Everything posted by ShawnW
83 Coupe Love ..Restore Progress ( Pics page 2)
You are kind of inspiring me. Back in 2003 I brought back a 1983 Turbowagon from Washington state and I have probably towed it more miles than I have driven it to this day but the story sure sounds similar. I have a power drain and to make things worse I dont know if its the car or the 2.2 swap or stereo or god knows what else that I have wired over the years.
5 stud/lug conversion - Crossbred Performance
So how many would be interested in the kit? I am working on setting up the first order and would like to know who would ACTUALLY buy one. The whole kit not just parts of it, and then those that would buy just the rear or just the front. Remember doing just the front means you will have difficulty in having an emergency brake which I am pretty sure is illegal to put a car on the road in the US without and just plain dangerous if it is legal. The price might seem high but by the time you buy Peugeot wheels, lugnuts or lugnut adapters you have spent some cash and have a rare and not always attractive wheel and tire combo. This opens up the wheel options and improves the brakes a great deal. If you bend a Peugeot wheel how many spares are available compared to a factory 5 bolt Subaru alloy/steelie? And are you going to be able to buy anything bigger than a 15" Peugeot? I love how these cars look with 16" WRX wheels...which are very cheap on craigslist at times.
fuel sending unit
Id agree clean the contacts. You can ground one of the wires and if the gauge rises to F your gauge is good too. Any Ea81 non digi dash car except the hatchback will have the same sending unit. Be real careful with the nuts on the tank to sender connection those little guys can snap off easy. Penetrating lube a few days in a row and then try with a very short 1/4" ratchet and shallow socket.
Center Lamp Relay Location
Me too. Pretty handy to have something that can stay on with the key off.
It says mitsuba on it and is black 2" square with the plug pointing out the bottom of it likely a clear 4 wire plug.
What 1 Iowa Winter Does to a Crack In the Subframe
Might be why I moved away. bheinen74: Park the brat winters. You'll be glad you did. I think I saved pictures from an ebay auction for the brat I owned before moving out here and I am sad to look at them. Entire rocker panel destroyed.
Removing 14mm 12pt. stripped cylinder bolt head
ShawnW replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy not just drill the head of the bolt off and then slide the cylinder head off and work it out from there?
Subaru 360 van Dyno day
Thanks for sharing I learned a lot. Not sarcasm. Love the walk around video with your daughter being able to circle them most of the time staying on pavement on a 1 lane driveway without scratching the sides. As a kid my parents wouldnt let me ride between the cars for fear of scratching the sides with the handlebars. Probably because they were Fords at the time and ate the whole driveway.
Wcss 11
Stickied thread to get some more interest and support the organizers. Ill host it here in Denver if need be to keep the shows going but even I would prefer to drive out to see the PNW crowd again.
'82 Brat: Solid Axle Build *** DONE! :) ***
push on!
Yes!!! Fond memory. Well photographed by Subiesport no less. That photo hangs in my garage next to the workbench for easy reference!
Northern tool MIG 135 review
Ive got a Hobart handler 135 and I love it. Works well and transports easy. I loan it to friends quite often. If you lived 2 hours away like the good ol days I would drop it off.
06 Frstr 45k what mtnce is due?
ShawnW replied to mattri's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you miss the 30 K service? At 30K we do: All FLUIDS except Brake and that wouldnt be a bad idea too. Rotate and balance tires Air filter Fuel filter (dont think yours has one anymore) plugs Adjust belts if necessary Lube hinges Fuel treatment (We use BG 44K) Battery service. Load Test, charge, and clean terminals and add battery pads. You should consult your owners manual and do everything it says to do that you haven't already done in the maintenance schedule. If they did a flush they were supposed to use the SUPER type ATF and if they didn't you need to complain.
Link EM Install finished
ShawnW replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think the impressive part is all the years that you have had that car and its just as sharp as ever. Didnt that car start as a NA 2.2 car too??
Just picked up an '85 Brat
That looks like the one that "The Yeti" bought from a lady out in Byers a couple years ago. Same color and same topper. If it is it has some rust on the shock towers but overall is in pretty ok shape. I might be interested in buying the topper if you want to get rid of it.
For the Vanagon guys.
Ive bought from these guys and they are great.
have a junk manual trans...
make a clutch align tool out of the shaft! Works alot better than a plastic one!
Bunce school Road from 4/19/09
COOL! Thanks for sharing.
new brat.. new projects
That is one nice looking barn! And Brat!
Mpfi>>>spfi
And you lose HP. Might as well just put a carb engine in while you are at it. Sell the spare motor if you already have it and start the 2.2 conversion.
EJ 2.0 vs EJ 2.2
It would be a good swap and bolts in exactly the same. Do it. The mileage could be better slightly of course would be a pro. Con lower power but not much.
California SMOG : from Sconnie to Cali
It actually is a crime to drive around long term with out of state plates so you could say they are doing their job by patroling for that. Why not reinstall the o2 sensor and put a legal exhaust on it? I believe in taking care of my cars, and I actually like knowing that they pass emissions. I find they run better and I take care of them more when I am required to pass. My cars get better mileage this way as well. Check the law books but you may be entitled to not have california plates if you are temporary resident and some do live there for college or other reasons that may actually legally allow you to maintain Wisconsin residence and drive there completely legally. Just check and if this is the case you dont have to get a Cali drivers license either most likely. Otherwise look for a smog friendly loyale in California to buy and bring it back to Wisconsin when you are done living there. The car will likely be completely rust free and you can use the one you got in Milwaukee for parts.
06 Baja Wheels on an 06 Outback? Or...
ShawnW replied to yojimbo11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey will all work its just a matter of what look you want.
A question on the Coolant Additive for Phase II Motors
ShawnW replied to 3Pin's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlame the people that banned the use of asbestos in head gaskets. Its no conicidence that the failures started popping up with the 2.5L engine and the head gasket material change also happened at the same time. I understand the damage asbestos can do but a head gasket is not being breathed in like insulation in your home.
wind noise
ShawnW replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are fixes for it but a lot of the time the driver is what needs repaired. By this I mean.... Stop closing the door by pushing the glass. The gusset as it is called, can be replaced for around $100 in parts or you can take a rag and with the door open compress the rubber with a very large pair of channel locks. Do so gently but evenly. It will tighten the gap for a while. This may be what the dealer did at 11K. I never heard of the shim but that was before I was a tech.
