Everything posted by Sweet82
Utah Users Unite!
Killer pics, I recognize the area. I had no idea that was Little Moab? My Scouts are going to Nutty Putty cave this weekend. I'm not sure if I'm going with them or not. (I think I'd rather work on the buggy) I test fired it a few days ago---started up great after 9 months of "rest & transformation". Is this your wagon in the pic? How Subaruable is this area? Glenn, 82 Summer, running but not finished. 01 Forester, running and finished!
arrg!! no heat... brrrrr its cold...
When ever I'm low on coolant I get the same thing..... However, you may not be getting any coolant type heating in your heater....? Let me explain. As I was taking out my heater and moving it to the buggy I noticed a wire that didn't make sence? I unscrewed the plug and wire only to find a heating element in my heater? I didn't realize Subarus had an electric heating element in the heater besides the coolant heating system. If it is weak heat, you may only be heating your windshield with the electric element and your other system is not working? Just a thought? Glenn, 82 Summer, with heater! 01 Forester, also with heater.
Who here has installed a rear window in an 80-84 wagon?
I did my Trooper!....it was simple. I watched the guy at the Junk yard pull it out. I did the same thing in reverse. I duct taped the window at the right level to the Trooper, so I didn't have to hold it. Put the gasket on the window. Pushed the window into a corner to start. Got a wide flat blade screwdriver and gently lifted/pulled the gasket inside the frame. Did it with one person in 5 minutes on a back vertical window. Maybe I got lucky or maybe its easy but I thought it was simple. For what its worth, Glenn 88 Trooper, 91 Trooper, And the Subies....
flyn soobair.....Whats your guys biggest/best jump
Ouch! That's gonna leave a mark!
It Moved! long
I use the Supertrap muffler on my trials bike with 4 disks on it:D The sound can't be beat! Glenn, 82 Summer, just needs armor plating.... 01 Forester, jealous.......
It Moved! long
Had some time last night and I threw some gas in the tank of Summer. Not really knowing what to expect, I figured I'd turn the key and find out what would happen? I double checked all the electrical connections, fluids, connected the battery and turned the key! Of course the battery cranked real slow. I had charged the battery off and on since I removed it last July. Guess I wasted my time there. So I went and got the Trooper and jumped the battery. Cranked fast but did not start? Undetured, I stole the snowmoble starter fluid and shot a dash in the carb. Climbed back in, crossed my fingers and turned the key... It fired! Smoked a tiny bit, slightly more than it used to on a cold morning. The engine sounded....well....the same:D I was hoping the Cherry Bomb Turbo II would change the sound but it sounds about like it did with my old muffler. At that point my boys and I piled in and went for many trips up and down the drive way. The only thing that kept me from taking a quick dash out on the street was the fact that I had piles of tools on the fenders, roof and rear of the buggy. One thing I noticed....at lower speeds (like driveway speeds), those deep lug tires are brutal! The buggy shakes each time a lug hits the ground. I'm looking forward to serious traction:grin: At somewhere over 5 mph the tires seem to mellow out and just roll instead of klunk! Only thing that seemed wrong was the idle seemed high. I kept releasing the choke and it would idle down but would slowly climb back up in rpms. This could be because it may not have been totally warmed up. The heat gauge did move up about 1/4 of the way though? Would a vacuum line cause any of this high idling? I'll let it warm up tonight and see if the idle calms down. Anyway, I'm happy!!!! Glenn 82 Summer, running---but not finished. 01 Forester, running---finished!
4sp VS 5sp Q?
Looking at picking up spare 4wd drive train parts for the SubaruHummer. Summer is made out of an 82 Hatch. I took about 18" out of my drive line. Will the driveline of a 4sp bolt to the 5sp tranny/diff? Are both the front and rear 5sp axles the same as the 4sp? Does the 5sp tranny have the same mounting points as the 4sp? Are the 4sp and 5sp first gear ratios the same? What I'm getting at is, will a 5sp be a reasonable parts car for an 82 Hatch? Thanks, Glenn 82 Summer 01 Forester
Spare tire?
Just order a large pepperoni from Dominos. They will even deliver your spare!
Underbody coating
I wire brushed mine and found 8" holes:eek: Good thing I had carpet!
pic of junk yard gl finally
Looks like good junk to me! Start carving! Fingers crossed, Glenn 82 Hatch, well it started out that way... 01 Forester, still is.....
Suday off-roading trip - damage pictures!
Damage, Damage? What Damage...... I thought thats how they were suppose to look? Love the skid plate up front. What is it made of? Where/what are you attaching it to in the back? I'm also looking for suggestions on how to reinforce the diff bar??? Looking good! Glenn, 82 Hatch? Well it used to be..... 01 Forester, still is.....
