8
Everything posted by ShawnW
Run the original starter wire AND the legacy one. My 83...it was the bolt on the SMJ plug...that giant grey plug that hooks the whole harness together...it wasnt bolted tight. Mine now runs, the car hasnt run in at least 6 years, got it just after wcss3 from Qman.
Yet another Roof Rack Question ...
ShawnW replied to Davalos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yakima or Thule make gutter mount racks. They can be found at a junkyard on ALOT of older japanese and german cars. Dont mess with drilling into your roof. -
Please do not promote illegal activity. Thanks! At most pull a part yards if you walk up to the counter with something that is 1-2 bucks on their price sheet they will just give it to you and tell you to put a buck in their charity wheel borrow, pop machine, etc. Being honest actually pays and if they do charge you 2 bucks, big deal its 2 bucks. thats 2/3 of a gallon of gas for something you need for your car.
The lower hose outlet on my 83's radiator points directly toward the timing belt cover and leaves very little choice on mounting a hose between it and the thermostat housing. What have others done to get around this problem. So far I have come up with: A: 90 degree bend of copper pipe so you have a 2" section of rubber, a 90 degree bend and then a flexhose running from the bend to the thermostat housing. B: Custom radiator...I dont like this idea I have a nearly brand new radiator already. C: 1.8L Impreza radiator? The only advantage I can see on this is the hose outlet is already the same size as the thermostat housing AND the mounts for the impreza radiator fan (nicer fans).
USMB/MW4 campout: Cancelled
ShawnW replied to mcbrat's topic in Meet n' Greet. Your USMB Welcome Center
Wasnt MW4 at my house last monday? Almost as many Subaru's! -
A but no white walls I dont care how date appropriate they are.
A steel ruler isnt going to be precise enough in this case. The tollerance is very low. Snap-On sells a straight edge that would be way overkill for a do it yourselfer but its obviously good enough. I have a feeling that if you put your shortblock in the trunk of a car and took it with you to the place that you have your heads surfaced at they might check the block for you for a few bucks.
They sieze all right! And the worst part is you cant use an air hammer on it because its just aluminum on aluminum and it will take all those little teeth off. You didnt say if it was a manual or automatic. On an automatic you would just replace the front diff and pinion gear, a used trans would provide those parts but they need to be a matched set. It certainly wouldnt be a 10 hour job to replace the seals only though...and on an 03 I dont see how these would be leaking yet.
You probably have a plastic or rubber part rubbing on a cam gear. Oil leaks cause the rubber inserts to "grow" larger and rub alot. The water lubricated the rubbing parts for a while I suppose. Time to take it apart again and you will definately see what is rubbing. If you don't maybe you forgot to force the tensioner left and then bolt it in and then reapply torque to expand it?
88 gl rough idle-197,000 miles -EFI
ShawnW replied to Roger Leht's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am crossing my fingers for a clean trip thru emissions for ya! This is a pretty nice little RU if you ask me! The CO was 20.6XX out of an allowed 20.000 the first try and nearly double allowable on the 2nd attempt after new plugs, wires, etc. A new 02 sensor and reset of timing should help alot, just a seat of the pants indicator would agree. Timing was about 8 degrees off and the o2 was BLACK soot covered. Seems this car may have spent some time at a lower altitude or somebody didn't plug the test connectors in while setting the timing the last time. -
Mystery Parts -- picture this, what is it?
ShawnW replied to Hank Roberts's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Idle air control valve.. Fancy for automatic choke if you ask me. -
She's gone to PA.........
ShawnW replied to 75subie's topic in Historic Subaru Forum: 50's thru 70's
Yes, and you wont be too homesick alot of people here are from the East. -
Got my parts wagon home in one piece
ShawnW replied to superwho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
30MPG is pretty good! -
Excellent point here, on a Vanagon this is a big pain in the butt. Remember you will have to bleed the air out of the system for it to do any cooling/circulating.
Dead reliable and ability for virtually any mechanic along the way to fix it would be a Weber Carburator. Simple, efficient, and lotsa parts availability. 2nd would be SPFI though, and not a great distance behind. Mileage will be better, and of all the late 80's subarus they are the most common. They will also self diagnose many of their own problems and tell you in morse code which is nice. Bring a spare fuel filter and it should be great. The stock hitachi I wouldnt rebuild, not when you can get a weber for 300.
Steering rack and crossmember 80-84 Wagon
ShawnW replied to ShawnW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PM me with details on how to get it and when I can come. -
weight of 2.5
ShawnW replied to chasrace's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
198 pounds estimated. Thats the DOHC longblock with oil filter, spark plugs and nothing else. -
Im putting an EJ22 in it with the 88 RX Ft4wd transmission. Im keeping 3.70 gears for gas mileage and the lo range trans should be nice even if its not the super low. -
Oh that'd be awesome! Is it bolted to the crossmember still?
