Everything posted by Sweet82
Solid Axle Subaru...
Qman has a rear solid axle on his Brat. Subie up front though!
Project "Brat-Lite"
A Brat would be hard to shave weight off. Doors are your biggest weight that's easily shed. (and put back on) A tailgate could be replaced by a net. Glass weighs. A hood weighs. A lot of what you can get rid of depends on what you want to use the vehicle for? Strictly off-road? Still street legal? These decisions will limit what you can do. I removed my doors, hatch, side glass and hood and I was amazed at how much weight those things added! (This is still Street legal in Ut.) Good luck Glenn
How to Properly Price a Salvage Title?
Sweet82 replied to jasinwa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had two salvage title vehicles. Still have one of them. My experience tells me you get what you pay for. Both salvaged cars i've had, have "personalities". A salvaged vehicle will always have quirks! The question is did you get a good enough deal to make it worth while to put up with the quirks? My mind tells me you have to get a super discount to make it worth while. Like 60 to 70% of book value. Good Luck, Glenn 88 Trooper--restored/rebuilt, quirky and still going!
***UP-DATE!***ATV tires RATED @ 925lbs! that's easy to mount! (or NEW 14" holy grail)
Great Pics, "You can't do this with them. . ." Not sure about that? I don't see any pictures that are over 20 mph? Nothin in those pictures I couldn't do and I'd have incredible traction while doing it!
- my lift....
I believe I paid $56 each for my 6 ply Dirt Devil XT's. But I was able to pick them up locally. Looks like they went up a little since then. http://www.rockymountainatv.com/typeDetail.do?navTitle=Tires+and+Wheels&webCatId=8&pageLinkUri=&vehicleType=&page=2&webTypeId=138&navType=type
Lincoln locker???
It makes all the difference in the world off-road! With out it, once you life a wheel, your screwed! All forward motion stops, one front wheel and one rear will spin and you won't move. You will have two wheel drive once you lift a tire. Welded your guranteed at least 3 wheel drive. You can lift your rear wheel 2ft in the air and still not loose traction. Subaru's are nose heave so you will most likely lift a rear anyway. My axles are more exposed than most but I can pull an axle in less than 60 seconds! 55 of those seconds are spent pounding the pin out. Weld it! Keep an axle out till your going wheeling. Install the axle then drive to your favorite wheeling spot. Don't look back! My .02 Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
I was wondering just how long it would take before I would pop up in this thread. I had been quietly monitoring it and just seeing what people have to say. Having run them for just under 3 years now I have seen many pros and cons to running ATV tires. Lemme share my thoughts on the subject. Cons; They ride like hell! They are an off-road tire. I don't run them over 20 mph. They won't fit inside your wheel wells. You'd need the most plys available at least 6. Your over stepping the tires recommended weight limit. You'd have to run a lift to use them as they will NOT clear the fenders. http://www.ultimatesubaru.org/photos/showphoto.php?photo=7435&cat=500&ppuser=584 Pros; They look cool as! They are the most aggressive type of tire. Nothing even comes close. I've never spun a wheel and consequently I've never been stuck. Yet:rolleyes: The come in a size that will allow you to keep what little gearing you have. The Auzzies have been running them for years on off-road Subies. I've played with tire pressure and never had one peal off or break a bead. http://www.ultimatesubaru.org/photos/showphoto.php?photo=434&cat=500&ppuser=584 There are many tires choices for Subies. What works for you in your area is probably best answered by you? You can get all the opinions you want but in the end it's all your opinion that matters. In Utah our trails are steep! Gears are critical. Clearance can be dealt with but it's hard to find a substitute for gearing. http://www.ultimatesubaru.org/photos/showphoto.php?photo=5190&cat=500&ppuser=584 I kept my tires at 26" for a reason and I still can't climb as steep as I could with my 13". Like I could climb that anyway...
MiniSubaruBuggy?
Ok it was cold and rainy in Salt Lake this weekend so what does one do? Make a semi-scale model of the SubaruHummer of course! http://www.ultimatesubaru.org/photos/showphoto.php?photo=12915&cat=500&ppuser=584 It's in it's very early stages. I'll probably end up using the existing tubing as a prototype for the real body. I'm not sure exactly what to make it out of? Brass tubing just kinked! Aluminum rod works great but connecting/welding/brazing is a bit of a problem for me? Steel--weight? Since I have the plans for the full size version, I can make it exactly to scale and the platform has unlimited power so weight is not that big of a concern but still, a full steel body would weigh and be a little top heavy on steep angles. Other modifications in the works are; Rear steering--order the front end parts bolt on the back! Dual speed controllers--one ESC for the front wheels one for the rear. Any thoughts, suggestions, insults... Ya, I know I had too much time on my hands last weekend! Glenn, 82 SubaruHummer--now a mini version! 84 GL Mad Max 01 Forester
How many remotes?
