Everything posted by Sweet82
Why does my Subaru catch fire so easily?
Got H.F. Sawzall and I have a 8" demolition/rescue blade. That's how I got the engine/tranny/suspension/tires and wheels out in one Big piece. LOL I've been known to shoot tracers??? The ones with the bright red/pink glow at night. I've also been known to use phosphoric acid to treat rust problems. Putting two and two together, is it possible for old phosphoric acid to burn like phosphors? I don't recall treating this area of the Sub with acid in the past, but I could have? Being a pyro at heart, I think I may pull some rust out and gather the kids around (for $5, at a safe distance) and see if metal will burn? Armed with a fresh change of underware and my sawzall I plan on making another attempt at the cut tonight.
removing the front swaybar....permanently
On-road, without the bar, I think the tires seem to roll under easyier giving unexpected results in turns. If I was on the road, I'd keep it and make a disconnect. I'm strictly off-road now and I wouldn't have it on. Disconnect it and tell us what you think? Glenn, 82 Hatch, well it started that way.... 01 Forester, still is a forester....
Anybody think this looks like fun :D
The first sales must have fallen through, current bid is a hundred bucks! Should be worth more than a hundred bucks. Think of the adventures with a lift kit and 4 wheel steering? Why do people do these things:confused:
The Backyard Boys at play
Great Vids, I wanna play too! Makes me wish I was down under. Stay just out of the main track and you'll make it up! Glenn, 82 Hatch, well it used to be... 01 Forester, single range tranny...
How many times have you caught your Subie on fire in one day? So......I'm working on a Secretmobile which all I can say is....it involved cutting the inside of my old Hatch with a grinder. All the upholstry, dash, panels, carpet, insulation is out of the car. There is nothing to burn, just yellow paint and rust inside my car. I'm happily making a cut inside the car near the rear seat foot well/seat area. It has a rust hole there. As I get close to the rusty area.....a spark from the grinder (and there are lots of them) hits the rusty area and bursts into flames? The flames are bright pink/red. It's a small fire that seems to be burning from one spot. The flames are giving off a bunch of silver/white smoke. About as quick as it started it went out? Needless to say I quit working on that area and moved to a different area....a spark from the grinder shot to the same area and POOF! The same area is on fire over a larger area this time and goes out about as fast as it started? Besides being confused now I'm gettin scared. What the heck is happening:confused: Long story short...it caught fire in a similar manner two more times in the same spot? I looked to see if something was spilled on the floor boards but found nothing except smoke coated metal? Why is my Subie catching on fire? Glenn, 82 The Flaming Hatch! 01 Forester
Fuel system electrics?
Thanks for the diagram, I may end up making one of these. If I'm understanding the FPCC correctly, there should be power to the fuel pump when I initially turn on the ignition switch. Then if the motor runs the coil/ignition will continue to feed power to the FPCC and then to the pump. So when I turn the key, and get no short duration power to the pump, then the FPCC is not working properly? I gonna get ugly with it tonight. Glenn,
Door-less wagon?
I pulled the doors off my Hatch (along with the hood and rear hatch). Great way to see the country. Drove it for several months that way until I transferred the drive conponants to the Summer. Driving without doors is cool! I never noticed any structural problems Glenn, 82 Summer, 01 Forester,
I read the links you sent..... Do I need the FPCU? or can I just run a wire to the pump. It sounds like folks are running power from a "key on" lead and going with that? Tell me more about the pink connectors..... I know what ones your talking about. Glenn,
Somebody needs to take the hatch away from me!
Duct tape a camara to your hood! We need this kind of video for inspiration! Sounds like fun wish I was there........... Glenn, 82 Summer, 01 Forester,
I swapped the entire wiring harness into the buggy. Though it would make things simpler that way. I used my volt meter and ran a test current into the fuel pump power line starting in the glove box area, then I checked for power back at the fuel pump connector. I found power in the wire (blue) and I also found partial power in the ground wire? A grounding problem makes some sence. Is it possible to get feed back into the ground through the FPCU? or is it more likely there is some other prob that is giving me some power from the power wire to the ground wire? Would this fry the FPCU?, Fuel Pump?. I tryed jumping 12v to the pump and the pump did nothing:banghead: Wondering if I'm dealing with two problems caused by a ground? ????????? Glenn, Daysed and confused!
I'm not getting power to my fuel pump:-\ (EA81 Hatch) How can I test the rev sensor/fuel pump regulator. This is the black box under the dash that I thought was the relay that the dealer calls a rev sensor ($150). If I jump 12v to the fuel pump to see if it's working is it going to hurt anything? Blue===Power? Black==Ground? I'm not getting gas to the front filter/carb. Thanks, Glenn 82 Summer, not getting fuel. 01 Forester, uses way too much fuel.
It just died!
