GeneralDisorder
  1. He's in CA - not likely. I know it's hard to beleive, but we don't have rust on the left coast. No such thing here. GD
  2. It's the round switch down under the steering column right? Hang on - there is one in my parts collection - I'll run and take a look. GD
  3. Check the fuel filter first - easy fix if that's it. The FILTER is by the pump. The one in the engine bay is the vapor seperator - it routes fuel vapor trapped in the line between the float bowl and the fuel pump to the carbon canistor so pressure doesn't build up on a hot day in a parking lot. The filter inside this is largely overkill, as nothing really ever gets by the one at the pump anyway... unless you had corrosion inside the body hard lines.... yuckies. I've had the Hitachi floats get stuck closed before too - can you restart it again after it's sputtered out? Really annoying problem to track down, as the float doesn't stay stuck for long when you start poking around looking for problems. Replaced the needle and seat and never had another problem with that one. Check ignition coil and distributor as well - could be a heat related ignition failure. Check for spark when it dies. GD
  4. Pull the knob off, and there is a nut under it. GD
  5. BAD, BAD idea. If you get in a wreck, the fuel pump will not shut off, and crete a serious fire hazard. Other soobs have a "fuel pump control unit" that will shut off power to the pump when the engine is not running. The Justy most likely has something along those lines. I would start looking for it. Have you changed the fuel filters? Classic symptoms with your old carb.... I'm sure you have thought of that tho. GD
  6. This is a SUBARU - it's not a swiss watch people. This is not rocket science, and people will not die if some of the foam comes off a wing. Get real. Jeezuz That said, it's a heck of a lot simpler and cheaper to just use the 2-peice. It's proven reliable. Personally, I've seen axles, and driveshafts cut and welded in the middle. You just have to know what you are doing, and how to properly weld it with the sleeve covering enough of the existing shaft, and the holes in the sleeve beveled and welded properly. There is not just ONE way to do things, and people haven't always had access to sophisticated equipement for this type of thing. GD
  7. Yes - it will run without the computer - but not well. You do have a computer - it's under the dash on the drivers side. Your check engine light may be burnt out, or the bulb pulled, or ECU disconnected so you wouldn't see it when you bough it. The feedback hitachi will run without the computer, but not well, and never correctly. In order to make it run right without all the extra stuff, the carb would have to be swapped out with non-feedback version. The jets and air correctors in the feedback version are not designed to run without the vacuum solenoids that are controlled by the ECU. Just be glad it's not a feedback EA82 - they are worse. Your strange issues could be related to a bad coolant temp sensor or something. Disconnect the ECU and see if that makes a difference. Also might look into the fuel pump control unit above the hood release latch. It supplies power to the fuel pump... might be bad or getting an incorrect signal from the ECU. GD
  8. You just have to remove the single E10 torx on INSIDE of the stub - so you'll have to dissasemble the axle cup, and remove the grease plug. Remove the axle boot, and it should be obvious from there. GD
  9. Are you SURE it has the computer controlled Hitachi? If so, that's totally different, and you'll thrash you mileage if you mess with a lot of it. You can still remove the systems that are not related to the feedback system, but it takes more in-depth knowledge to sort that stuff out from the computer. The computer will get angry and throw codes at you, then run in "limp" mode with defualt fuel maps till you fix it. GD
  10. The AIS is passive - it has NO moving parts. There are two AIS valves usually - just follow the 1" steel tube up from the bottom of the head right above the exhaust flange and you'll find them. There are a couple plastic silincers and the 1" rubber tubes that hook into the air filter. You would likely know if you had a CA model. If you have an O2 sensor in your y-pipe where the cat is, then you have the feedback mess. But you probably don't. GD
  11. Dissasemble rear axle - use E10 torx socket to remove stub from diff - place cup and stub in a vise - remove the grease plug in the bottom of the cup - use brass punch and BFH to pound the stub out of the cup...... make sure to use anti-sieze for reassembly. GD
  12. There are usually three vacuum valves, one for EGR as you mentioned. Block the EGR completely, or route it to the other port on the front of the carb - also ported vacuum, but it gets vacuum later than the disty. It's easier to just block it tho. None of these has anything to do with the AIS, unless the AIS valve is the vacuum operated type (CA emmissions models, and I think some very Carter carb versions). Just disconect it. GD