Does anyone know how many remotes can be programed into a system? I have two programed in my 01 Forester and I want to program two more. I was wondering if there is a limit? Anyone know before I start wasting my time programing? Thanks, Glenn 82 SubaruHummer--no locks or doors 84 GL Mad Max--key is kept in ignition 2001 Forester--factory keyless & alarm
98 Outback Factory Alarm
Sweet82 replied to jp98's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt should just be a plug in module. Unplug and remove. The question is Where is it?
My sooby
Hatchy, You need to post those in the Photo section for all to see! You don't even have a gallery!
Rust Problems....
Cough....Buggy!....cough! Simply install a new body without rust:D Why look here's one...and no rust! http://www.ultimatesubaru.org/photos/showphoto.php?photo=8707&cat=500&ppuser=584 I'm into my buggy $1,600 as it stands. Cough....hey, what do you know, some links appeared! http://www.risingsuncarservice.com.au/ http://www.rhinobuggies.com.au/products.htm ...a great way to keep your Subie around forever?
Nice Pic STI Forester
Sweet82 replied to HATCHY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey have been around for a bit. http://foto.auto.vl.ru/1889/ Here is a 2001 Forester STi.
Check Your Lift Bolts!
I marked all my bolt & nuts with fingernail polish when I built the buggy. I check them on a regular basis. So far no movement:dead:. Good advice on these old cars!
another possible offroad trail..
Sure is pretty back there! Not terribly steep, but pretty.
Rust Problems....
That's why my old Subie became a buggy!
$150 Brat
I love storys with happy endings:rolleyes:
rolled subaru
I prefer these... http://www.rhinobuggies.com.au/products.htm I think I'm a little biased:rolleyes: http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&page=6&ppuser=584 One thing's for sure, Subaru's make great buggies! Get that sawzall fired up! Good Luck, Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester
Need CV Boot replacement instructions, 2001 Forester
Is there a link to step-by-step instructions for CV/CV Boot replacement on a Forester around anywhere? I've done searches but it seems as though there are some different opinions on ways to do it and no real step-by-step instructions? I'm wondering is there a better/best way to replace the Boot or the joint? I'm looking for idiot proof step-by-step instructions on what to unbolt or not unbolt to make the job easy and painless. Thanks, Glenn 82 SubaruHummer--rear CV change in 30 seconds or less! 84 GL Mad Max--been missing boots for years! (we don't need no stinking boots) 01 Forester--freshly split boots at 60K?
Weight loss plan
With this weight loss plan, what is the end result? Strictly off-road? If your just going off road you can shed many pounds by pitching your rear hatch? Side doors weigh a ton! Times that by 4! A hood is a fairly heavy piece of equipment??? As I was stripping my hatch to make the buggy, I was amazed at how much those things weighed---and how light my car was without them. The car ran noticeably better without all the cosmetic stuff like doors, the hood etc... I talked with a cop, who said it was actually legal to drive like that. Much like the Broncos or Jeeps do. Just a thought? Glenn, 82 SubaruHummer--diet plate! 84 GL Mad Max--Rust has contributed significantly to it's weight loss:eek: 01 Forester--weighs in at #3200
Old School Meet! Wyoming/Colorado guys and gals! Sept. 23rd, 2006
Today works for me! ...as I'm stuck in a Hotel over near the Centenial Airport:cool: anyone....really, anyone... I'll just be here waiting....patiently.... Glenn, 82 SubaruHummer 84 GL Mad Max--now sporting a new air suction valve! 01 Forester--now with a newly relocated knock sensor.
Knock Sensor Problem Solved or Not ?
Sweet82 replied to jonfit04's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was getting an 0325 Knock sensor malfunction bank one. I relocated my knock sensor and the light went back off. I'm waiting to see if it will come back...
Another is it worth it thread...87 GL Wagon
I spotted an 87 GL Wagon for sale in the neighborhood. It had a duct tape front light on one side and some rust along the rocker panels. The sign said $400 runs great (auto) trans needs work. It has 131,000 on it. The only possible use I would have for this is a project car for my boys to build and eventually drive. I'd be thinking D/R tranny and Pugs. Any thoughts? Glenn 82 SubaruHummer--Summer 84 GL Mad Max--mobile spare parts for Summer 01 Forester--Knock sensor moved.
final drive change in an auto?
You know...an auto may be just the thing for compensating for the larger tires. If you don't abuse the auto too much it can function as a variable low range? How big of tires are you thinking?
