438
Do a standard timing belt/water pump job on it and see how things go. If the thermostat has been removed or gutted that's a typical sign of head gasket failure. The fact that the lower hose is cold is a sure sign of trouble. Subaru's do not mix coolant and oil when the gaskets fail. They pressureize the cooling system with exhuast gasses in nearly 100% of EJ22 and EJ25D HG failures. GD
You don't need a lift and most yards will have the cars high enough to drop a tranny or will roll it on it's side with a forklift, etc.... usually if you just talk to them they can make it accesible for you. You don't need a lift to put one in. Just a jack and something to jack the car up onto (6 ton jack stands are inexpensive at Harbor Freight). Prohibitively expensive. Minimum of $1000 to rebuild one and typically it's more like $1500. The parts alone will be around $800 typically. To rebuild a transmission you need at LEAST a press, proper bearing splitters, etc. Besides normal hand tools of course. The good news is that the D/R transmissions typically last the life of the car - not unusual for them to last half a million miles without failure. If they aren't abused and someone changes the gear oil every 100k or so. GD
ea81 hitachi issue, bowl vent?
GeneralDisorder replied to TajMan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The stock Hitachi can run pretty much stripped down - but you have to be careful about how you hookup stuff and if you have one that needs the feedback computer there are some serious challenges for most mechanics. I'm fairly confident that with a wideband O2 sensor and some trial & error I could orifice the metering ports well enough that it would run pretty decent overall. I don't expect most people that would want to try and run the Hitachi have that kind of equipment or skill though. GD -
Replace or grease up the u-joint between the steering column and the rack. Some of the joint is rusted and binding. GD
A bad slave will not cause slipping. If it's slipping then the clutch is bad. The pedal sticks to the floor when there is air in the system. It's a complex little system actually and hard to describe. After you have bled a few and changed enough slaves you get a "feeling" for how they work..... but your problem is not the slave. GD
Franken Engine Harness, Lets talk shop
GeneralDisorder replied to NoahDL88's topic in Subaru Retrofitting
I have the neccesary documents to strip the OBD-II harnesses.... as Chux does. Some of them I think I got from his site in the first place actually . For the most part you don't really need too much documentation - especially if you label connectors as you disconnect them on the donor car. I have a more tedious time when I strip harnesses for people because they never label the plugs. After a while you begin to recognize them on sight and it's a lot easier..... generally speaking on the OBD-II harnesses.... if it's a water-tight plug on the engine bay side you will probably be keeping it..... I start by removing large sections of the harness that I know I won't need - stuff on the dash side that's obviously gauge cluster and steering column wireing.... any wires that head back into the ECU bundle I leave as long as I can. From there it's just a matter of following the wires from each plug that you think can be removed and deciding if any of them go to the ECU and if so what their function is and if you want to keep them or not. That's where the ECU pin-out's and voltage charts come in handy. That's pretty much all I use - diagrams that show the ECU pin numbers, wire colors, and functions, and the ECU pin-voltage charts. GD -
how do you replace headgasket on a EA81T
GeneralDisorder replied to tlp8ntball's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Best way is to pull the engine. Better way is to push it off a cliff and forget you ever saw the EA82T. Poor excuse for an engine in the opinion of most around this board. GD -
Have you verified that the valve timing is correct and that the cam pulleys have not moved on the nose of the cams? Checking the timing marks is not sufficient because those will not be out of alignment unless the belt slips. The problem that I related in my earlier post was that the cam sprocket had moved on the cam itself - the belt was perfectly aligned and a check of the timing marks shows nothing. You actually have to tear it down. The ONLY problem the ECU could detect was the misfire. Also have you checked for a bad battery or engine ground? Grounding issues can cause all kinds of problems. I just got a Legacy where the engine was torn completely apart by an amature looking for "sensor" problems when the real issue was an almost completely severed ground cable that couldn't be seen because it was all inside the insulation. Sometimes you really have to dig for this stuff - but it's always something that you assumed was a constant when you started looking - like the valve timing. Your mechanic probably looked at the timing marks, found them to be correct, and dismissed that as being a potential problem. Now that you can't find the problem anywhere else it's time to revisit those things you took for granted at the begining of your search. GD
The 90 to 94 OBD-I harness is not a good choice IMO. The '96+ (95 is weird and to be avoided also) is easier to strip as there is no SMJ and only two extra plugs (The OBD-II port itself, and the rear O2 sensor plug). In addition, the OBD-I computer doesn't seem to like cam changes while the OBD-II stuff seems to be much more tollerant. The idle fluctuations with cams on the OBD-I ECU is pretty pronounced. Personally I have decided I won't do any more OBD-I harnesses for my own swaps. The OBD-II wins on all accounts - easier to strip, handles mods better, and it's code-reader compliant. I have not seen an issue with running lean - even on the OBD-I. The frankenmotor is more effecient due to it's high compression and the EJ25D uses the same injectors as the EJ22..... the overhead seems to be adequate. GD -
If not using AC, is belt required?