Utah Users Unite!
Xtreme, There's modified XT's around, One of my favorites This guy is running what looks to be a tractor tire with a chevron pattern. I thought this ride was great! Hatchet, where is little Moab from Nutty Putty? Glenn, 82 Summer, needs to get finished! 01 Forester, finished!
Need help understanding the divorced t-case mod
Welcome to the board! If I understand things correctly.... Since you don't use the front transaxle (consequently they would take no power away from the engine) all output power would be transfered to the driveshaft. My suggestion is use the old transaxle cups as a PTO for a generator/welder or Winch? A PTO could be real handy along the trail? Mudrat has some ideas on this. On your tranny... I have the same problem in first when I lug it. Folks on the board have told me that its most likely a syncro that is messed up and causing the problem. Anyone else? Glenn, 82 Summer, SubaruHummer....... 01 Forester, Jealous.........
Underbody coating
I have used most of the brands over the years. My experience has been that they are all about the same. The importent thing is getting it on before the rust starts! I had been using it every few years to reseal the floor pan. It seems to me that the seams and cracks are hard to seal and that is where the rust starts.:madder: I say if the rust has not started then undercoat away. If rust has started you probably need to fix those areas before sealing. Good luck, Glenn 82 Hatch, terminal rust on the botton side.... 01 Forester, no rust!
suby offroad version 2
Hard to tell what kind of deal you got until you get it up and running. Storing cars isn't the best thing you can do for them. If you can put a belt in it and get a JY steering column for cheap, you got a great deal. What's important is you now have a platform to sculpt with. What mods are you contemplating Glenn, 82 Summer 01 Forester
Jumpy tac at higher revs
My tach has jumped for several years now. I have never fixed it Maybe I should but so far it hasn't been a problem. 82 Summer, jumpy tach 01 Forester, regular tach
Pics of BRAT painted UPDATE New tire Pic added
You sure that's not a Tamiya Mudblaster? Looks too good to be real! Glenn, 82 Summer, wish I had time to work on it..... 01 Forester, same same.
Mudrat79 Cars
I'm in on this one! Johns a great guy, he knows his Subarus! That's all he does. He is my go-to guy. His fabrication and mechanic skills can't be beat. Besides working on Subarus, John has a life. He responds to emails and answers his phone like everyone else. If Johns away or pursuing a hobby, that makes him a real person and it will make him a better one when he returns. Our Subies are old they will break. If you have concerns about the car, ask John. If he is aware of the problem he would tell you how much it would cost to fix or how you could do it yourself. Mudrat has my vote of confidence. Glenn, 82 Summer, Mudrat approved! 01 Forester, Mudrat says it's too low!
Intermittent Fuel Pump failure. Which wires +?
Brian, My 82 did this exact same thing (many years ago). Exact same! Replacing the pump did the trick. It was my pump NOT the wiring. The black wire is the ground it should run the the side of the car then connect with all the other black wires in the grounding system in the harness. Good Luck, Glenn, 82 Hatch, well it used to be..... 01 Forester, still is.....
best tires to use???
I think these will get you there! http://www.candssales.com/psp/showdetl.cfm?&DID=66&User_ID=1111226&st=4475&st2=51129439&st3=79951964&Product_ID=1678&CATID=165 This was my choice.........I didn't want the 2" lugs. http://www.rockymountainatv.com/home.asp?sid=0003408975 I wish you well in your search. Glenn 82 Hatch, well it used to be..... 01 Forester, still is........
New member
Sweet82 replied to scubaroo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board! There is a wealth of information out there on the board. I haven't been able to stump the board yet. Good to have you on board, Glenn, 82 Hatch, well it used to be...... 01 Forester, still is.......
any floridians here???????
Beachbum, RavenTBK is a florida person. Raven just posted on the old subaru section....
gear ratio questions - I need the details
There is a bunch of posts on this subject. http://www.ultimatesubaru.org/forum/showthread.php?s=&threadid=2666&highlight=gear+ratio This has the 1982 ratios. Why don't we add the ratios to the Repair Manual? Everyone seems to want these at one point or another.
stiffer rear springs?
What about dual shocks? A secondary pair of coil overs may work? I'm using adjustable Bug Pack coil overs on the buggy. Dual shocks would be killer! Just a thought,
Drive train Weak Link?
I don't want to hijack my own thread so I'll make another. With a welded diff.... What is the weak link in the (EA-81) drive train? What is going to break first, most consistently etc... What part is the fuse? or is there several? Just trying to determine what drive train parts should be on board for an outing? Thoughts? Glenn, 82 Summer, gettin ready to break things! 01 Forester, don't wanna break anything!
