Everything posted by Sweet82
any floridians here???????
Sweet82 replied to beachbum's topic in Meet n' Greet. Your USMB Welcome Center
Beachbum, RavenTBK is a florida person. Raven just posted on the old subaru section.... -
gear ratio questions - I need the details
Sweet82 replied to greggbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is a bunch of posts on this subject. http://www.ultimatesubaru.org/forum/showthread.php?s=&threadid=2666&highlight=gear+ratio This has the 1982 ratios. Why don't we add the ratios to the Repair Manual? Everyone seems to want these at one point or another. -
What about dual shocks? A secondary pair of coil overs may work? I'm using adjustable Bug Pack coil overs on the buggy. Dual shocks would be killer! Just a thought,
I don't want to hijack my own thread so I'll make another. With a welded diff.... What is the weak link in the (EA-81) drive train? What is going to break first, most consistently etc... What part is the fuse? or is there several? Just trying to determine what drive train parts should be on board for an outing? Thoughts? Glenn, 82 Summer, gettin ready to break things! 01 Forester, don't wanna break anything!
I'm stupid, or just havn't spent any quality time with my diff thingy. Having stated the obvious, The stub that sticks out can be unbolted and replaced leaving all the welded gears inside happy:) and inplace? Glenn, 82 Summer, contemplating slickrock......
Once you weld your diff......and break a stub.... How do you remove your diff gears or do you just replace the whole thing....? Just thinkin ahead to Moab..... Thanks, Glenn 82 Summer, welded diff.... 01 Forester, LSD......
Just got back from Moab! What a great place.... Only regret is, didn't take Summer with.:boohoo: Did Hells Revenge, Metal Masher, Kane Creek, If a guy prepared a Subie right I think all three of these trails could be Subed! Glenn, 82 Summer, 01 Forester,
That's one of the best Hatches I've ever seen! Nice Job! Glenn, 82 Hatch, well it used to be.... 01 Forester, still is....
Dude, everyone needs to take this quiz!
Sweet82 replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
STI! How come I have a beat up 80's GL and a Forester? Sumthin ain't right. Glenn, 82 Hatch, well it used to be. 01 Forester, still is. -
New 33x15.5 swampers are here.
Sweet82 replied to subarubrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mount those babies! Send us pics! So your low range will be the same as the stock 13" in High range? Glenn, -
I paid $80/rim......made however I wanted them! They turned out to be 12" high 9" wide with a offset I can't recall but can measure. That will allow you to have the most aggressive tires possible. I found some with 2" lugs. The ones I got were Dirt Devil XT's. You can loose a quarter in the tread depth. These lugs are DEEP! 25X12X12, 26X12X12, 27X12X12 or 28X12X12. I went with 26" to keep my gear ratio as close as possible. Glenn,
I'll be leaving in a few hours.......... Anyone interested in Moab later this year, send me your angle of approach and departure and give me an idea of how much clearance you have soon. If you know your maximum climbing angle send that too. I'll assess Subability on Kane Creek, Metal Masher, Gold Bar and Golden Spike this weekend. I have 47 approach, 71 departure and 11.5" down the center. Overhang may kill us! Glenn, 82 Summer, 01 Forester,
Iluvdrt, Rims were made by Trudesign in Colorado. I have rim pics in the reader ride section of the board. Let me know if you want to order some, I may order a spare some day.....
Snapped some pics of Summer last night. Since you saw it last it now has; a roof, a floor, front seats, clearance lights up top for that Hummer look, driving lights up top for true "high beams", my old luggage rack runners, a blower to go with the heater core, and one tail light! Buggy pics Could fire it up anytime:D But I'm going to Moab! so it won't happen this weekend. Shuuuuuuuu! DON'T Tell Summer! Glenn 82 Summer, almost done! 01 Forester, done!
Thanks, Subsandrail So the rolling rating is pulling a rolling vehicle on flat ground? (With 60 psi tires on concrete:eek: ). Seems that the rolling weight is somewhat meaningless, the straight pull would be the only meaningfull figure? I can pull a #2000 pound vehicle:cool: I figure the buggy will weigh around #1500 when it's done. A #2000 would be 25% over the vehicle weight. I plan on getting a snatch block anyway. Thanks, Glenn 82 Summer, almost done... 01 Forester, done...
I'm going to put a winch on Summer. I don't know a thing about them. However I did pick up one of those $49 Harbor Freight #2000 ones discussed in previous posts. Can anyone explain what the rolling weight means on a winch vs a strait pull? I have been getting conflicting info from under qualified parts store people. Anyone shed some light on requirements and what ratings mean for winches? Thanks, Glenn 82 Summer, (SubaruHummer) almost wired. 01 Forester, wired!
The headlights are wired using the Factory harness (2 fuses one for each light) and then they share a common ground. The headlight plug is labeled; Pass Drive Ground What would happen if I used a jumper wire back to the low beams from the high beams? and didn't use a relay? (roasted wires? What's that smell?) Wheres this relay thing? Glenn, 82 Summer, with park, reverse, signal, hazard and brake lights only! 01 Forester, fully lit!
Facts: My 82 Hatch had the single headlight with the dual element. Now my Hatch is a buggy, I have those off-the-shelf, single element driving lights. Problem: What I want to do is have one set of driving lights be my low beams and use my blinker to switch on a seperate set of driving lights for high beams. It don't work! What I have tried, Wiring the new, driving light, low beams to the existing low beam wires and wiring the new, driving light, high beams to the existing high beams. What happens is as soon as I flip the blinker to light the "high beams" the "low beams" go off! I assume the problem is the head light relay? I'm looking for suggestions to allow me to use the original light switch and blinker to run the lights. Thanks, Glenn 82 Summer the "SubaruHummer". 01 Forester, still bent but not broken!
Great Pics, Great Hatch! I wanna play too! Did you make your own lift? Glenn, 82 Hatch, almost done..... 01 Forester, done!
Who's Built a Bridge while 4x4'ing...? ( long )
Sweet82 replied to mudrat79's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Video? -
That great! What rims is them?
The neatest web site ever!!
Sweet82 replied to NoahDL88's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I love the big Brat and little Brat picture. Wonder what the heck they are sayin:confused: Glenn, 82 Hatch, almost done! 01 Forester, done! -
That's just WRONG! Now go out and smokem! I love it! Glenn, 82 Hatch, almost done! 01 Forester, bent but not broken!
My Snowmobile holds more gas than my car! Range has never been a real issue on either...........
