Everything posted by nipper
New Alternator Needed?
nipper replied to AFCEA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt happens at full load, your ALT is dying. Put everything (and i mean everything) on and check the battery voltage. Raise engine RPM to 1800 rpm Bet it is below 13. nipper
nipper replied to AFCEA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI thought the 2000 was much higher then that. That is what i paid for Blu, a great price. Go OE then, as aftermarket rebuilds have been very problematic
96 Legacy AWD out
nipper replied to kevinhoffert's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt that mileage i would say it is just tired. People will say put the car on jack stands etc etc. It's just tired. You can try (i think it is lucks) LSD rear additive. someone will chime in with what it is. nipper
nipper replied to AFCEA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure they use the old analog type tester. the digital ones are worthless and miss altenators that are borderline as techs (and autoparts people) have no clue how to read them. If you go aftermarket find a real shop to buy a rebuilt from, not a chain. nipper
96 Legacy AWD out
nipper replied to kevinhoffert's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles. What caused you to think you needed the FWD fuse? If the FWD fuse is working the solenoid is working..... for now. Did all your tires match? Sometimes it fails just due to high mileage. What are the symptoms?
Transmission or clutch noise?
nipper replied to landozion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe throw out bearing is rattling around inside the transmission. When you depress the clutch the noise goes away. You are loading up the bearing. MAN OH MAN you may win the award for the most miles on a clutch! I wouldnt be surprised if it is a thorw out bearing, or a pilot bearing. My money on throwout. http://science.howstuffworks.com/bearing1.htm Look how the bearing is constructed, and you can invision the noise. Google it and 98% of the responses are a bad TO bearing. Even people with new trannies are confirming it. Shaft bearing would make noise as you released the clutch, not just when it is fully released.
Strange thud after offroading, need help!
nipper replied to cdizzle666's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had that for a while too. what solved it was a really really good washing of the under body with a hose. It drove me nuts. nipper
nipper replied to landozion's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThrow out bearing. When was the clutch last done and what parts were replaced.
update- AT oil light on and car wont start.
nipper replied to tenderfootblue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy mistake, they are inductors DUH brain fart!
Engine compression
nipper replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEngine out of car you need to do a leak down test. nipper
Collapsed radiator hose - a couple of questions
nipper replied to Chessie92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI prefer the tried and true, and safer method. Let the shop use an emissions sniffer to look for products of combustion in the radiator. nipper
nipper replied to tenderfootblue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXInteresting, as that is only 1/2 the test for any sensor of that type. It is a standard testing procedure engineering wise. nipper
factory vs. after market replace parts
nipper replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClutch staying on the floor is either an assist spring or the hydarulic clutch itself (don't remeber if there is an assist spring). All seals from subaru. Valve covers can be aftermarket, spark plug bucket seals from subaru. Headgaskets SUBAUR ONLY! Waterpump anywhere. theromstat subaru PCV valve Tming belt any brand name. Tensioners and idlers yes BTW when you take the engine out the very first thing you do is flush the radiator. Antifreeze and goo can clog a perfectly good radiator when exposed to air.
nipper replied to Chessie92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXan FYI, never use tap water in an aluminum engine. Use 50/50 pre,ix or demineralized water. I go for the sooby cap first, then a clogged radiator second. nipper
nipper replied to tenderfootblue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOdd thats now how you test a hall effect sensor. I cant find it in the FSM (clue me into the section) The resistance is the first test to make sure there are no opens in the sensor, there are only two wires so it is easy. The pattern will be 1-11-1-111-1 . Do the resistance if it fails that you are done. It is possible to loose a tooth on the reluctor (GEAR) and that will keep the car from running. It will be an all or nothing test otherwise.
nipper replied to tenderfootblue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is a pulse of high/low AC signal. It does not happe an regular intervals as the signal gear is refernced to specific rotations. Look at the haynes manual even if it is not your year, as all the cam and crank sensors work the same way.
tranny oil frothy on dip stick.
nipper replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFrothy usually means it is overfilled. nipper
nipper replied to tenderfootblue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXResistance is one way, but you need both tests. You are looking for an AC pulse as the engine is cranked (which is the FSm way of testing it). It creates a pulse as the toothed "gear" passes under it.
Underdash Wiring? 99 OB Sport
nipper replied to 99ImprezaOSport's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXC- says it right on it "cruise control Unit" D - is an antenna to something B - i can hunt down on the FSM if no one has an answer. Leave the green and black connectors alone. they are for diagnostics and reflashing the control units. Cruise control not workind 99% of the time is a bad brake light and or clutch switch in a subaru. nipper
2nd Gen Legacy Bullbar?
nipper replied to TheLoyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSure it does. The more you make of something the cheaper it is. Only 5% of any given AWD/SUV (excpet Jeeps) see any offraod, and even less see real offroad in the USA. Kind of hard to justify making 100 or 200 units (more likely less then 100) for what they would have to charge in the USA. ALso it would affect crash tests and function of the air bags so there would be a huge liability concern. nipper
A/C electromagnetic clutch
nipper replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"will check my options then, here in italy, parts are not as cheap and harder to get." Once again he is in ITALY. He said parts are hard to get and very expensive, he is not in the states where things are cheap. If he was here i would not have mentioned the EU or health and saftey. And in my expierience if money is tight and edpending upon the make of car, repolacing a clutch that is bad is just a bad clutch. One can see when removing the clutch if the bearing is bad or the seal is bad.
Bad power steering?
It sounds more like the pump. The pulsation is matching the rotation of the pump. There is probably a bad gear in the pump. A rack would be stiff when cold when trying to turn the wheel (and I mean winter cold) or binding. It wouldnt be pulsing.
nipper replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXExcept he is in Itally, and i dont know what the nanny state/EU/Health and saftey will allow him to do. I wouldnt be afraid of using a used clutch either. nipper
nipper replied to turboguzzi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would go ahead and replace just the clutch, or if you can get it the clutch coil. I do not agree on a subaru that if the coil burns out the compressor isnt far behind. Compressors last much longer, so just replace the coil/clutch. nipper
backfire
nipper replied to jp1gt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno need to shout. Exhaust leaks can be of two types. One that opens up when the car gets warm, or closes up when the car gets warm. Ahev you noticed if the light comes on while the car is warming up, when it is cold, or after it is warmed? Or just havent noticed (not a biggy).