I'm busy tampering with my suspension in the yard and my car (EA81 Hatch) just died:eek: Added a bit of fuel and put the car on level ground. Nothing! Got some starting fluid. Ran for a second. Pulled the line off my front filter and turned on the key. No gas! Pulled off my power leads to the pump and checked for power. Nothing! Ran up the wiring harness to the wires (I had labeled Fuel Pump??Not 100% sure I had the right wires??). Power! Questions, Are the fuel pump wires White w red stripes and black w yellow leading to the fuel pump? Am I missing something or is the problem likely in the wiring? How do I test the fuel pump relay? Do they still sell relays and fuel pumps at the dealer? Have I missed anything? SUGGESTIONS? Thanks, Glenn 82 Hatch, in a previous life! 01 Forester, still a Forester!
wagon slope testing
Wagon's ability Good! Hill Holder Evil! I hate those things!
Towing with a 2003 Forester
Sweet82 replied to jbordwine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI tow, http://usmb.net/gallery/albuo21/cap_111203_102535_16_1 Forester towing my SubaruHummer (frame). I tow a riding mower, hobie cat and a snowmobile on a regular basis and the Forester does not even notice. Glenn, 82 Summer 01 Forester
EA82 2bl weight
Throw in an EA81 while your throwing out weight figures. I put out a thread a while back and I have never been able to get an answer on weight figures:confused: Glenn, 82 SubaruHummer 01 Forester
WWP-99 recall.
I just got my WWP-99 coolant recall notice. I did a search and apparently it has been out a while... Has anyone had their Subaru in to the dealer yet or have any more details than what was in the recall letter. Wanting to know if there is anything I should be aware of before I take it in for the recall. Thanks, Glenn 82 Summer, up and running 01 Forester, always running!
Clock issues?
Sweet82 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the pics, I was holding off till I knew how to remove the thing. I'll pull it off tonight and see what I can see? I just got a stereo installed last week so that will take the urgency off fixing the subaru clock. Now I just have to figure out how to set the stereo clock:confused: Thanks, Glenn 82 Summer, still has orignal dash clock 01 Forester, still timeless.
Utah Users Unite!
Utah Update Went through the San Rafael Swell last weekend. The Forester was at home in the desert terrain. As it was threatening to rain, My boy and I ended up sleeping in the Forester? I was thinking it was going to be painful getting elbowed all night folded up on a tiny car. It turns out that the Forester folds out nice and flat! My little boy didn't kick me all night like I was thinking. I was surprised at just how much room there really was! What a great campmobile! At least half of the vehicles I saw were Subaru wagons of some sort! Must be a Subaru Mecca down in the San Rafael Swell? Glenn, 82 Summer, up and raging! 01 Forester, campmobile!
ANOTHER project car!
Can't have enough Subarus!
Balancing Subaru and life... (SHE SAID YES!!)
My wife was the one who sent the $ to Australia for the plans! I think she did it so she wouldn't have to drive it anymore:confused: She has been very supportive. If I'm out in the garage she has time to read! Wife, Family, Hobbies, life is a balancing act. Glenn, 82 Summer, up and running. 01 Forester, running.
Forester rock sliders?
Sweet82 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm wondering why a guy couldn't make some? It doesn't seem like it would be that difficult? The ones I saw had flattened spots for steps by the doors for steps and that sand paper stuff for traction on the steps. Now I'm thinkin:confused: Humm...............
I was at lunch today and a Forester parked next to me. The thing had American Racing wheels, a push bar and Rock Sliders? I had never seen these on a Forester before? Who makes sliders for Subies? I thought they looked pretty good. I wouldn't mind having some on my Forester. Thanks, Glenn 82 Hatch, well it used to be.... 01 Forester, fender flares but that's it...
Turn signal trouble?
The brighter element (blinker) works with the hazards? but not with the turn? I guess I need to find the switch plug for the blinker (next plug up the line?) and see if I have volts there? No spare blinker switch:mad: Can half a flasher go out? Will swapping the right and left turns mess with my stop lamp checker? Still puzzled:confused: Glenn, 82 Summer, with one messed up rear turn signal 01 Forester, with no messed up turn signals
Names of your Soobs
My Hatch was Yellow........ My Friends and I always end up singing the Beatles, "We all Drive in Yellow Subaru, Yellow Subaru, Yellow Subaru...." Why do people always stare when we drive by? .......so I have always referred to it as the Yellow Sub!(marine) Glenn, 82 Hatch, used to look like a Hatch. 01 Forester, still looks like a Wagon.
Clock issues?
Sweet82 replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhile I was driving home last night I decided to dig into the project..... How do you get the plastic cover off? I couldn't see any screws hidden around that upper consul thing. I assume I can lightly pry the face plate of the clock off or pry the whole consul off? Thought I'd ask before messing up my plastic. Thanks, Glenn 82 SubaruHummer and the clock still works! 01 Forester, timeless!
