Everything posted by ShawnW
It's Halloween! My favorite!
Should be a fun party. What else did you say? My eyes only read this much.
Who has schematics for EJ stuff? pinouts for the ECUs?
Looks great man. One ? is the air box hooked down?
Did you try installing the 2.2 ECU to the 1.8 wiring and adding the couple wires for the knock sensor? Or are the 1.8 ecu plugs completely different?
Easy BRAT heater core clean?
Pull the glovebox and then pull the blower motor. Make sure it isnt full of it too.
Why are you messing with any of the wiring? The 1.8 stuff bolts right onto the 2.2 motor. The only thing you might have to deal with is an EGR valve and thats just a matter of drilling and tapping the head to accept the pipe.
EJ22 in EA81, wiring help please. <yet more help needed>
Box under seat is the ABS. Id use the ej22 relays myself but it could be done.
97 EJ22 into my 98 outback Need Help
Those are for the charcoal canister. Go back to the yard and buy the canister. I have a feeling you will get away with the EGR not being there.
Tracking Down Coolant Leak
"rent" from autozone a cooling system pressure tester.
Where's my canister? 97 outback
ShawnW replied to tlzorro's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIve got a 97 Outback and I cant find mine either.
Timing belt cover!!!
ShawnW replied to cyarmak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich cover is broken? There are 3 on the front of the engine and two that they attach to behind the timing belts and gears/idlers they turn with.
VSS#2 update Fri 13th
ShawnW replied to Skip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'd have to pull the trans. Youre right its a nylon gear in the ring gear section of the differential.
de-activate remote door locking beeps?
ShawnW replied to Garran's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook on the back of your remote for directons.
finaly some real suspension for my wagon!!!
The outback would be pretty easy. Just google Tein or similar companies.
1.8L motor opinion
ShawnW replied to hogweed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcellent motor especially for rallycross.
Really bad static/bad reception on AM
ShawnW replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe big ground wire above the starter would be a good start.
Denver mad scientists - transmission lab: Lab ingredients/forumula FOUND!
Sorry I should have clarified. Broken part had nothing to do with Subaru quality just somebody had to have hit something in the road to break the end link mount off.
Subaru Heaven
Do a search I have to have posted it in the past.
How best to ship glass??
Agreed, its tempered and actually pretty strong. I just PACK a ton of peanuts in and send it out. Fragile stickers wouldnt hurt either.
None made in the past few days I have been replacing the rear crossmember on our new Baja.
EG33 engine in a Corvair- Doable?
I am sure they do too. I saw one yesterday (corvair) and wondered how it would work. Add a heater core while youre at it.
ej swap......
All of the above plus there is not enough evidence to point to the SOHC 2.5's having better track records with head gaskets.
Salvage yard 5MT has torque bind
ShawnW replied to jjou812's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey fail real often. Id get a new one.
The gear I am having trouble with is always a problem. Got a great press its just a matter of heating it up, cooling it right, repeat.
Turbo vs Non-Turbo Head Geasket
Doesnt mean the OEM gaskets are bad though. Alot of them still running around on original gaskets.
Kits
Neither "company" is doing this as his full time job and demand is remarkably high for the product. Make a choice which one you want and then dedicate your efforts to being patient with them to contact you back. I would expect having to wait a week for a reply from either one at times. SJR would probably be faster to reply back to a PM here and Ozified probably an email.
