25
Everything posted by nipper
Why did you replace ALL those parts. You only change one thing at a time. If you have the original parts from the car, put them back on. Then change just the sensor and check for vac leaks, and make sure the electircal connector is good. Also computer codes are a tool, not the answer to all problems. you stil have to do diagnositics. nipper
Just a general clarification for everyone. 13 flahses of the traany light on startup means that there was an electrical fault the last time the car was operated in the transmission. It does not automtaically mean that the Duty c is bad, but in your case, it is bad. There is a procedure for pulling tranny codes, so if you dont have TB and have the flashing tranny light it may be something else. nipper
Heat would be nice. I had a freind that had a wood burning stove in his garage. nipper
Compression should be 180-185 PSI. I would have a proper dry/wet compression test done first to see what the numbers are. If you want a vacume gauge can tell us the condition of the engine too. The aftermarket Cat, if it was an Eastern Cat, I would fault the cat and not the engine. A Cat can tolerate a fairly large amount of oil burning, as cars consume oil in thier normal operation. First thing first, get a proper compression test. nipper
