Everything posted by ShawnW
Subaru Brake Tool 9255 90000
Anything that works to turn the caliper in. You don't push the caliper in with a clamp or press type tool it screws into the caliper. I have used a pipe with notches recessed in it for years and that works good or there is a cube tool that most auto parts stores sell.
New member just purchased 85 Brat
I think it makes it a little ugly but if it adds functionality for you then its worth it. I personally like the open bed, rollbar and seats in the back look the best.
Original brat roll bar fog lights??
My old Lenses say IPF on them. Never did any digging to see what "brand" that was.
Gen 2 shock inserts
Should be able to do either side, all the part numbers on my systems are just front or rear for anything before 84. I didn't know they used to be an insert without the perch on the 80-84, I knew they were for the prior generations.
I found a note on my Brat today
The Ea82 turbocharger, uppipe and downpipe would swap in, much easier to find one of those.
Gen 2 shock inserts
Front struts are adjustable or not and you cant switch the inserts the brackets are all welded to the strut assembly. Adjusters shown below in the photo, if they aren't adjustable they just don't have that. I believe the 4wd ones have a different height for the lower perch but I haven't taken the time to get them all side by side before. I believe a 233024 from KYB is going to work on any 4wd but remaining units that I can order are not adjustable. $60/ea
Spindle Nut Socket for rear wheel bearing on 80's Subaru's
I found a socket that works ok, its an Evercraft 776-9179. It only has 2 notches instead of 4 but it works. If anybody needs one let me know I can try ordering more.
Lifted Forester
Its a cool car but I don't think the video is very impressive. :cool:
Hatch got hit
Tried pushing the dent out yet?
Fiberglass 1st Gen Fenders
http://cosprings.craigslist.org/pts/3277893921.html
bouncing speedo
Its kindof a pain. If you pay attention to how it comes out of the speedo head while unrouting it and are careful with the threaded end its pretty easy. Allow an hour for it and be happy if it takes 20 minutes.
Axle Sets.
You have managed to install all the kinds that I know of that are habitual clickers so far. I will PM you some pricing on good axles.
'81 subaru
That's such a great year. I love the photo!
Good pictures of the tube work under my brat...
I remember seeing it in the driveway very shortly after he got it with a hole cut in the bed/rusted out and the gas tank removed maybe? I knew he was up to "no good" in a good way with the look he gave me when I asked him what his "fix" for that was going to be. Heck its a completely different vehicle from when he got featured in Subiesport even and back then it was awesome.
Iowa: CI4WI Timber Ridge Trail Ride, Sept 21-23, 2012
Cool! Post the photo you loaded up to Facebook!
EJ swap radiator
There is only room to do that on the lower side. The upper tank doesn't have enough room. I would start with a new one and have a shop put new one in unless you are good at Brazing.
bouncing speedo
Usually a little fluid in the speedo cable itself. The seal in the transmission lets it suck up into the speedo head.
99 legacy rear spindle wont give up axle
ShawnW replied to natext6's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAutozone has one that works you can rent it for Free/$25 and take it back to get money back.
Salvaging Trailer Hitch
Pretty sure its just 4 bolts that are accessed from under the car. Should be 14MM bolt heads.
Moving and overwhelmed with the stuff in my workshop!
I will say, 14 at once is pretty "smart."
Temporary Spares - Vancouver BC
The place I crush cars at will remove the wheels at the yard for me. Might inquire on that.
I did one years ago, I recall taking the rear compartment lid open and having to drill thru in specific spots thru the tunnel of the frame but it may have been a different brand. I wouldn't sweat it, just start removing the bumper, remove the bolts securing the hitch and make a few notes of how it was.
Denver 95/96 2.2 in the Yards?
ShawnW replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLarry has done a bunch of these swaps. Ill watch but I haven't had time to hit a yard in weeks.
83 Feedback carb problem
Is there a part that would make the car run strange only about around 52-55 MPH and above? At 45-50MPH its completely normal above that it surges and feels really weird like a sensor or something is angry. Doesn't matter what gear or how hard you drive it just seems to be speed related. Could I just unplug the ECM to see if its there or would a bunch of the other parts/sensors not work? I have always avoided this system and would just 'put a weber on' but the owner isnt going to like that idea and is very gas mileage orientated. The car is ea81 sedan FWD 5spd manual.
Half Depth radio fits GL $19 @ walmart.com
Says out of stock too.
