Everything posted by ShawnW
95 legacy awd wagon
ShawnW replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNope, sorry they don't fit. Also: Moving topic to proper forum.
quick brake question
The caliper BRACKET is removed with the 2 17MM bolts but the caliper itself will come off with just the 12MM at the bottom. Remove that bolt and it will pivot upward on the pivot pin. (the pin is part of the caliper bracket). You may need to tap on the caliper or pry gently on it to get it to pivot.
I have this freind ....
ShawnW replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"Drive by wire" Call the dealer and have it towed in immediately. Thats very dangerous and should be covered under 3yr/36k.
Is it time for new belts?
ShawnW replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck your power steering fluid level and replace the belts if they look dry or cracked out. 15 minute job and 40 bux in parts is worth it.
XT6 wiring harness and ecm/ecu
I could get you a LHD one, its already pulled. You'll have to do the homework and find out if it will work with your engine, or better yet source a LHD intake manifold and know it will work.
Timing belt 137K 98 2.5L outback
ShawnW replied to dlm5774's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that'd be reasonable...you paid 900 all ready so I kindof think they ought to just do it for the cost of the pump.
Audiophiles: Dual Deck?
ShawnW replied to the_bard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet a small CB radio they have a weather channel alot of the time.
colorado members i need a transmission
One of em is lacking an LSD.
EA81 Power Windows
LOL! Yeah, I make MY passengers rotate a little prehistoric crank until the window goes down.
Old School Meet! Wyoming/Colorado guys and gals! Sept. 23rd, 2006
Ill likely be there, and my Subie runs!
Help w/ Cam Sprocket Removal
ShawnW replied to newbie1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'll have to use air tools to get the bolt off or break it loose with the timing belt still on and hope the tension of the belt holds it although I dont recommend this as you can bend valves very easily if you aren't careful.
i dont know if its the head gasket
ShawnW replied to BIGBLUE1212's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomething is causing it to have an air bleed in the system. Head gasket can cause it but you really need to rent or borrow a cooling system pressure tester and pump the system up to like 13PSI and see if maybe you have a pinhole leak that you cant normally find or something. If you don't its probably a Head Gasket. Autozone will loan them to you.
Check out this old BRAT workhorse!!!!!
Gotta mow the yard to be able to find the bolts you drop while working on it.
Anyone making a EJ22 wiring harness for swap?
That'd be me. I wouldnt call it plug and play you still need to cut it to length to suit your needs but all the unnecessary stuff is removed and all of it is tagged and ready to be wrapped in your protective plastic and installed. $200 plus shipping each way. To do it: Pull the entire wiring harness from a 90-94 Legacy. Also pull the complete intake, MAF, ECU, ignitor, relays, etc from same said car as you need to pull all your donor parts from the same car. Strip off the tape and plastic and place the harness into a box. Please plug your ECU and ignitor into the harness and ship that along with it. Get a quote for shipping it to me and from me to you and paypal the $200 and the return shipping amount and state in the paypal how it should be shipped back and to where....or even better make a return mailing label for me. Write a short note letting me know what year and model you are installing it to, what year and model the harness is from (I usually can tell but its nice to know), and whether or not you are going to want A/C to work on the harness. Mail it to: Shawn Watson 9506 Otis St Westminster CO 80021 Any questions please feel free to PM me.
dash lights?
Likely a bare wire or wires between the dash and the taillights. Youre going to have to take the right side (pass) sill plates off and OHM the wires from the circuit and such to try to find it and replace the section that is burned up.
Wow, no redneck stereotypes broken here. Car in Cinderblocks in front yard, dangerous working conditions..............ill stop there.
need some help on stripping down wiring harness (Ej22)
1. This is the Auto trans computer. You can eliminate it. 2. If you want Cruise control for an Ej22 swap its alot easier to use an Audiovox aftermarket unit. I will install one in my wagon when its all running and operational but until then the only snafu I can see is the speed sensor bracket and magnet...shouldnt be terribly hard to fab up though. 3. Yes its the ABS computer and you can eliminate it. Basically any wires coming off the car that arent in the dash or forward can be eliminated but to make things easier strip out the Auto trans and ABS stuff and you will probably find that virtually everything in that clump of mess virtually falls out by itself.
It happened Again.Road Rage not my own...
Closing thread. This is more suitable for Off Topic than anything but probably wouldn't have been approved in Off Topic by every moderator/admin.
What to offer..80 Brat
I saw 2 parts cars at Pull n save of this era Brat today.
Junkyard spotted
Front wheel drive 79 wagon with right around 100K on it. I snagged three parts from it but if you own one of these and are local you really should go check it out. Its at Action Auto Salvage in Aurora CO , a pull a part yard with decent prices. Its kindof a golden yellow color and its an automatic. I grabbed the carb shield, DL emblem and the Automatic emblem from the rear lift gate. $3/ea plus cheapie shipping. Emblems are in VERY good condition. The car has A/C and the weirdest clutch fan setup I have ever seen on a Subaru. Sadly the car looks like it would drive out and except for the tops of the fenders is pretty much rust free.
Headers for 2.2
The Kennedy ones work really nice if you are putting it in a rear engine application. http://www.kennedyeng.com
Weber swap how-to
That'd make a nice USRM article... Junkie when u get it fixed up would you mind posting it in the forum?
Paintin the 84 (the gray one)
I plan on doing that exact thing on mine this week! Take pictures and I will as well....this could be competitive!!!
EA-EJ Adapter Plates back IN STOCK!! 8-23-06
Awesome service! Thanks again!
Co:Spotted a yellow mid '70s coupe on Kipling.
Yellow/blue no graphics I dont think.
