Everything posted by Sweet82
Question for Sweet82.
I'm into Summer $1,600 as it stands. $500 tires & custom rims. $400 Steel. $600 Aluminum. Done. Some quick stats, Wheel base center to center 80" Wheel track center of tire to center of tire 62" ATV Wheel width outside measurement 73" ATV Overall Length 133" Floor height 20" Overall height 63" Angle of approach 45 Angle of departure 71 The only tire wear I have noticed is on the edge of the lugs from being up front. Typical front tire wear. I've been running my tires at around 30psi I have not experimented with lower pressures. I think the closest compable vehicle is one of the 2-4 person quads you mentioned. The biggest difference would be the cost...
My net was down all afternoon:mad:. Sorry about that. 1. Yes. I have had it over 25 but my speedo is now off by a wide margin. 22.5 tires VS 25.5 tires. I have indicated 25 mph on the speedo with ATV tires. Not really sure of my true speed. The most limiting factor in my land speed record attempts has been the vibration. I have armor plated Summer. This armor plating will vibrate and make noise. I'm slowly isolating the noises/rattles from the plating. The frame and running gear are rock solid. So it's only body panels that have kept me in check. The other reason I keep my speed down is the tires I purchased are real aggressive. They have 1 1/4 lugs and spaced way far apart. This is not a tread pattern that is condusive to quiet/smooth running. A less aggressive tire would no doubt allow a smoother ride at higher speeds. I'm fully aware I'm pushing the limits of an ATV tire and have no real desire to find out what that limit is. My tires are six ply and I have run them for 3 years now. They seem to behave as I expected. I have never been Stuck. 2. Yes. I have played with Quads. I can pretty much go where they go. My track is always the widest but will always fit in any twin tracks. The two vehicles have their differences. I can carry 4 people and all the gear I need. I can go all week on a tank of gas. There are places where I can do better, there are places a quad will do better. 3. I have no reservations on the suspension. More is always better but for the engine and power I have it seems to work. Suspension is just not an issue with this vehicle. The shortend wheel base takes care of so much of the problems of a limited suspension. I purchased the "on-road" tires to get me quickly down asphault roads with out vibrations. I have not had them off-road as much as the ATV's. From what I have seen they seem to do fine in most situations. I'm sure there will be a difference in snow and sand. You certainly have a better range of speed with a "on-road" tire. But you loose width with on-road tires. Substantial width! The speeds quoted by Rhinobuggies have got to be with regular tires. The way they explained it to me was. "It's the same car you had before, you have not done a thing to change it's speed". That is true. You have just put on a new "more off-road oriented" body. Everything else is just as it was with your old car. 4. Yes. I have always been inpressed by the climbing ability of my little Sub. However when you up the tire size you loose that ability. The bigger the tire, the less climbing ability you have. There is a positive trade-off with bigger tires. Clearance is it. The longer the vehicle the more you'll need. I took 15" out of Summer and don't need much clearance. My little Mad Max (84 GL Wagon) will make a much stronger attempt at a STEEP hill. Max will spin tires and stop. Summer will not spin a tire and if the hill is too steep it will power out. 5. If I replaced them, I might try a 25" or maybe even a 24" rather than the 26". Climbing is everything to me. Clearance is just not an issue with this body. 6. No. I used artistic license when I built the buggy. I changed a handful of things but one thing I would not change is the length. It already turns on a dime!!! Ask anyone who's riden in it. Shawn W, Caboobaru, Honda Sucks, Mudrat, Harpua... It will turn the rear wheels in a 9' loop. No need to shorten. The shortness allow you to bypass so many of the limitations of the old Subarus. 7. Nothing! I wanted a 4 place buggy for the family to putter around in the hills. That is what I use it for. That is what it does best. If I was looking for a different application I'd do many things different. I built it to my specks. It's exactly how I want it. I does what I want it to do. 8. Yes. The sway bar is gone and that made a difference. The diff is welded and that makes a difference. I enjoy the scenery going by because it's an open buggy and that makes it enjoyable. I have been able to put it on some incredible angles sideways with out the slightest bit of worry or rolling. My wheel width is well over six feet. You do sit higher than a stock Subie. This gives you a great drivers prospective for dealing with the trail. The other main driving difference you'd notice is from the gearing! It's not the same driving style as your stock gearing. You will use the clutch more and have less power. You don't sit inside the car like you do with a stock Subie. The rest of the driving is the same as the old Subaru. Hope I've answered all your questions. I have got to run. Let me know if I missed anything (spell check, grammer...) http://www.ultimatesubaru.org/photos/showgallery.php?cat=500&ppuser=584 Link to pics.
Stand down! My Subie's been spirited off a hillside near Tucson!
What about using starting fluid to get it running then the carb should be able to keep running?
contact at american racing re: 4X140 rims
The center could be 3/8? The guy assumed they were for a rock crawler. I don't know what they weigh. I've never really cared. They don't seem any heavier than any other rims?