  13. You can eliminate them both - the distributor needs ported vacuum - on the front of your carb. In other words, it gets a rising vacuum signal off-idle, and no vacuum at idle. The hole for this signal is right above the throttle plate. The other vacuum valve is for the evap system. It will evacuate the carbon cannistor once the sytem reaches operating temp. Read and UNDERSTAND how each system works on the engine, and this will all make sense. You are wasting your time and ours poking around and asking questions when a little research will save you from scratching your head for hours and begging for help. Also - I have personally covered each of the systems at length in previous posts - search is your friend as this is all availible for reading at your leisure. Why wait for us to post? GD
  14. Yes - do a search - I've personally covered this many times for people. The short answer is you need to learn what the stuff does, and the pro's/con's of removing it first. KNOW how your engine works, and what all the little parts do, and you won't have to ask questions of a bunch of people who largely don't know either. GD
  15. Usually bad DOJ's (Double offset joints) will not so much make noise as they will vibrate pretty drastically. You would know it - usually gets real bad quick. Check your axle nuts, and make sure the cone washer isn't worn out. Very common on the EA82's I've noticed. GD
  16. Engine is carbed, so fuel is no problem. A mech oil pressure test would be usefull, and probably a compression check now that it has a starter on it. GD
  17. He's making it sound like a big deal so he can charge you more, and scare you off from doing it yourself. Subaru over-engineered nearly everything, and an extra couple inches in the driveline isn't going to make a difference at all. Besides that how does he know how thick it is? He cut it open to find out? Frankly - my money is on doing it myself, and then just having a driveline shop balance it for me. Just cut the tube in the middle, and get some tube that is slightly larger to slide over the existing tube. Drill a lot of small holes in the sleeve, and fill them with weld. Then just have it balanced. Another thing - stock soob u-joints are serviceable - at least all the ones I've seen on EA81's are. Replaced a couple myself actually. GD
  18. Agreed - the cross-hatch usually still looks new even after 100k miles. Don't judge anything till you have looked upon the main bearings tho.... they get pretty sloppy usually. GD
  19. Engine came from a wrecked Loyale - no history on it other than it was wrecked at about 260k miles. Ran after it hit the tree, but the fan shroud punctured the oil filter - they were drunk apparently, and drove it more after that.... radiator was also pretty nuked. Hard to say really, but it was free Engine does have compression, but no oil pressure. It's been sitting for over a year. Even with the plugs out we could not get the oil pressure guage to rise. This could be the sender, or the pump, but even with a LOT of cranking with no plugs the new oil filter was still dry even with a full crankcase of oil. No leaks. Filled the filter to try and prime the system but still can't get the guage to rise. After that I had to leave, but I sugested he put the oil pump from his old engine on this block along with the sender to see if he can get some oil pressure out of it. It cranks and fires a tiny bit, but won't kick over like it should. The scraping noise sounds internal - like dry cylinder walls or dry main bearings - exactly what I would expect for no oil pressure. I suspect that she doesn't have enough compression to fire due to the dry state of everything. Hard to say tho - it's got spark for sure - timed correctly I'm pretty sure. Carb was on the old engine so that shouldn't be a problem, and we can smell gas. No lack of air. Turns over a bit labored - again - like the engine is dry inside. GD
  20. Front main seal - you'll have to pull the timing belts and covers to inpsect it. On the bright side it's a cheap part. $10 or so. GD
  21. What type of engine? GD
  22. I could still use one myself actually.... the dealer still has them for about $115 so unless it's cheaper than that, I'll go with factory fit and finish for $200 alex.... GD
  23. You need to replace the carb base gasket, AND the intake manifold gaskets on either head. The base gaskets are a problem too, but the manifold gaskets are the ones that usually go. They leak coolant into the head while running. Don't mess around - just do them all - they are way cheap. Do a compression check - if you HAVE compression, then it's the manifold gaskets. If you do not, then it's some other problem most likely. GD
  24. I got one of the equus guages too - the silly tubing for the oil pressure isn't really long enough tho - how did you do it? Get more tubing? Whats a source for 1/8" tubing - home depot only carries down to 1/4".... GD
