Everything posted by monstaru
steering u-joint
a rag joint is a disc of fabric and rubber that is used between some of the non-power steering shafts and the rack..... a universal joint is at the top of that section, attaching to the shaft , and steering column shaft ..... which part is bad?cheers, brian
Type of tap to repair threads
depending on the bolt, you can drill through from the top, put a socket on it and tap away......... but technically , he is right...bad idear.however, when i did not know better, i did this several times without drilling a hole (with a hole saw)above, and was able to clean them out pretty well....... cheers, brian
how impossible is it to go to an ace hardware?that is where i got my 12x1.25 tap.... just go buy a tap......geezus
rear axle removal
read dates......
lowering the wagon
well, i'll rub...read the dates.....tony rump roast parker......
So. California EA82 Wheeler
actually, you are supposed to use your right hand, cupped perfectly over the bottom of the can......it allows the bottom of the can to sit right on the shifter ...voile' no cup holder:grin: but seriously, cup holders in a wheeler?are you gonna have sippie cup lids on cans or what?thats just asking for trouble:lol:cheers, brian
Is this dangerous?
a rod bearing is alot differnet than a rod.here, http://lmgtfy.com/?q=what+is+a+rod+bearing%3F
How many Soobs have you owned twice or more?
so, your gettin eds brat huh?nice!i wish i could go to the brat meet!buy a piece of 1.5 tube, and i'll make you a rollbar............... cheers, brian
WCCS 12 Site and Location are Set
you shut your mouth , right meow........
B.R.A.T. Meet 2010
he is all fixed up. no excuses now:)....
Lost dipstick in '90 loyale manual transmission
try harder grasshopper....
New to me Hatch
gimme your address......cheers, brian
Blown inner CV joint boot
monstaru replied to jseabolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthis is not where this goes, it should be in whatever corresponding year area your vehicle is.....
Half doors
i wanna wheel that when i come over:grin:.....
EA81 Lift Kit Differences
maybe you should read a bunch.........
Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!
they are not all interchangeable...........good luck.:)cheers, brian
Definately OFF the ROAD use
there are tons of guys that utilize subaru engines for small aircraft.you probably know that by now:).... those guys are the front runners for the modification to put carbs on the ej engines....(obviously where they were not attainable factory).that is where i got all of my info when i did that.... cool stuff.there is also alot of neat stand alone systems they use .very engineer oriented. cheers, brian
i l,ove the desert....looks like fun.cheers, brian
New Toy
i hate you......that is sick.cheers,,brian
The Beast: Straight Axle swap Begins!
you should just trade me out of mine.....they have brand new cartridges in them and just need finish welding.....make you a good deal:grin:cheers, brian
i made it Columbia,sc
good job!glad you had a safe trip....so, are ya gonna be at wcss?:lol:cheers, brian
Ignition barrel removal 85 brat.
he is talking about the tumbler, just the tumbler........ i have been trying too, and i cannot remember......nor get it out.i do not have time to call a locksmith.but that is the next step i believe.let me know whats up. and i think it is a pain, but not nearly as impossible as stated.....cheers, brian
B.R.A.T. Meet 2010
unless you have a very nice GPS, and i mean, very nice, the variability is to high.still fail...... you have to have reliability to get concrete data.sorry ben, but your rigs are not reliable.(proven by your own posts, not bashing) the driveability is better with a 5 spd period. and the rpm's drop about 500 rpms throughout the range....this was tested on a 1986 brat with 185/80/13's,205/75/14's, and 235/75/15's.on a 1983 wagon with 175/70/ 13's and 235/75/15's. you originally stated"maybe a little higher"...... that is what i went off of.cheers, brian
B.R.A.T. Meet 2010
hrrmm, last time i knew, you were pbarely getting any 4spd to work at all in your brat.when did you do a 5 spd swap? and guages not working pretty much make your results null and void.no concrete data.sorry, fail. cheers, brain
B.R.A.T. Meet 2010
have you done a 5 spd swap for comparison?'cause you should say anything about it unless you have first hand knowledge..... cheers,brian