GeneralDisorder replied to TweedleDee's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The casting of the idler under the green screw is hex shaped so you can slip a socket and breaker bar over it to use as a tensioning lever. Then you can tighten the blue bolt (I can't recall if there should be a normal nut or a special one back there that prevents it from turning) and it will stay in place till you tighten the green one. GD -
Can you have rear WD only
GeneralDisorder replied to WASHroad's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Generally speaking the rear components aren't beefy enough for anything other than a stock-power EA series engine. You could upgrade them to handle more but the next weakest link is the 1:1 rear output gear set inside the tranny. Drives from the pinion shaft to the shaft that runs the driveline.... you'll strip the teeth right off those gears. GD -
Introducing my new BRAT!!!!!
GeneralDisorder replied to 98ImprezaWA's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sweet - glad it was simply a bad fuse in the tail lights, a loose charging fuse, and run-down battery. Easy stuff . Definitely take it for some longer drives . GD -
Yep - it's fully seated. You're good to go. Line up one of the ears with the location of the access hole on the engine side so it's easy to stab in the first flex plate bolt. The difinitive test is that as you rotate the TC you should be able to just barely keep it from touching the starter gear. Usually if you just spin them without supporting them in the center they will "grind" against the starter gear till they are pulled forward away from it by the flex-plate. GD
I'm in Portland and if you want me to take a look send me a PM, or an email - cropperr (at) gmail (dot) com. It is possible that you had a piston strike a valve and bend it ever so slightly - this will cause it to not seat completely - and the tapping would then be the rocker arm out of adjustment. You should immediately verfiy the valve adjustment with some feeler gauges. If ANY of the valves have an excessively large lash adjustment then they have been kissed by the piston and are no longer closing straight. That said - IF it's timed properly - you will not get any further piston/valve interferance and it is perfectly safe to run it unless a valve should stick in it's guide or something. With a perfect EJ22 you should see 180 to 190 psi of compression. 150 is low and could indicate a slightly bent valve on an otherwise perfect engine. There's a good chance that you can run it in the short term simply by adjusting whatever rockers are loose..... it's not ideal but if you lack the funds to properly repair it at this time it will get you down the road. Let me know if you need me to look at it and make the call for you . GD
Hitachi solenoids, schematic ea82 brat
GeneralDisorder replied to MilesFox's topic in Subaru Retrofitting
The idle cut is neccesary as without power you will have no idle circuit - just give it +12v. It grounds through the carb body. I don't think you will need to power the bowl vent solenoid. But it's similar... +12v will open it so the bowl is vented - in case you think there's a buildup of pressure or something in the bowl. I've never bothered with powering them. Without the computer they are worthless. They require a square wave signal from the feedback computer.... the frequency of which is based on it's reading of the O2 sensor - they regulate airflow to the high and low speed circuits of the carb..... I would make a note of which ports they connect to on the carb and then likely cap them off at first..... if the mixture is too rich you can then progressively orifice the ports till you find a happy medium. Yeah - or just replace with one from an EJ engine that's newer and known to be good..... they are smaller and much easier to work around, etc. You can also weld up the holes in the EGR valve body (cut off the diaphram portion) and use it as it's own block-off plate. GD -
