NoahDL88
Everything posted by NoahDL88
  1. Run the wires into the cabin and put it under the steering column with the stock unit, much safer, drier and out of the way.
  2. There is a rubber dust boot on the end of the throttle cable that keeps dust from getting in and the lube from getting out. On my DL it fell apart and worked its way in between the cam and the throttle cable holding the throttle at about 25%, which unloaded means it got to red line pretty quick.
  3. +1 Without the clear coat you'll just be flitzing again in a couple of months.
  4. Make sure the ignition wires are all still connected. I've seen timing belts appear ok, but have sheared teeth under one or both of the pulleys. Try to narrow it down whether its a spark or fuel issue.
  5. Actually, you use the drive train to turn over the engine, the alternator has nothing to do with it. ever try to pop-start a dirt bike on a gravel hill?
  6. Fresh, where are you located? I have one lying around I'd be willing to give away. Its 22 years old, but it worked when i parted out the car.
  7. I've used them in motorcycle tires with no ill effects, and i assure you those tires spin much faster then a swamper, based of both circumference and top speed.
  8. For reliability the Suzuki 650 twin can't be beat, mine got me to and from Mexico from Seattle without any troubles, and I'll be heading south again in November and should hit 60k on the way back.
  9. I like my SV650, and it was my favorite until i rode a V-Strom 650, put 57k miles on that one in less time then it took the SV to get to 14k It does have fairings, but that makes it nicer in bad weather. Stay away from Harleys, you'd be buying an image instead of a bike. The Honda Shadow 750 is a great bike and will run circles around a harley any day of the week, and will stay running forever.
  10. what pump are you using?
  11. a fuzzy bracket? what do i win?
  12. check resistance in your wires, should be around 800 ohms per foot i believe. if you have a second set of wires try those.
  13. ask them to clean it off, if they are a reasonable dealer, they should clean it off. if they were a good dealer they would have cleaned it before you had gotten it back.
  14. recheck your connections. I believe that your yellow and black wires are backwards, but wait until some one else agrees. if the disty is used it could just be a bad one. Make sure there is a rotor inside the disty.
  15. glad i searched, was just about to post this as a new topic, been catching up on http://www.hulu.com
  16. The stock intake will flow up to around 300 hp without modifications, unless your car is a turbo i wouldn't mess with the intake, and even if it were there are much more effective ways of increasing power. Remember, if you increase flow via an air filter (K&N), its letting not just more air in but dust, dirt and sand as well.
  17. There may be a problem with their servers, should be fixed soon. The motorbike forum i'm on is on the same server and thats down too.
  18. http://en.wikipedia.org/wiki/Northern_Alliance Just sayin, Northern Alliance may not be the best idea.
  19. they still don't work for me, maybe I'm just not smart enough
  20. well 2 your small battery issue and your pics didn't show up
