 grit) and polished the inside leading edges of the twin sticks to get them to move more fluidly next to each other.Then hit them with a dremel and some rouge.. The whole layout, teting bolt sizes, looking azt length etc.... Thats about it, I think I have made a deal on My Subie EJ d/r, so I will have the scrilla to throw at this thing again soon. I need ARP studs for my knuckles, then I can put stuff together the way I want to!! cheers
My EA82T->EJ20G conversion
Incidently, That looks like about 16 guage. cheers
W series Toyota trans adaptors
Fair enough.I feel differently about it all the time.... But I would never leave you guys out
Smiley..........
So, the distance between the 82 Toyota framerails(which is the same up to 85) is 22 ish inches. The width of the EJ is about 29 inches.Hopefully my luck is with me and I can keep it high enough to stay intside of my shock mounts.Or I might have to take the ford towers out and make some Tube mounts. We'll see.I may just have to flatbelly the whole shebang.Just so the engine is high enough. cheers
I will absolutely post pics.I probably won't make a build thread here As this is a Subaru board.
I am amost to that point.Like so close it is ridiculous.I will have family here for the next week, so I'll find out in a week or so FRom measurements it looks like I will need to relocate the ford shock towers, then flatbelly to clear the bottom of the valve covers. We shall see. It will get mounted in there.Period. Whatever I have to do to make it fit.... Cheers
I have mine going into MY toyota rock crawler RIght rump roast we speak!!!! Just a teaser!!
- NWWO Walker Run Dec 22
Smiley..........
Yeah, a bigger motor just brings bigger probems:horse:.Ima be pushin it with a frankenmotor. But hopefully it won't turn out to be an issue. I would LOVE to do a diesel conversion next.... cheers
Smiley..........
That is what I am tackling now.I am the point I need an engine to lay up in there.I am working on it.trust me , damnit It IS going down. This is kinda my dream. I will make room if there is not SOON.SOOOOONNNN!!!!!!!!!! cheers
Monster wagon vr2 "Monster Sedan" build thread
?Weellz? QUOTE=Subafreak;1151679]Well that was a long day. But! I got the other rear wheel well prepped, fabbed, welded, and treated! So it was a productive day. This side had a bit more intrusive rot so I had to repair it up above my wheel arch line. So it looks like I'll have to do some bondo-ing anyway. I'm gonna order this body filler from POR-15, it's supposed to work right over the POR-15 treatment so the metal underneath can stay protected and not just blow out the body filler in a year like you ussualy see with bondo jobs. Hopefully Tomorow I can get the rocker panel repair done on this side and get everything seam sealed in.
Smiley..........
Finally got around to welding these centers in. moar weld porn The shop at work afterhours.. 1/4 inch pressed ceenters from trailwortyfab.com, into HMMWV double beadlocks with rubber runflats. Thats my wheels. Hopefully this will go smoothly,I am gonna have to try an retrofit a Subie hydro clutch to the Toyota system.Mr.Hinchers best... I have the ************in shifter rail in backwards!!DOH Otherwise theses would be tight together by now..... More to come i guess. I shall now lay it out for you: 85 Toyota shortbed frame with Ext cab, double bobbed bed Ej frankenmotor W56 5 spd 4.7:1 t-case 4.88 axles with lockright in front , v6 third out back (probably gonna weld it) trussed,built to ************ front housing.Rear needs some love, but I think I'll wait until I put my v6 rearend in there. From Stella besides the motor 02 WRX seats, cb, lights, etc.... So far so good. Need hysteer, ARP knuckle studs, add 5th stud, and possibly a new ring and pinion for the front. Otherr than that , Wire up the engine to the Yota harness, and make some engine mounts. Hopefully I have an engine to use as a mock up within a week.Then hopefully after the holidays I'll have some dough to finish throwing at her. Cheers
Whats the biggest engine that could be fitted into a EA/EJ body?
You alkways have the same ************ing answer. Have you not seen his name around here forever. Thanks Captain Obvious.No really, I am sure he needed to hear that. Jeezus.Stay in one place in the forum.Where newbs are preferably. Gad amn
Lockhart Basin in a soob, new gen wheeling report from Moab
True, but when you are doing light duty stuff and still break.It sucks.Even when I DIDN"T use skinny pedal(which is almost impossible)I was breaking stuff. Mostly due to QUALITY of product. Yes they ARE cars.And I have taken them pretty far considering..... farther than most.Not as far as some.And defenitely built my own ************. I had almost 700 bucks invested in utilizing Ujoints attached to a slip joint from a hop harvester..... I still needed way more cash to run that one down..... For that price I could buy Toyota chromo fronts and rears.... Just sayin.Thay do have their place.It is just not in the woods with ME anymore:D:drunk: cheers AWESOME car Superu.I havealways liked it! Unhijack
I am so ************in tired of breaking ************.There is gonna have to be some serious upgrades to axles before I go back to wheelin a Subie .... Like chromos.....
Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
- MOVING TO SEATTLE! Looking for work / lodging!
So your gonna become a downtown scenester huh?- Stellaaaaaaaa!!!!!!!!NEW PICS!!!!
She is getting parted out!Ima keep the shell,I.already sold some of the suspension,wheels and tires. She will move into the shop when I get more space. For phase 3....- Monster wagon vr2 "Monster Sedan" build thread
If you add a belly pan? Thats one thing that always bugged me about my Roo's, hanging exhaust.....DOH!!!!- Annual Hatch Patrol Xmas Tree Run, Saturday, Dec 8
Had a good time seeing those I hadna seen in a while, Missed some of those I didna get to see, and liked meeting those I had never seen! Cheers to all, and to all a good damn Christmas!!- Toyota mags...what lug nuts?
I am gonna come steal all your lug nuts just cause you shoulda reamed the rims > LOLOL cheers- Annual Hatch Patrol Xmas Tree Run, Saturday, Dec 8
Can't bring my Roo..... Don't have snow tires for hers(bad solenoid C anyway)Which actually wouldna matter in the snow LOL So, the truck it is.... Gonna have to get up early to get the weight in the back. cheers - MOVING TO SEATTLE! Looking for work / lodging!