You have to consider that the stock 55 Amp alternator only puts out about 20 to 25 amps at idle. If you are pulling 8 of that for your stereo amp.... not much is left for the rest of the car. Alternators (generators and motors in general) are stupid - REALLY stupid. They will attempt to give you whatever you ask of them. If you ask for 70 amps from a 55 amp alternator - it will do it for a short time (till something overheats and gives up) because there is no fail-safe system in place to prevent it from doing so. Electric motors act similarly - if you ask for 10 HP from a 5 HP motor..... it will try very hard to give you this. In fact it will probably catch fire and burn itself down trying! Not funny - I've seen 4 foot flames shoot out the rump roast end of some rather large electric motors being over-amped. In addition to that, the Amperage "rating" of an alternator is at cruise RPM. Usually 3600 RPM for the alternator which is around 1500 RPM for the car's engine. If it's idling at 700 you have to derate it accordingly. The battery acts as a buffer and will supply some of these amps - but the battery is a double-edged sword because due to it's nature as an electrical "sink" it will drink as many amps from the alternator as the poor thing can make if it's drained. That's why you never hookup a new alternator to a car with a dead battery and then just jump it and go. The battery will take everything it can from the alt and drive it at max capacity - which they are not rated to produce for any reasonable length of time. A 55 amp alt will not survive long if you ask it for 55 amps all the time. They simply arent rated for 100% duty cycle. GD
Dash lights illuminating are almost always a result of rectifier failure inside the alt. That doesn't neccesarily mean the regulator is bad - though it sounds weak from your voltages. It should not dip much below 13.5 even at idle. Check for AC current off the back of the alt - that will defeat the diode protected christmas tree lights and cause them to come on. I think you have a bad rectifier and are getting some quantitiy of AC current superimposed on your charging current. It's worth the peice of mind to get the Subaru reman unit for $75. They will take the Autozone POS for a core GD
EGR should default to closed - being they are only used for cruiseing RPM's and higher. The solenoids on the carb..... are you refering to the idle cut solenoid, and the float bowl vent solenoid.... or are you talking about the feedback duty solenoids that run the high speed and low speed mixture control circuits.... those are usually on the manifold not the carb itself. GD -
Run it. It will be fine. Given what you describe under the valve cover.... you have a very nice example of a low mileage EJ22. I wouldn't worry about it in the slightest. The difference you are feeling in compression has likely everything to do with how much the lifters have bled down and the orientation the engine was stored in and where the oil was/was not. Squirt some MMO in the cylinders and fire it up. Rings are not an issue with Subaru engines. It just doesn't happen. You are overthinking this - just run it. GD
Replacing an EJ25D with an EJ22... nightmarish
GeneralDisorder replied to jarl's topic in Subaru Retrofitting
And yes - it would be stupendously stupid to open up the engine. If it turns out to be a pile of crap - take it back and get another. I've done it before. That's what warranties are for. If you were going to do that..... I have a company here locally that will 100% rebuild your EJ25D for $1300 and they have one in stock ready to go - you bring your core and you leave with a new engine. They build them like an assembly line almost - lots of demand around my area. GD -
I wouldn't worry in the slightest at how long it's sat. I've done a lot of engine swaps and that wouldn't even register on my "Oh $hit" scale. Check for any abnormal thrust play in the crank - if it passes that test and comes with a warrantee and a compression test result - go to town. Repair as needed - engines come with busted and problematic bits on them all the time - rusty oil pan is par for the course. Replace and move on. New timing belt, water pump, idlers, cam/crank seals, plugs, wires..... etc - that stuff is par for the course and usually REQUIRED to maintain the warrantee from the "dismantler". I do them every time. The only parts that can't be transfered to the next engine should it be a dud is the cam and crank seals. Those are cheap. Not even worth mentioning. Drop it in and go. Sounds like a great candidate with low, low mileage. You will be grinning from ear-to-ear when it fires up. GD -
If it's not a Subaru reman alternator - ditch it and get one from the dealer. They are only about $75 because your model year had a recall on them. I've seen countless examples of aftermarket (NAPA is especially bad from my expeience) alternators for Subaru's lasting only 6 months or a year before subsequent failure. The reman one from the dealer will be the last one you buy. GD
