Everything posted by stngllhm
How do you find cheap Subies?
stngllhm replied to 4RnrRick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i've got a 92 loyal on-demand 4wd with blown head gaskets i will sell for $350 man i wish i lived in the NW -
see if he will sell it with out the work done -
the rx will be a 3.7
probly just needs adjusting it takes a 10mm and a 12mm wrench. it is right on top of the tranny underneath the spare tire
try changing the fluid in the tranny that always seems to help with hard shifting as for slopy shifting welcome to subaru
1989 Subaru GL10 Turbo - Hesitations
stngllhm replied to jazzician's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the coil pack replaces the distbutor and coil -
Did my first C.V. today!!!
stngllhm replied to BobBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it is on the half shaft it is easy to see. personlly i think soobs are easier than most other cars -
isn't the inner joint easier to get apart
the splines on the hub end are thrashed pretty bad.
upgraded suspension and ground effect. it was the sport modile basically
well that sucks the cvs with the d/r are bad and the one on my turbo are good. what about the hubs
Got a dual range coming! questions...
stngllhm replied to sandman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes you can drop the tranny out the bottom of the car. and you need to check to see if the rear diff in the donor car is a 3.9 or 3.7. if it is a 3.9 you need to get that also cuz yours is a 3.7 cv can't say for sure -
Spider Manifold Coolant temp sensor - XT turbo
stngllhm replied to OLS's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sorry can't say what the one in the pic is i just went and looked there is nothing there on mine. as far as getting to it i'm pretty sure you will have to take the upper part off the intake. it is not that hard three bolts on each side and the egr and the throttle cable and electical cables -
Oil filler Tube Gasket???
stngllhm replied to pearlm30's topic in Old Gen.: 80's GL/DL/XT/Loyales...
good piont -
it is on the lower part of the manifold basically below the thortle cable hope this helps -
i got four 87 that the air still works on
i do not think so
i've got a dual range tranny and 3.9 diff i would like to put in my 87 gl-10 wagon is there any differance in how strong the d/r is in ralation to the 5 speed on-demand i have in there now. so in short if i do the swap is the d/r going to hold up i was told that the turbo tranny is built more heavy-duty that is why i am asking
LSD's: 3.7 or 3.9? replacing 3.9
stngllhm replied to dstargard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
try a search -
btw got a 3.7 lsd for sale -
hey i used to live near bend madress to be exact but back to topic if you where to put a 3.7 in you would have to change the tranny also. to get a 3.9 lsd i do believe you have to take the lsd out of a 3.7 and put it in a 3.9 case. -
they are a paper gasket and yes i would just use the gasket silicone to seal it up -
Whats the 'best' Subie to start with??
as far as i know there are only 3.7 and 3.9 and i believe that all turbos came with the 3.7. stock lsd are 3.7. -
autozone was only $45 last time i got one
