Everything posted by nipper
High beams 2011 Legacy
nipper replied to Bluepearlgirl's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPush the turn signal away from you it will click on.
What is this ea82t
Really? Who knew. It will be a solenoid of some kind as I cant see the business end of it in the pic.
1981 VW Rabbit Diesel
Try this http://www.vwdieselparts.com/forum/index.php?sid=58d9bbd6eb57866e06a144effd11b387
Still with Subaru
Hi! 2,5 block (engine) is engineered to the very edges of what it can do normally. You'll be better off starting off with a 2.2 as it is a stronger engine all around.
What is this ea82t
Injectors or carbed? Ot looks like the anti diesling solenoid for the carb but not sure.
Stinky, noisy, and indestructible. Try the Vanagon boards for some assistance as I think they use the same diesel engines.
Subaru History
http://oppositelock.kinja.com/proud-of-boxer-50-years-of-the-modern-subaru-1737707038
2000 forester not starting
nipper replied to milktoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA timing belt is a complicated thing. Belts can stretch/break internally and look fine on the outside. How many miles are on this belt? How many miles are on the tensioner?
our Cars Unique Quirks
My choke on my Justy.
nipper replied to milktoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTime to check basics, do you have fuel injection and spark? Do you have a compression tester?
1997 Grand Wagon Head Gasket and Severe Overheating
nipper replied to Finlayg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks Emily, I did not know that.
nipper replied to Finlayg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy mistake, saw grand wagon and thought Jeep. Still stick by the compression test though
trouble shooting AT Oil temp light issue
nipper replied to petergriffon2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe solenoid may have failed as it is pulsed (hence duty in the name). It makes sense.
nipper replied to petergriffon2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCoil is straight forward to test fir opens or shorts. Check your harness fr physical damage but odds are given the age of the car it can be a tired solenoid. Just an FYI, the flashing light indicated a failure on the previous running cycle.
nipper replied to Finlayg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this a straight 6? I'm guessing an aluminum head. I would do a sry and wet compression test first to see what shape the engine is in to begin with. All those years of driving upside down may have hurt it
nipper replied to petergriffon2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFWD someone pulled the bulb. There are quite a few solenoids. How are you pulling the tranny codes?
nipper replied to milktoast's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTriple check your timing belt timing. Its not uncommon to get it wrong.
nipper replied to Finlayg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou cant just judge a car by its book value, but the value to you. What year is his, and how many KM are on it?
2003 Baja Speedometer Shows 4 miles slower than GPS
nipper replied to talamana's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your worried about resale value at 150,000 miles, may I suggest that one never buys a new car. Also consider this, that tire sizes are not an exact measurement (physical measurement is) between mfg's. Who knows if your new car bought today will even survive to 150K (hey its a rough world out there).
Clanking noise/rumbling coming from rear?
nipper replied to Doobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA bad U-Joint it my bet.
2001 H6 Outback central noise/thumping on taking off
nipper replied to RodA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt sounds like you may need a new (used) driveshaft due to a bad universal joint. As it is not making a vibration at speed that slowly gets lower with time, inspect that driveshaft now. I am going to assume that its not a tire issue only because this can be a saftey issue. How many miles are on it. FWD fuse isnt going to help at all if it is the drive shaft.
PORN! Subaru VW Porn!
You want to see a naked subaru engine? You want to see a subaru in a Beetle (and for once showing how its cooled) Got it right here
We Post Our Grievances Here
Dear Subaru, As a justy owner, please do share ho in bloody hell do you manage to bolt the carb on a justy manifold, or was it all assembled by Asian female children with the tinyest of fingers?
- Newbie with a slight problem
Burbing the cooling system
Fill the cooling system from empty SLOWLY with the engine runing. Allow the T-Stat to open and keep filling, yes with the heat on. Level ground is fine.
