Everything posted by NoahDL88
Waterwagon 3 Build-up, and the SJR+EJ Lift Thread!
It happens, I used to be shy, but now I'll start up a conversation with anybody riding a motorcycle, driving a subaru, or wearing anything from Michigan.
Yeah, that was us, I was in the blue Leggo next to his
waterproofing 1990 loyale
you'll need to run hoses up the "A" pillar for all your vents, tranny 2, rear diff, the powersteering cap is closed pretty tight, i wouldn't worry about that as much, just make sure you have a good seal on that one. Seriously though, its a waste of time, you can get every fluid happy but you'll still be soaking connectors and wires, so you may have to junk the car anyway, except it will have some good looking fluid in it instead. you can get 207S bearings for the front wheels, they are sealed and are less likely to be ruined by water crossings. An older diesel has no electronics so you can cut the distributor entirely. Its fun going through water, don't get me wrong, but its just not worth it to "waterproof" your car
cheap go fast goodies?
we need to let this thread die, the OP already tried stuff against our recommendations and now his engine is dead Where is the I told you so smiley?
97 obw wont start after airbags deployed
NoahDL88 replied to ssheaven's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasiest option is to find a replacement engine, you can probably get one from Japan for less than 1200. Or, you can pull the heads, replace the valves and make sure the pistons are happy. which will cost you about the same.
so i messed up and i need help
NoahDL88 replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXgo back to stock, make sure that you haven't picked up anything in your air filter, you'll clog an airfilter quick with a CAI. Make sure your IAC is connected still. BTW, all Subaru's come with a CAI stock
Marvel Mystery Oil in a Gen 1 Brat???
Naptha is a petroleum distillate. What ever it is, its good stuff. I'm also a big fan of Seafoam, but that's for a different application.
It looks and tastes like trany fluid. Also, based on the MSDS both MMO and Dexron have a great deal of Naptha and mineral oil.
New Subi.... *Updated*
The Loyale is single range. Nice body though.
ej18/ej22 best power combo
NoahDL88 replied to huelsdonk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt was meant in good fun There are a few online subaru parts stores, a few are good, a few are bad. In Seattle, Carter isn't bad, and the online parts from Walker's is pretty good.
NoahDL88 replied to huelsdonk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't believe that there is any performance gain swapping EJ18 parts onto an EJ22. Stick with the EJ22, its bigger, has more power and is bullet proof if you don't overheat it. As far as finding Subaru parts Linky
2.2 getting hot
NoahDL88 replied to RussellW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the thermostat is installed correctly, if its backwards it won't open correctly. I would get a genuine Subaru OEM thermostat, aftermarket thermostats seem to be hit or miss.
$900 for clutch and labor?!
Can you do it in 8 hours? Did you spend good money on an education to learn how to fix cars? Have you taken the time to get certified by your local state and or ASE chapter? Have you taken the extra classes provided by dealerships to make damn sure that when someone comes in with a car that you are trained to fix it and not taking a shot in the dark? Have you spent between 5 and 15 thousand dollars on tools out of your own pocket? Did you spend extra money on tools that are specialized so that you can complete the 16 hour job in 8? Mechanics are a bargain considering what you get for your money.
flat rate labor times are standard, so the difference in price is usually due to different labor rates, between 80-120 dollars an hour. If you go into Schmucks and buy a clutch kit you get it pretty cheap, but the Dealer/Mechanic wants to make money on parts too, so there is a markup there. If they replace or resurface the flywheel there is going to be between 50-150 dollars into that. 900 bucks for a clutch seems high, but not horrible. If you agreed to it, you're liable, if stuff was done without your permission above and beyond the quote, you can ask them to return it to the condition it was in and not pay. Separating thoughts into different paragraphs make it easier for the rest of us to understand what you're trying to say.
its still mostly tranny fluid :-\
Its a cleaner, more than an anti wear additive, i believe its mostly tranny fluid.
It can help with lifter tick, but ultimately we can't know if it will help your brat unless we know whats wrong with it. If it has a flat tire, MMO probably won't help.
180 degree or 192 state
I usually go with Bowwow on Filbert road. That is if i'm not going OEM
Any problem ditching the driveshaft, differential, rear axles on '84 4wd wagon?
the driveshaft is the plug for the back of the transmission, you'll loose fluid out the back of your transmission
192 is out of the service manual.
Bad Gas Mileage
NoahDL88 replied to mccullough's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen is the last time you did a complete tune up? How much stuff do you have in the back? bags of sand, bricks and the like. Plugs, wires, air and fuel filter can do wonders. Your O2 sensor may be sluggish.
I'd stick with the stock one, which appears to be the 192 degree thermostat. It will run more efficiently and have more power.
ok, here we go again: part deux
Are you talking to me? I know Brian is one ugly mug, but that fabrication is just too pretty.
automatic seat belt retractor stuck
NoahDL88 replied to Fordman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a common failure. if they don't warranty, which i believe is a 10 year, not a lifetime warranty. Easiest fix is to get replacements from the junkyard. Won't hurt to call Subaru though, they might have them, even if they don't replace them free.
Glad to see the air intake hose worked out for ya.