I called American Racing, among many others, early on in my quest for custom Subaru rims. They wouldn't do it. I had these custom made by a company in Denver. My size, my width and my off-set and they did the rest. The center is around a 1/2 thick steel. They are exactly true. They were $380 for the set (4). That may have included shipping but I don't remember. http://www.ultimatesubaru.org/photos/showphoto.php?photo=4967&cat=500&ppuser=584 I'd bet 14" or 15" could be produced at that price or less with a group buy? and they are "local". Just a thought:rolleyes: Glenn, 82 SubaruHummer--12" X 9" custom rims.
Anyone close to MHT airport, in NH?
Sweet82 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate us on your adventure. It probably won't compare to any Mile Fox road trip but it may be fun. Librarys have free internet access.
Trailer Hitch Wiring Harness
Sweet82 replied to abraxaas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board! http://www.ultimatesubaru.org/forum/showthread.php?t=56518&highlight=outback+trailer+lights Try here first. This search feature is great. Good luck, Glenn
Sit Ubu, sit...
Been there done that! A good solid smack works wonders for fuel pumps. Smack it so you won't dent it but it needs to be a good solid hit. Saved me a bunch of money on my Trooper. If it's already broken what's the risk? Your not going to hurt it...it's broken! I've never done the Alcohol bit but everyone I know who has tried it, passed!
Sit Ubu, sit...
Welcome to the board, We need more Utah folks here. If your truly up in the Mountains you don't need emission testing? Only us Wasatch Front people need emission testing. Alcohol Keep us posted on the pump. Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
Why dont you guys take I.S. to the next level?
The Toyotas Eat CV joints! That is their biggest/only weakness. Some folks are having them specially treated (heat/freeze) to make them stronger. The are still breaking these treated ones too!
Shop/Club night Bellingham Offroaders
Have you ever though about moving to Utah? Sounds like a great time is had by all. Only wish I was closer!
November Subiefest
Why don't they have cool stuff like this around here:-\ I wanna go!
Photos from Mt. Hood Rally this weekend
Way cool! I assume pictures don't really do it justice? Great pics though!
fun to drive
I've been driving my Subie for 24 years and have not got board yet. It's the car I want to drive. They are not fast but just plain fun to drive. I wish we (USA) could still get them with the old D/R tranny.... Never had a car that was so enjoyable to drive...
Pics of where the wagon will spend the winter...
Been there done that! http://www.ultimatesubaru.org/photos/showphoto.php?photo=9699&cat=500&ppuser=584 Put some kinda screen over the pipe. Mice will be all over the undercarrage looking for food or a way in. They will chew on wires and rubber tubing it will cause you nothing but greef. Put traps everywhere! Rather than stabilize the gas? Run the engine on a regular basis. Make sure it gets to operating temp. I'd move the car around to avoid flat spots on the tires. Good Luck
Running issues with the hatch, blinking light in dash??????
I'd do a basic tune-up first. I had something that sounds as though it may be the same thing. It turned out to be my wires. I'd do your basic cap, rotor, wires, filters...and then access the situation? Good luck, Glenn
New look for the Brat
I think it would look better with an Airplane on hood like GoldDiggerRoo?
heat shield (exhaust) rattling solutions?
Sweet82 replied to flash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to me between RTV orange and muffler tape you should be able to quiet down most of those rattles. Part of my noise is cause by gravel that doesn't want to come out:mad: That will require a different approach. I'm trying the RTV next. ...yes I've done the nail thing too...
The opinions on an 86GL 4wd hi-lo?
The sentance structure (or complete lack of same) indicates little in the way of formal schooling. I'm not perfect either, but I'm laughing on this one. Can't we all just get along.
83 Brat Turbo MPG?
I have to wonder if a low profile shell would make him more aerodynamic?
Kangaroo Catchers, Bull Bars, Cow Scoops.. post pics of yours!
Seems like the Australlians have the best bumpers out there? The best ones I have seen are down under. What is Subarinos bumper made out of?
Offroad Videos Walker Valley Soobies plus Toys
Great videos, It's amazing where these little things can go! I only wish I was there to share in the mud:grin: Glenn,
I fixed my car with vacuum cleaner parts!!!
Somethings not right? A household vacuum is 120 volts AC. A car is 12 volts DC? Humm....that does not make sence:confused:
Hello USMB!
Welcome, It's pretty hard to stump the board on Subie issues. I've been saved many a time by help form the board. Great place to get answers. Glenn, 82 SubaruHummer 84 GL Mad Max 01 Forester
Mud Bogs This Weekend!! PICTURES!!!!
Your oil pressure sensor seems to be beggin to be hit? Are you going to have some sort of cover/skid plate for it? Great Pics!
