Everything posted by NoahDL88
Good, Cheap CB sugestions?
I have a 102 inch steel whip, the twangy twangy kind, i can't say as to weather it works better than a shorter one but it looks cool and i can hit stuff 12 feet tall. gets in the way sometimes, but if you get a fire stick or the like make sure you get the spring that goes between the antenna and the mount, just ask Tex and Austin if there worth it.
I bought the wrong radiator...
Chongo, check your thermostat, if its working porperly, no matter the size of the radiator it should put out heat.
need tires
bigger tires will make her feel slower because of the change in gearing, i'm running 28" swampers and can really tell the difference even with a manual. depends what you want it for, on road, i'd stick to stock, but if you are going for looks or offroad, bigger tires may slow you down but thats the price you pay to look cool, and go like stink in the mud
Stub axles?
Yea i love subaru engineering, everything is easy to fix, except for the axle count and the timing belts. other than that they seem to be the easiest cars to work on, i got the old axle out in less then 15 minutes, it took longer to get the new one in, i ripped the boot a little on the control arm but siliconed it right up no worries. i can hear my self think now that the bearings arn't growling like a cat in a plastic bag. (no cats were harmed in the replacing of my axle)
sway bar question
If you can get the hubs and such off the xt6 front and rear concider yourself lucky then you can switch to a more practical 5 bolt as opposed to the 1 on 140, as far as switching over tex should know about it along with a few others
Stub axles?
As i said, i DIDN"T think they fit, but you are correct they do just enough to screw everything up. i got the right one and everything is a ok
white sludge in oil filler cap
I would say head gasket, one more good way of telling is to look for bubbles in the radiator. take off the cap, when the engine is cold and check for bubbles coming out, thats a sure sign of either a cracked head or head gasket giving you problems, do a compression check and find out which side, it may save you some time and money.
Gas? Fuel? What is it? *EA82T Performance Thread*
I'm not saying that advancing the timing is the end all be all of performance mods, but yes to a point advancing the timing increases the horse power. My point is that switching from 87 to 93 and not doing anything to the car will not do anything at all except hurt your pocketbook.
just to set the record straight, just running a higher octane gas will not increase hp, its the advancing of the timing that increases the power and its the octane that allows the timing to be advanced.
Changing oil
with oil you do get what you pay for. although all the oils on the shelf should have the starburst and the donut, if they don't, don't run them ever. name brand oils will surpass the standards as opposed to just reaching them. i would also reccomend using the oil viscosity that was reccomended from the factory unless you are burning mass oil, when you run a thicker oil it takes longer for the oil to make it to the moving parts, this adds dramatically to the wear that your engine experiences. I run castrol and FHI filters, thats what it got from the factory and thats what she seems to run best with
Bumpers, She's mean now!
the price was about 300 with shipping, depending on your options and picking them up yourself you could probably get them for around 200 ish
Soobme I haven't had a chance to put the spacer plate on, the bolts are too short, like a quarter of an inch. i have intake bolts that will take care of that though, i have an axle problem that is taking precidence. Amanda I will get a new sticker pick, just as soon as i get the new stickers on the car, when it gets above freezing.
Stub axles?
I didn't think that the 25 fit on the 23, oh well, i'll have to try that on thursday when i get another chance to work on it.
Stub axles?
I did the frond wheel bearings on my 88 and they were a breeze, however i also changed an axle, and when i went to drive away the axle pin sheared. i'm sure it was in far enough, but the problem is why? it feels pretty good, maybe a little loose on the stub axle but it shears. And now for the question, are front and rear stub axles interchangeable? cause if they are problem solved, if they arn't well then i'm in for a world of hurt.
I got the new bumpers on the 88 DL this weekend, and i dare say she is looking mean now. http://usmb.net/gallery/album110
shaking and vibration problem
do you feel the shake in your steering wheel or your seat?
Anyway to remove the clutter on engine?
The gas cap check is for hydrocarbons, and evaporative emissions account for 80% of them, usually through the gas cap, you may not see the benifit of a gas cap check but i'm sure your grandchildren will.
For your listening pleasure.
That sounds too cool
Block spots
Its not corrosion if its on the main journal surface, its aluminum and won't rust it will corrode a bit but thats only places that are not exposed to oil, its a hot spot, thats not good but its not particularly bad either, call emily at ccr and she'll help you out, they are cheaper than trying to rebuild it yourself
TWB Testimonials Needed.
I have one sweet set of front and rear bumpers, i got them on the car in less than 12 hours after i got them, i had to go to class first but as soon as i got out, despite the 0 degree weather i got them on, i do have pics but the resolution is too high so i cant post them, if i can get the go ahead for the gallery i will get them up asap.
ea82 wagon t-case lift
Not if i do it first, however i will need to graduate, in may, and find a job, yeah right, with this economy. so if you do it within 1 year you will very easily have me beat, and i say go for it, that way i can learn from you, but i would second the learn from mudrat, he is the guru of T-case mods, there are a few others on the board like littlebrownmule or unhatched, i don't recall what his screne name is.
EA-82 died on the highway
if its leaking out the timing cover it could just be a bad water pump, give it a good once over, don't pull the engine unless you have to, if the pump got kinked the timing belts could be a good time to replace them, along with the front cam seals and an oil pump if it looks old. if you see a visible crack in the side of the block you may be able to jb weld it shut, they have great 2 part epoxys that will hold most anything together.
improve gas mileage?
Don't you think that if there was a SUPERCARB that got some sort of insane fuel economy we'd be using it. fuel injection is a much better system for fuel economy and performance. there is no carb, there never was or will there ever be one that gets 100 mpg. granted our government, especially the current one, is bowing to the oil companies to give them what they want, and if you were an oil company you wouldn't want new cars to burn less gas.
rebuild: cam holders and valve springs?
try ram engines, they have sets of springs that replace the inner and outer with just one spring, they have the same approxamate seat pressure so they won't ruin your seats but they have more stiffness then stock. http://www.ramengines.com
Jason had a Boy........:)
Can we still contribute to the memorial fund?
