Everything posted by ShawnW
How to check Timing with light ?
Honestly, with that trans if you have all 3 gears reliably-be happy.
Yes. Cyl 1 is passenger front. 5000 is pretty typical on a 3AT under full load. I wouldn't do that real often-that trans isn't really meant for that.
Heads Up!!! 2012 Impeza Radio Install
ShawnW replied to The Dude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't have the AUX in the center console? Pretty easy to add to most models with a dealer part.
EJ20 Front Crankshaft Seal?
ShawnW replied to zenosparadox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless its a turbo I use a tapered pin punch thru the hole on the passenger side of the bellhousing. Its threaded and about even with the dowel pin (1/2 way down). It will lock into the teeth of a flywheel or the bolt of an automatic flex plate bolt. I also have the Subaru Special Tool for holding the crank pulley but the punch is much faster than setting up the tool. That can be used on the turbo engines and any that don't have the flywheel or flexplate still attached.
Dual Carb EA-81 Build
I think the ea82 carb cars had that when they were new, I bet most are broken and gone by now. Would probably be pretty easy to retrofit into an ea81.
1999 legacy air con not working
ShawnW replied to yewman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe cheapest I ever am for A/C is $99, that's EVAC, replace O rings, pull vac and verify no leak, recharge. Just the Freon itself is $20-25 and the oil another 3-4. I would be skeptical of anybody that is a professional shop doing it for less than the $100.
Do you use Fuel Injector Cleaner every 3K mi. as Subaru recommends?
ShawnW replied to mountainwalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am a BG Retailer and I don't push it that often. I include it as a part of the 15 and 30K services only. My dealer did the same. Every 3K is greedy to me.
Downside to 3.9 ratio
ShawnW replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbove I was asked why I wouldn't just change the trans bearings. The shop is pretty busy at the moment and it would be a lot quicker to just test out the trans from a car I parted out than to take the one out, tear it down, order all the stuff, and put it back in. I can have the other one installed in a couple easy hours and not tie up the lift long. I also don't like doing the input shaft bearing on a trans that I don't know how long its been bad. Many times I have seen the metal distorted on the case and that basically means the trans case is going to be scrap. I really appreciate the comments and advice. I think I will try the Impreza trans now. Might even be able to get my bore scope in the dipstick hole and read the numbering off the ring gear.
That's neat they had a cooler air duct attachment on those too. Never seen that on a US market car.
Any interest in new Gen 2 Brat gas tanks?
A bonus would be having the outlets be available as stock or EFI rated hose size for the fuel pump. And if they were all EFI baffled so people could skip having to add or have a surge tank for EJ swapped cars.
I still have a few setups laying around, just carbs and intakes/blue air cleaners. They are Jerry DeMoss's but being stored in my Attic at the moment with no plans for use at the moment either.
proportioning valve + rear disk swap (WTB: valve)
If I remember correctly it requires moving to the caliper, caliper bracket and brake rotor from an 83-87 Brat/Hatch/Wagon/Sedan or Coupe of the EA81 bodystyle. Should be a bolt in affair.
- Southeast Subaru mx and body shops
Hand disc sander.
If you can find a nice gently used one that is a few years old you might get an not Chinese made one too. Usually better. The Porter Cable or Bosch ones are my personal preference.
Painting in cold wet weather
And by all means watch the weather and be patient with it. Sometimes waiting 2-3 days can mean the temp goes up for 4-5 days in a row here and in the winter I see 70 degrees quite often. I think Portland is kindof similar to Denver on that sort of thing.
I certainly don't see it as a required item but nice to have for sure. The rear disc brakes are certainly less braking than the fronts-still smaller than the fronts, etc. It might be more of an issue on one with 80-82 brakes on an EA71/81 car but otherwise I dont see it being something you can lock the rear without locking the front on.
01 5mt into a 05 ob stub axle questions
ShawnW replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect. Only the Auto trans stubs are removable externally. I would probably take the inner DOJ cups off each and see if the splines on the CV shafts are compatible. But usually the axles will just work as is even with a little visual difference. Would help to post a photo of the outers so I can see.
Touch up paint for rims (2009 Legacy)
ShawnW replied to mattocs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich wheel?
o7 impreza have a fuel filter?
ShawnW replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTechnically in the tank and I don't mess with it unless the fuel pump fails.
Steering feels stiff
ShawnW replied to Speedwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the rubber at the steering u joint.
coolant temperature sensor location
ShawnW replied to AEIOU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen they are this new its 1 sensor that does both.
My 1982 GL Wagon 4x4 four speed
I usually beat the Ebay $320 price on those kits if people call my shop. Office open 2-6 mountain time. Same for any other Redline stuff if I can help USMB guys out I do.
Passing Emission
Most places, the muffler is for being legal on the street-not emissions but if there is a safety check involved then you might run into that. Old cats-if they work whats the worry?
3x Subie Fun in Denver
Let me know next time you go to the junkyard I might tag along. Nice collection!
What goes up... must come down.
I assume the camera is on/with you the whole time. If so it doesn't seem like you were that much further up than you were away in many points of the video. Loss of signal, or maybe the angle of the antenna system became too weak at that altitude and distance from your vantage point? All very impressive and the cost you describe is really amazing drop in cost over the years. A very neat project!
