1998 Legacy GT coolant change FAIL
GeneralDisorder replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPoor quality parts were used if this is failing 9,000 miles after replacement. Replace it all with Japanese parts. If that's the quality of water pump used..... I would be questioning all of it including the head gaskets and the labor. GD
GeneralDisorder replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou have a bad water pump. That leak is from the "weep hole" which is not visible till you remove the pump. You don't want to run straight water in the system as it has no shaft seal lubricating properties like coolant does. The pump was likely on its way out already though. GD
Critique My EJ253 HG/TB Repair Plan!
The D pistons don't have valve reliefs because of the dish. The 2.5 turbo pistons similarly have a dish (with a dome in the center) and don't need valve reliefs. All the others have them. GD
- 105 replies
- gasket
- timing
- timing belt
- oil leak
Tagged with:
D pistons have a square dish in them. 251 pistons just have valve reliefs without a large dish. GD
- 105 replies
- gasket
- timing
- timing belt
- oil leak
Tagged with:
Yeah they do that. Piston slap that is. Are you running 251 pistons? Cost for knurling is $120 per set. You will have to file them down to fit each cylinder. GD
- 105 replies
- gasket
- timing
- timing belt
- oil leak
Tagged with:
2010 forester heater core replacement?
GeneralDisorder replied to Mallory's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it's producing heat on one side of the car then the core isn't the problem. It's some type of flapper door actuator problem. And yes depending on the problem it may require substantial dissasembly of the dash. GD
Oil usage Forester
GeneralDisorder replied to milty60's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplace the PCV valve. And stop using 20 weight. Run 5w40 synthetic. GD
Coolant stays in overflow, but only when the heat is on.
Check the seat on the radiator filler neck. If that's not it, then I would suspect the coolant cross over o-rings. Pressure test it well above operating pressure. Like 20 psi or even 25. You'll find the leak.... GD
Rod Knock 2004 2.5 Forester
GeneralDisorder replied to Souperoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt doesn't work like that. The crank will be trashed besides. We never reuse cranks. 100% new replacement. DO NOT split the block. The skills required to be successful at it are hard won. Without hands on training the first time is sure to be a total failure. GD
Need some advice on my Hatch
Failing to idle but having enough power to drive is not a indication of fuel pump problems. Fuel delivery problems would get worse as demand for fuel (engine load) increases. Idle is the least load/lowest fuel demand condition. GD
- Frankenmotor choices
WRX boost levels?
Should be closer to 1 bar. GD
Rotary Powered BRAT?
It's been done. But Mazda rotary engines are garbage for reliability so it's really a pretty poor idea to put one in..... anything. GD
Valve spring recall
Timken doesn't make wheel bearings for Subaru's. They buy them from NTN or NSK - one of the Japanese manufacturers that makes them for Subaru. They do this to "fill out" their catalog. What you bought is most likely just an OEM bearing in a Timken box. GD
EJ25x block differences?
I wish I could. I hate working on EVO's. But the owners are crazy and they bring in 50% more labor for virtually any job that isn't spark plugs. English Racing makes an absolute killing off those fools and I've witnessed their "work" first hand. No comment. GD
2002 wrx oxygen sensor eliminator??
GeneralDisorder replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTake the car to a competent shop. You have screwed the pooch. GD
GeneralDisorder replied to Wildem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEasily tuned out with a Tactrix cable. But illegal. GD
Weberized ea81 stalls when turning left
It does sound like the float needs adjustment - but also check your fuel pressure. With a gauge. GD
Any engine I can swap with a 90 loyale?
GeneralDisorder replied to Meatboi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPoint in fact - it's absolutely too much trouble. For the same amount of work you could do something that's actually FUN. Like swap an LS into an older F body or even a C/K truck/blazer. And yeah - it's quite a bit of trouble. Very few people out there that can do this in a weekend and have it running (I'm saying this AS ONE OF THEM). For most that attempt it - they spend a month or more (sometimes years) getting them operational. The end result isn't that worthwhile. The rest of the car is mechanically unable to support the power of something like a 20G turbo. That would tear the Loyale in half like Jesse Ventura with a phone book. GD
EA81 decreased oil pressure with increased rpm!
I vote for screwy sending unit. GD
2002 Impreza Outback differential oil change
Wheel bearing. Most likely pass rear. GD
06 TR with STI swap
GeneralDisorder replied to MaxKCool's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt depends on how you do it. Full swap with 5x114 or 04 axles, auto driveline, and keep the R160. I would say about $4500 on the low end, and upwards of 7-8k on the high end figuring wheels, tires, etc. GD
Depends on what you mean by less power. The 2 liter makes power higher in the rpm range. Honestly the EJ25 turbo is a much weaker engine than the 207. And some 207's come stock with forged pistons. There are plenty of 2 liter engines that make a TON more power (somewhat reliably) than any of the EJ's. The 4G63 is easily capable of much more. 500 is a low number for the 4G. The 207 revs faster, climbs higher, and will handle more boost stock due to thicker cylinder walls. GD
